Question about Panasonic Viera TC-L32C12 32 in. LCD TV
Picture is bigger than screen
The picture on my TV is bigger than the screen. Zoom and aspect ration doesnt fix the problem, its almost like it is always zoomed in.
  • 84 Answers
SOURCE: The picture has shrunk - maybe 720P vs 480P?
make sure your hd cable connection from your cable box is going to an hd connection to your tv.[via hdmi, dvi,or componant.] if you have a different hook up such as rca out or coax out, these are not hd connections and you are probably streching out the picture.look at the rear of the tv & cable box and see how the connections are.the hd hook up to the hd input should make the picture the right size only if it's set on the hd input channel.hook up the dvd player to a aux/line in or video/source input and try changing the picture size. you may have to play around with it till you get it the way you want.
hope this helps.
wg
Posted on Feb 06, 2008
SOURCE: Panasonic TV 50 inch plasma
I had the same problem and found that I was viewing the TV input instead of the composite input. Once I changed it back, the aspect setting would hold.
Posted on Feb 10, 2008
SOURCE: Zoom Function and Verizon Fios TV
On the verizon FIOS tv box, turn the FIOS STB on, and turn on the tv, tap the following buttons on the Verizon FIOS STB )in this order) 1-Power, then Select, then Menu. This will bring up the FIOS STB HD options. Arrow down to 4:3 Bypass and set the bypass option to 480P. Hit power 2 times, once to turn off, second time to turn STB back on. This should on standard channels give you the zoom feature back. This worked on my Samsunf 5053 TV model.
Posted on May 06, 2008
  • 1039 Answers
SOURCE: Panasonic Viera TV with black band on left hand side
disconnect the x and y sustain boards from the power supply. then check the flex connector to the screen and reseat them. check connections on c boards at bottom and screen connectors. reconnect the power supply only after all flex cables are reconnected or charge from supply will burn flex cables. if still preent replace correcsponding c board. if still no fix replace panel.
Posted on Apr 25, 2009
SOURCE: The picture is to big to fit on the TV screen.
It was the on the HD cable remote. the aspect ratio had to be changed backed to a 720
Posted on Sep 22, 2009
The picture is in the middle of the screen on my sanyo tv. Is the tv playing out or can I fix it?
could be or the aspect ratio has changed
get the on screen menu up and find the scree aspect ration using the volume buttons adjust till the picture is full screen with the figures the right size( not tall and skinny or short and fat)-- ok then exit
Jun 09, 2016 | Sanyo Televison & Video
How do I make the picture bigger so it fills the screen and not have black bands at top and bottom
Banding of the screen usually means that the aspect ratio of the broadcast is different than the screen size ratio. Most modern TVs are 16:9 ratio. Most modern TV broadcasts and movies are as well. In those cases, when in HD mode, you will see the picture fill the entire screen. Older broadcasts and many syndicated reruns are in the old 4:3 format and will be banded. Also, some movies are in larger formats than 16:9 and will reduce in size in order to get the entire picture on the screen. That being said, most TVs DO have a stretch and.or zoom feature that will expand all images to full screen size. Be advised that this can result is image distortion, especially of the 4:3 ration broadcasts. Others will have some of the picture cut off and you may see some items such as network logos, etc. partially chopped off in this mode.
Mar 13, 2015 | Televison & Video
The picture from the dvd is cut off at the top, bottom, and sides. only analog channels are found so zoom buttons on remote can't help. what to do? dvd player works fine on a different tv. this is a R
Check with an other known disc; have recording in aspect ration 4:3. If that disc show full screen picture, the recording to the present one; you're viewing has wide screen recording. Electro help
Nov 30, 2014 | RCA Televison & Video
Jvc lt-47em59 picture too large in all aspect modes
Larger as in -- the screen looks fatter. 4:3 stretched to 16:9 or as in Larger as in, screen is longer but thinner? 16:9 / 10 fitting onto ratio 4:3?
Asuming... its the second one -- that ur screen is box 4:3 and the picture is huge 16:9 which is why u need to "zoom out" to get the full picture -- are u sure some idiot didnt mess with the settings and make the tv "zoom in" if it isnt a aspect ratio issue?
... if it is a aspect ratio issue, and ur using 4:3 (small old box televisions) there should be a ratio setting either on ur television OR on ur set top box, that would by defualt with digital tv have wide screen 16:9 -- id suggest finding the settings either on the tv or the set top box or...
just get a bigger tv that supports 16:9 cheap for 50 bucks.
Mar 17, 2014 | JVC Televison & Video
Picture size bigger than tv screen.
Please check tv remote for Zoom/ Aspect Ratio button, press it to change picture size as compare to screen.
Hope this will help.
Thanks.
Aug 04, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Picture size too large, especially horizontal
Try to press the zoom in or zoom out button on the remote control
if that didn't work, try to check the aspect ratio of your TV. You can see the aspect ration on the menu. set it to 4:3 standards and if it's HD TV set it to 1080i.
Apr 17, 2011 | Televison & Video
Picture too large for screen
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
May 02, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My tv the picture is bigger than the tv screen
it sounds like you have hit the zoom button or your aspect ratio isnt right. the aspect ratio should be set to 16:9 (if there isnt a button for aspect ratio, change it in the menu) and there should be a zoom button on your remote and just keep hitting that and it should return to normal. If neither works, post your tv brand and model and i'll try to find another answer
Oct 20, 2008 | Akai PT4298HD Rear Projection Television
Model 51f59a hd widescreen aspect settings dont take and picture too big
I called Hitachi and the solution is in your cable remote not your tv remote. Your tv has a aspect menu as does your cable remote. Based on your cable provider you should have a settings or menu button to change the zoom or aspect of your screen. I had the same problem and have Comcast as cable and this worked for me.
Apr 25, 2008 | Hitachi 51F500 51" Rear Projection...
Panasonic Viera TC-L32C12 32 in. LCD TV Logo
378 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
