Question about Panasonic PT-50LC13 50" Rear Projection HDTV
TV does not turn on, blinking green on off button.
The replace bulb message has been coming on for some weeks now, but once you turn set on and off the TV comes on and everything looks fine. However, today the on off button only flashes green or red, TV won't come on. Is this related to bulb or a separate problem? How difficult to change bulb if that is the problem?
I replaced the ballast kit and I have 5 blinking yellows lights and it doesn't turn on!!!
Posted on Jun 13, 2010
    President:
  • 3,130 Answers
That should be in the owners manual
techman
most sets havev a small door thathas has a screw on it and the bulb is inside a small cage you pull out
techman
Posted on May 14, 2010
SOURCE:
I've owned a Vizio VT420M for just over 13 months. About a week ago the tv started flickering when I turn it on. The picture is visable, but the area around the actors is flickering. After about 7 to 10...
The flickering is most likely due to a faulty fluorescent backlight. Once the bulb heats up the flickering usually goes away. Some bulbs are easier to replace than others so I would contact your local TV repair shop.
Mar 01, 2011 | Vizio VT420M LCD TV
Hitachi ultravision projection that is turning off
Ur tv projection bulb,been a long time had not been replaced?If the the bulb been,replaced the ballast might be dead.
Apr 14, 2010 | Hitachi UltraVision 55HDS52 Television
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
I have a 50'' Philips tv. When I turn it on the picture comes on fine, within a matter of minutes the picture goes out and this red light comes on highlighting a tiny picture of a light bulb on the ''on...
Sounds like your lamp is bad. I think this is the set where you have to take the whole back off to replace the lamp. Once you take the back off, its on the left hand side.
Dec 02, 2009 | Philips 50PL9126D/37B 50" DLP TV
Red keeps going out but there is a new bulb in place.
red light keeps blinking on and off but the tv isnt turning on
Jun 02, 2009 | Toshiba TN61X81 61" Rear Projection...
KDF E60A20 screen goes blank loses sound for 10 60 seconds
I've had this same problem ongoing for a couple weeks. Finally, tonight it would shut off every 20-30 seconds, stay off for another 20-30 seconds then come back on. It turned out to be my bulb. I blew the TV out with compressed air, removed the bulb and disassembled it. Taking the bulb out of the plastic cage I then remove one of the metal screens at the top of the bulb, it just has little clips holding it in. I took a bottle of rubbing alcohol, some Q-tips and proceeded to clean the inside of the bulb through the screen hole. After cleaning the inside I put the screen back in, cleaned the outside of the bulb with a rag and alcohol, then reassembled everything. The TV is much brighter, I had to turn down the brightness setting and has been running the last few hours without an issue. You can avoid all this by buying a new bulb but I don't have the money right now to replace it and I'm cheap so I'll milk this bulb for everything it has. Heat kills bulbs so if you clean the screens and blow out the TV once every couple months you'll get a lot of life out of it..... I'm almost to 4 years on my original bulb and my TV is on constantly!! Good luck to all!!
Mar 15, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Samsung hl-s4666w won't come on...
Circuit malfunction indicated. Have it serviced
Apr 18, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
PT-50DL54 panasonic 50" DLP
to get rid of "replace lamp" push the blue action button on the remote and the volumn down on the tv set for a couple of seconds. this has to be done at the same time, good luck.
Bob
Dec 09, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Unexpected lamp shutdown
TRY REPLACING THE BALLAST POWER SUPPLY FOR THE LAMP-THIS WILL HAVE TO BE CHECKED FIRST BY A SERVICE TECH TO VERIFY WHETHER THE LAMP DRIVE VOLTAGE IS SUFFICENT. IF NOT SUSPECT A BAD BALLAST POWER SUPPLY. ALSO COULD JUST A DEFECTIVE LAMP. AAA ELEC
Nov 09, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
372 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
