Question about Craftsman 10" Table Saw
Table saw does not start.
My 10" delta table saw does not start. I check the ciril break pushed in but does not come back. What I have to do to fix it.
    President:
  • 2,468 Answers
If it just hummmms then check for a start capacitor on the motor body,if none,then check for a bad centrifigual motor switch on the end of the motor
Posted on May 14, 2010
2 Suggested Answers
  • 60 Answers
SOURCE: table saw
I had a similar problem with my table saw. It would not come on. I unplugged it and cleaned out the on/off switch...it had saw dust in it that was preventing it from contacting and coming on. You might want to try this.
Posted on May 15, 2010
How do you "unlock" the Delta miter saw?
To unlock a miter saw, push down on the saw to unlock the head and loosen the knob on the table to make adjustments. Start using a miter saw with help from a custom furniture maker in this free video on woodworking tools. Read more: How to Unlock a Miter Saw How to Unlock Miter Saw Best Miter Saw Reviews Real Man Miter Saw
Oct 22, 2011 | Delta SM100M 13 Amp 10" Compound Miter Saw
I have a 10" Delta table saw. It was running rough
Check that the blade is not warped or binding. Don't use long extension cords. Check your home breakers. Also check if the table saw has a breaker. Don't force lumber into the blade too fast and don't jam the lumber between the guide and blade. Try a different outlet and check your wire for breaks. Good luck!
Oct 05, 2011 | Saws
I have a delta contractors table saw that wont start. It has a Marathon Electric Motor 62-044 that hangs off the back. It has capacitors rather than brushes. When you turn on the swithch it does nothing. I...
Most likely to quit suddenly is the switch.
My table saw switch broke recently, and at first I thought it was the motor.
Over the years I remember seeing table saws fitted with a handy box and ordinary light switch to replace the table saw switch.
Check for power at motor: Sometimes the wire connection from switch has access box on the motor where you can get in and check for power.
Feb 01, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
Table saw
May 14, 2010 | Saws
The motor on my delta 10" table saw starts a low rpm and does not go into high rpm - after a a few seconds it fails the circuit breaker, and without the belt conected this does not happen. Is the motor...
This saw tends to have a problem where the belt rides "outside" the V-grove. Check that the belt is actually installed into the V-grove, and that the grove is in line. Mine was installed (at the factory) with the shiv back to front, so the belt would catch, and kick out. Maybe the same issue.
Jan 30, 2010 | Delta 36-716B 10" 1-3/4 HP 120/240V...
10'' delta table saw manual
you might try Dewaltservicenet.com but you will need the model number and you might have to put the dash in between to get it to list the model. Let me know if you need more assistance and if you do I would also need this information.
Nov 27, 2009 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Delta Table Saw stopped running
I have a table saw that the cord from the motor plugs into the the back of the on/off switch. I yours is configured like that, unplug the motor cord from the back of the switch and plug it in to the wall and see if the motor will run. If so replace the switch.
Jun 21, 2009 | Delta 10"Hybrid Tablesaw with 30"Unifence
Can I mount a Delta 36-T30 T2 30-Inch Fence and Rail System on my
I just installed a Delta T2 fence on my 10" Craftsman Table Saw. It's 27" deep. The bushing either could be relocated or you could use spacers on the front, back, or both on the saw to get the required distance. Also, you'll have to drill new holes, however, I used one of the existing holes in the front and back of my saw as well.
Mar 11, 2009 | Delta 36 T30 T2 30 Inch Fence And Rail...
Delta shopmaster saw blade stuck down and won't go back up
sounds silly, but on the right side there is a blue knob.Push down on the saw handle and pull out the blue knob. That should release the saw arm.
Oct 08, 2008 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Craftsman 10" Table Saw Logo
419 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
