Question about Dryers
Fridgidare fdg546resi gas drye sounds like drum is
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
DryerFridgidare fdg546resi gas drye sounds like drum is - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on May 15, 2010
My Fridgidare gas stove model FGF348KSG trips the GFI when I try to turn the oven on.
Sounds like a dead short, you probably need to call the factory. Is it new? Has it always done this?
Jul 20, 2014 | Ovens
Our front load fridgidare dryer has began to squeal
You need a rear bearing most likely (5303281153)
This kit includes all that you need to redo the drum bearing. I have repair photos HERE
Mar 08, 2010 | Dryers
Drye runs but does not get warm
Sounds like your heating coil is faulty.
Unplug the dryer, remove the back of the dryer.
Locate the air tube going from the blower to the drum.
Normally inside the air tube is where you will find the heating coil and thermostats.
Remove the wires from the heating coil...and check with a continuity meter across the two terminals...you should read continuity across the terminals, if you do not read continuity across the terminals then the heater coil is faulty.
Good luck,
I hope this helps
Oct 05, 2009 | Whirlpool Dryers
Dryer makes a thumping noise when drum is turning its an electric fridgidare de5520rw2
Sounds like you have flat spots on your drum rollers.
If your machine is a front loader, remove the front of the machine, this will expose the belt and drum, remove the drum and belt, and this will expose the drum rollers.
Check the rollers to see if they have flat spots on them, if they do replace them with new ones. This should solve your thumping noise.
If the rollers do not have flat spots on them then you can try to lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil.
I hope this helps
Oct 02, 2009 | Frigidaire Dryers
How do I register a Kenmore Microwave Oven and a Kenmore Gas Drye
you can call any sears store and they will be happy to register them for you.
Sep 09, 2009 | Microwave Ovens
My dryer is making a horrible scraping sound...metal on metal. It appears to be coming from the back area. The belt is still intact...I can make the sound just by turning by hand. I've tried taking the...
rear bearing is bad you will need to take the dryer apart and replace the bearing also you need to check the front drum support while you have the dryer apart
Jul 10, 2009 | GE DBSR453EBWW Electric Dryer
Drye squeaks louldly and smells hot drum stops turning
you have a drum ball that is chrome looking that fails a lot
you need to get the kit and direction from a parts house to fix it ..
mine breakes about every 6 mo
5 boys in the house
Apr 02, 2009 | Kenmore Dryers
Fridgidare dryer problem
there is a front glide assembly, depending on model will have 3 teflon/plastic glides attached t o the felt, this may be your grinding and gap issue
Nov 16, 2008 | Dryers
Dryers Logo
Top Dryers Experts
