RCA D52W20 will not come on blinks three times it is not the deflection board what could it be
  • bweddings May 14, 2010
    i will try this thanks
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. If any of them is puffed up on top replace all the 3 capacitors. Resolder all pins on Fly Back Transformer (FBT) also. FBT could be in the power supply. Check the SMPS and in any event replace CP 120: 330UF/35V/HF & CP 150: 2200UF/16V/HF (May be bulged or vented). Always Resolder Cl031 & Cl032 (usually looks ok on visual inspection but common to ring crack). Replace deformed ribbon cable plastic connector BP005 on the flyback board. This connector is warping or bowing (May not even look like it) and causing poor connections to the Ribbon Cable. Replace RCA P/N # 258686. Try putting pressure on the BP005 Connector and turn the set on. You may find the set will now work fine. Replace connector and you may wish to replace the ribbon as well while you are doing the repair!
Note--If you want to do it yourself all this is only recommended if you have electrical expertise and know how to solder/re-solder components if not then you should always contact a qualified repair tech. Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF position.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 14, 2010
My RCA R52W turned itself off then on. When I hit the power on button it whistles the green on button comes on three times then turns off
The deflection board will need replacement . You can get the replacement deflection board from www.tvrepairworld.com which comes with installation instructions.
Oct 13, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Describe your D52W20 52 in. Rear Projection HDTV-Ready Television Problem the tv will not turn on the power light will blink three times then shut off
That could be caused by the CP150, CP120 and CP114 capacitors on the deflection board. Very famous issue. You can get the RCA repair kit by that same name from www.tvrepairworld.com which has the capacitors and the CD with repair instructions
Aug 27, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 in D52W20 that has no power, I have 1 blink followed by 9
Check these 3 capacitors on your Deflection board. its bottom board left hand side / cp150 2200uf16v and cp114 cp120 220uf 35v if any of them are swollen,vented or puffed up on top replace all 3 capacitors.
Mar 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv will not turn on
CK for Bad capacitors on your Deflection Board its the bottom board on left hand side cp150 cp114 cp120/ if (cp150)- 2200uf 16v is puffed up on top It is Bad replace all 3 capacitors 220uf 35v is the other 2.
Jan 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 gets power but won't turn on
Hi, thank you for visit fix ya.
Common problem on thi tv.
Capacitors on power supply bad.
Replace this:
2200uf 16V, 220uf 16V. Upgrade to 35V.
Located on power supply- deflection board.
(picture)a57b905.png Thank you
Jul 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Problem with d52w20
On the Deflection board there is 3 capacitors cp114,120,150 if any of them is puffed up on top replace all 3 capacitors cp150 2200uf 16 other 2 are 220uf 35v theywill be green with gold writing on them. Resolder all pinns on FBT also.flyback transfomer.
Feb 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV will not turn on.
On the Deflection board check capacitor cp150- 2200uf 16v if it is puffed up on top it is bad,replace 2 other caps in same circuit also cp114- cp120 -220uf 35v. they are green with gold writing on them.
Dec 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W27D The Three Blinks of Death
Check 3 capacitors on deflection board cp150,cp111,cp114 most of the time this is the problem 2200uf16v /330 uf 35v /220uf 35v.
Oct 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Jun 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
