Question about Electric Strider Maxi 4 Wheel Mobility Scooter - Cherry Red
Scooter dash lights flash up and down .were normaly they come on and stay at top .they just constantly run up and down ..batteries show on charger in boot .that its fully charged
  • 177 Answers
Hi. Some scooters will show a pattern like this while the charger is operating, but when the charger is turned off it should stop. Some internal chargers have a relay that is activated while the charger is on to disable the scooter. Does the scooter operate properly after the charger is turned off? If not, then unplug the charger where it connects to the batteries inside the scooter and see if this helps. If this helps, you might need a new charger.
Good luck. Neil.
Posted on May 29, 2010
Why does green light on charger stay on?
Most pride chargers show up the green light when batteries r charged...when charging u should have a red power led & an orange led ...hope this helps
Jan 07, 2016 | Pride Mobility Products Go-Go Elite...
Why won't my lights work
It sounds like your alternator is not charging the battery. Fit a new battery remember to undo negative lead first to remove and fit positive lead first to refit the battery. When the new battery is filled please charge it using less than 1 Amp DO NOT use a car charger or try to jump start it. Your new battery should show 12.5 to 13 volts on a meter for a 12 volt system and 6.3 to near 7 volts for a 6 volt system. Start the scooter and check across the battery terminals your meter should show about 14.4 V for 12 volt battery and about 7.5 V for a 6 Volt one. No voltage increase means your charging circuit is not working. Either the alternator or rectifier(regulator) are not operating correctly. Worst case scenario is both units dead.
Sep 06, 2014 | 2012 Piaggio Fly 50 4V
My husbands Daytona 4 just started having this charging problem
I'm afraid your batteries have expired. They will show full voltage but the Amps are not being replenished.
Jun 18, 2014 | Drive Medical Health & Beauty
Scooter won't run
How old is the battery? Most are only good for three years........
Mike
Mar 15, 2014 | Ezip Currie 1000 Electric Scooter, Black
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
Blue light on battery condition meter is blinking. It doesn't stop.
hi the blue light is indicating a fault, now count the flashes before a pause, or does it just flash all of the time ?
Please keep me updated.
Regards
Dec 22, 2012 | Pride Pursuit Xl Heavy Duty 4-wheel...
Charger light flashes when plugged into laptop , stays on solid when unplugged,had charger checked 19v ok ,had socket checked 19v ok ,then checked to first board 19v ok ?? has a board gone down ??? annoyin...
your battery pack is causing your problem rule #1 never!! leave the charger in!! everytime you start up!! run off the batteries till the power low light come's on then apply the charger constant charging causes early failure of all/ any nican battery pack
Jan 13, 2010 | Acer Aspire 5920-6335 Laptop
Electric Strider Maxi 4 Wheel Mobility Scooter - Cherry Red Logo
236 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
