Question about Husqvarna Sewing Machines
I have a Mega Quilter Machine and top thread keeps breaking and irregular stitches.
  • 713 Answers
Hi,please check the tension setting on your machine it might be shifted,this will definately cause the thread to break and produce irregular stitches,if the problem persists,you should take out the bobbin case and oil it adequately
Thanks and take care
Posted on May 14, 2010
  • skf1851 May 14, 2010
    Would this cause the top thread to keep breaking every little bit??
When sewing it skips stitches also the thread keeps breaking.
Remove the thread from the machine.
Install a brand new needle.
RAISE the presser foot and rethread the top thread.
Verify the thread path is correct.
Load and thread the bobbin case & install it. Verify it is correct.
Set the top tension at the midway point.
Re-test your stitch.
Sewing Machine Problem 1 Thread Breakage
10 reasons for skipped stitches
Mar 22, 2017 | Sewing Machines
My top thread on the mega quilter keeps looping big loops on the backing and the quilt is on the frame. How do I fix this problem?
I'm not familiar with quilting machines, but I have heard conversations about problems occurring when the fabric sandwich is stretched too tight so it is "trampolining" when it stitches. Also, the needle may need changing. Could be that the thread is too heavy for the needle being used.
JM humble guess!
Sep 25, 2016 | Sewing Machines
What could be wrong with my Husqvarna Mega Quilter?
could be the computer is not working right or could be a mechanical problem, if the problem doesn't stop the machine needs to be checked
Jan 06, 2016 | Husqvarna Sewing Machines
Adjust the timing on a singer confidence quilter 7469q
Hook/needle timing needs a hands on guidance to get it fix, 2 options either you can watch in utube 'singer sewing machine hook timing' or 'google' for singer 7469q service manual for your referral.
Nov 10, 2013 | Singer Confidence 7469 Mechanical Sewing...
Shredding thread
have you checked to see if the needle is inserted into the needle
holder correctly
have you checked to see if it's the correct size needle for the machine& for the fabric
check for burrs in the needle plate area & on the bobbin case
if these suggestions don't help then it's possible that the machine
needs to be checked at a sewing machine shop to see if the
machine could be slightly out of time.
Aug 20, 2012 | Sewing Machines
I have the Mega Quilter and Quilters Cruise Control. My stitches are very inconsistent.
I agree to have the regulator check, & even having the whole machine checked wouldn't hurt.
May 15, 2012 | Sewing Machines
I have a Viking Mega Quilter. The bobbin thread is sewing properly for a few stitches and then does a loose stitch and then a few good stitches and a loose one again, etc.
Good day!!!
please apply a some oil on the motor and other moving parts inside you sewing machine..
After that reboot the machine and used it....first try is persisted but when you used it continuously for at least 10 minutes your machine is OK...
thanks for using fixya..
Jun 23, 2011 | Husqvarna Viking 1
My sister just bought the smaller mega quilter, we are having difficulties when threading machine. we have studied booklet and video and believe we have threaded it correctly. every time we try to sew...
when you sew or use a serger or a quilter machine have a long thread tail of 3-6 inches & make sure the tail is pulled behind the needle
happy quilting
Nov 03, 2010 | Husqvarna Sewing Machines
I have an older kenmore sewing machine. It's been
When I have run into similar problems with my older Singer, it's because there is a bit of thread caught somewhere in the bobbin mechanism that doesn't allow the shuttle to run freely. Take the bobbin assembly apart and use a bright light to see if you see any bits of thread in there.
Good luck and let me know if this works!
Jan 14, 2010 | Kenmore Sewing Machines
Sewing Machines Logo
53 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
