Question about Taylor 5757 Digital Glass Body Fat Scale
Lost instructions I have misplaced my instructions, I cannot remember how to use the setting to determine fat percentage. My scale apperas to be your Taylor 5757 glass
  • 8,197 Answers
Posted on May 14, 2010
Testimonial: "Thank you, received the manual promptly, appreciate it."
Scale BFM588 User manual
Although the HealthOMeter.com site no longer posts a user manual for the BFM588DQ-81 scale, they do have a different model scale, BFM955-60, instruction manual that will work for the BFM588 because all the setting buttons are identical. You can download the manual for free at their site. Go to the site, under "Service & Support" setect "Instruction Manuals", then select "Body Fat Scales". Once there, find and select the BFM955-60. It will open as .pdf document and you can save it to your computer and print it out. It worked for my BFM588 scale for which I had lost the user manual.
Nov 16, 2014 | Health-O-Meter Health o Meter BFM588DQ-81...
How do I reset my ozeri digital scales that read body fat percentage
I fixed this on my scale by going through every profile and changing the height and age, setting the two main ones correctly (but swapping my wife and mine) and then setting the rest to be very short and young. Then I pressed Set, picked my profile again, and weight myself. At this point I no longer got the PIP2 error.
Jul 31, 2014 | Ozeri Precision II Digital Bath Scale...
I need a users manual for my Um-016
Tanita UM Series Body Fat / Hydration Monitor InstructionsTanita UM Series Body Fat Monitor/Scale Instruction Manual
How to Determine Body Fat Percentage
Setting & Storing Data in the Memory
1. Turn the power on using the set button.
2. Select a Personal data number using the Up/Down arrow buttons, then press set.
3. Select your Age using the Up/Down arrow buttons to scroll through numbers, then press set.
4. Select Male or Female using the Up/Down arrow buttons, then press set.
5. Specify the Height using the Up/Down arrow buttons, then press set.
The unit will beep twice and the display will flash all data (Male/Female, Age, Height) to confirm the programming. The power will shut automatically, or you can tap the weight only button (in front of monitor) for quick shut off.
How to select Personal Data Number
1. Press the Up memory button to turn on.
2. Use the Up/Down arrow buttons to select your personal data number, then press set.
3. The unit will beep and the display will show the programmed data.
4. The unit will beep again and the display will show '0.0' and then step on the platform.
5. Your weight will show first, then "00000" will appear and then your Body Fat Percentage will appear on the display.
Programming the Guest Mode
1. Press the Down Guest button to turn on
2. Follow the same steps for programming as outlined above.
3. The unit will beep twice and show '0.0', then Step onto the platform.
Taking Weight Measurement only
1. Select weight only mode, by toe-tapping the weight only button located at the base of the scale.
2. Wait for the scale to display ‘0.0', then step on.
Replacing the batteries
1. When the "Lo" error message appears on the screen, the batteries need to be replaced.
Understanding Your Readings
Healthy Range Indicator
(Please note this function is only applicable on adult mode, as no standard healthy ranges have been established for children and athletes.)
Your body fat monitor/scale instantly compares your body fat reading to the healthy range chart. Following your body fat reading, a black bar will flash across the bottom of the display, identifying where you fall within the body fat ranges for your age and gender.
(-): Underfat; below the healthy range. Increased risk for health problems
(O): Healthy; within the healthy body fat percentage range for your age/gender
(+): Overfat; above the healthy range. Increased risk for health problems
(++): Obese; high above the healthy body fat range. Greatly increased risk of obesity related problems.
Oct 18, 2009 | Tanita 2204 Body Fat Scale
No instructions. how do i set it up and what does
P zero to P 9 is just a user number to set it up... Instructions for set up are:
  • Turn it on.
  • Select user number using up and down buttons (P0 is fine).
  • Hit the Set button.
  • Choose gender using up and down buttons.
  • Enter your age using up and down buttons.
  • Enter your height (goes in 1/2 inch increments) using up and down buttons.
  • Hit the Set button. (Info is now saved.)
  • When scale changes to 0.0, you can step on, and get your weight.
  • It will blink and change weight possibly for a second or two. When it stops, it shows your weight.
  • Stay standing still on the scale after your weight, and it will gon to show your bodyfat percentage, then your body water percentage.
  • When finished, you can step off, and it will turn off.
Oct 17, 2009 | Taylor 5757 Digital Glass Body Fat Scale
Lost instructions for bmi and special feature settings
Conair Support – Online Tech Help to Troubleshoot Problems
by: Guest1223497 in Conair Weight Watchers WW-87 Body Fat Glass Scale | 9 months , 28 day(s) ago | 10 ... Manual or Instructions for Conair CID502 Phone ...
livesupport.maybenow.com/Conair
Oct 04, 2009 | Conair Weight Watchers WW-87 Body Fat...
Fat percentage question
Some body fat percentage levels are more culturally valued than others, and some are related to better health or improved athletic performance. Ideal percentages are also based on age categories as well. The recommended amount for women is 20-25% and for men is 8–14%. You can find a more detailed body fat percentage chart at your local dietitians and nutritionists, and on the internet.
Aug 27, 2008 | Detecto 8450 Low Profile Digital Pediatric...
Body fat scale Question
Like all body fat tests, body fat scales don't actually measure your body fat percentage. They determine your body density. The examiner (or the scales) then uses a formula to calculate body fat percentage based on body density. These formulas just predict your body fat. Unfortunately there is no one formula that accurately predicts body fat for the whole population. Differences in age, gender, ethnicity, body size, and fitness level all have a significant affect on the results. Well, whether body fat scales measure your "true" body fat percentage or not doesn't matter! As long as they can accurately monitor changes in your body composition over time, that's all you need.
Aug 27, 2008 | Detecto DR150 Low Profile Digital Platform...
How do I get body fat help?
The scales don't tell you the whole picture - your weight is less important than your percentage of body fat when it comes to appearance, fitness, and health. Tracking your percentage of body fat better shows how you are doing with diet and exercise than measuring weight. Remember that weight is measuring not only your fat, but also you muscles and your bones. If you did some extra work at the jym, your body weight might be effected (muscle tissue is heavier then fat tissue).
Aug 27, 2008 | Detecto Portable Digital Visiting Nursing...
Taylor 5757 Digital Glass Body Fat Scale Logo
860 people viewed this question
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
