Question about Brother IntelliFAX 4100 Laser Fax
VOIP support fax machines - Brother IntelliFAX 4100 Laser Fax
    President:
  • 3,085 Answers
None
Posted on May 14, 2010
3 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: adjust baud rate on Sharp UX- 700 fax machine
It won't make any difference if you could. All fax machines are analog devices and won't work reliably on a digital phone line.
Posted on Nov 13, 2009
  • 265 Answers
SOURCE: Comm error on a VOIP line
Fax cannot send on a VOIP line unless the VOIP line has T.38 fax protocol service.
Posted on Dec 14, 2009
How do I access system settings to change the baud rate and turn off ECM.Thanks in advance.
Fax settings for VoIP ' How to lower the Baud Rate ' Faxing ...
www.voipmechanic.com/voip-fax-settings-9600-baud.htm
How to Lower the BAUD rate to 9600 on fax machines for better VoIP faxing success.
Faxing over VoIP, the correct configuration settings that you ...
www.voipmechanic.com/faxingissuesandotherdevices.htm
How to fax over VoIP and the settings and configurations, like BAUD rate that you need to set.
Dell VoIP Fax Settings, how to lower the BAUD rate and ...
www.voipmechanic.com/voip-fax-settings-dell.htm
VoIP Fax settings for Dell printer/fax machines/multi-purpose machines.Missing: kyocera
Faxing over VoIP - Sfax
Dec 15, 2015 | Kyocera FS-1128MFP FS-1128MFP...
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
Fax machine does not receive FAX
The problem is that the codecs used by VoIP IADs are designed to compress voice, not the analog signals sent and received by modems.
In a VoIP Internet world, voice is first converted into packets and then they are sent over the connections that make up our our vast Internet. They may take slightly different times to arrive at their destination. In doing so some packets may be discarded, but the end result is that the receiving VoIP device has enough packets to make a clear and understandable conversation.
We suggest these settings on a fax machine for faxing over VoIP; slowing the transmission rate down and allowing the machine to continue receiving the transmission even though a few bits of data were lost, then faxing over VoIP can become more consistent. Our suggestions in many cases can resolve issues that prevent faxing over a VoIP connection, but not in all cases. If after trying and making all the VoIP fax changes we suggest you still cannot fax over your connection then try a Internet Fax service.
Aug 10, 2011 | HP Office Equipment & Supplies
Using on voip
If your VOIP adapter has only one service line (VOIP PIN configured) then you have to remove the phone line and connect the FAX line. Now if you have the two service lines (in the both port separate VOIP PIN should be configured) - then you may connect this FAX to the other port. Both (Phone as well ad FAX) will work simultaneously. (Remember - two seperate PINS are required if you attach phone as well as FAX line in same adapter). After attaching the FAX - every think is normal like normal FAX line. Generally you don't have to dial pre country code like 011 or 00 or +, just dial the number starting from Country code.
Jun 06, 2010 | Brother FAX-575 Plain Paper Thermal
Adjust baud rate on Sharp UX- 700 fax machine
Nov 13, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Slow down a HP 640fax machine for VOIP use
Can't be done. ALL fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines.
Oct 17, 2009 | HP 640 Inkjet Fax Machine
Sep 25, 2009 | Brother FAX-575 Plain Paper Thermal
Connect fax from 6210 to phone via cable modem (VoIP)
In Order to use a Fax functionality of the router you need to connect the small RJ11 cable for telephones on the printer port. These printers do not suppoer VOIP Fax. To use VOIP as fax you can purchase a online VOIP subscription where you can scan and fax the documents.
Feb 04, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP 5610xi All-in-one wont send fax since switching from Vonage to Comcast
the 5610 will send & recive with comcast try to do the test from the unit itself. Try to send a test fax to HP 1-888-473-2963 it will send you a return fax
Jul 11, 2008 | HP Officejet 5610 All-In-One InkJet...
Sending fax
Iam afraid HP Supports VOIP Services, they always says that we do not assure fax in VOIP Service because it is not analog it is digital they always refer to your service provider
Also you can tried reducing the speed of the fax machine
That is> Press Menu/Setup> then scroll toAdvance Fax setup> Then Fax Speed> then Press Ok> And reduce the speed to Slow and then try.
Good Luck
Jun 13, 2008 | HP PSC 2210 All-In-One InkJet Printer
Brother IntelliFAX 4100 Laser Fax Logo
157 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
