Question about iLO DVDR05 DVD Recorder
Can't record from tv or disc,
When would you need a modulator
Shouldn't need one, If you can't get the tuner source of your ilo to record, try using A/V cables (output) from tv to (Inputs) on ilo. set tv on channel you want to watch and it should come through to the ilo (selecting the correct source input of course) If your tv is really old and doesn't have A/V then you will need RF Modulator. This way of hooking tv up will also work with recording DIGITAL signal from a Digital converter box type tuner (the tuner in Ilo soon to be no longer operatable).
Posted on May 20, 2008
Just bought the Bush BPDP42HD and nowhere in the user guide does it tell you how to record. There is the option from the menu but when you tell it to record it says "disc not ready". What disc?...
to record and pause live tv you need to purchase a USB stick which you can buy for around £40 for a 16GB, this will allow you to do these actions. I agree, I even sent my TV back as faulty because of this.
Jan 23, 2011 | Televison & Video
I am trying to connect a DVD player to a RCA F25216BC 25" TV - the TV only has an F type Coax connector and does not have a CH 3 or 4 switch - I put the input from the wall to the DVD player and out to the...
Your TV must be equipped with AV inputs (RCA jacks - yellow, white, red)
in order to connect this unit. If your TV does not have AV inputs, you will need a RF Modulator to connect the DVD recorder to your TV's
antenna/cable input. RF Modulators are available at
major electronics retailers such as Radio Shack or Wal-Mart and allow the 3 RCA outs from the recorder to connect to the RF modulator RCA inputs and then you can connect a coaxial cable from the modulator to the TV RF input and select channel 3 or 4 on the TV. The DVD recorder will not pass thru signals to the TV using coaxial cable as far as DVD are concerned.
Aug 22, 2010 | RCA F25216BC 25" TV
How can I record a tv show onto a blank disc? I
Make sure you have the right DVD disc and the disc is clean if you do... (2) make sure you connected it right and are fully seated. LINE IN on your DVD-R is for the recorder part LINE OUT on the tv is to send it to the DVD-R If you done that try another RCA cable or two That should fix it
Jul 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Cannot tape on vcr with new dvd-vcr player
You need to route the signal from the cable modulator to the DVR and then to the TV to be able to view and record. If this is done you will be able to watch what you are recording. When you are not recording, the signal will go through the DVR to the TV.
Please change the cabling and you should have what you want.
May 26, 2009 | RCA 32V550T 32" TV
Recording onto DVD
That's because the DVD+R and DVD-R discs are actually different, and the recorder is made to record only on the +R media. It will play back discs recorded by other units on -R discs. But you'll need to purchase the +R type. They are the same price.
Hope you've found this helpful. Please take a moment to rate my solution, and thanks for asking here!
Mar 18, 2009 | Humax DRT800 DVD Recorder w/ 80 hr Tivo
No Disc
I have the same model ... you can't use DVD-R or DVD-RW discs, only DVD+R or DVD+RW
Apr 26, 2008 | Cyberhome DVD Recorder - DVR1600
Recordes but dont play back
before you can watch a recorded DVD on another DVD player you must finalize the disc. to finalize the disc put the recorded disc into the DVD recorder, when the DVD loads it will show the titles that are recorded on the DVD on the screen
push the stop button it is the button with the square on it. the screen will go blank or it may let you watch whatever tv channel you are on if you have your tv ran through the recorder, push the setup buton a new screen will come up, with the arrow down button scroll down and highlight disc edit, press ok another screen will come up, with the arrow down button scroll down and highlight "finalize", press "ok" it is the button in the middle of the arrow keys
scroll up and highlight "yes" press "ok" the recorder will finalize the disc and it can be watched on any DVD player, just remember when you finalize a disc you cannot add anything else to the disc.
Mar 02, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can i record from tv to dvd
yes
make sure the cables are connected correctly, the manual will show that.
If the mwr20v6 has a tuner you must have the channel on the dvd set to the program, if it has no tuner, you must have your tv set to the correct channel.
Feb 13, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
DVD recording.
Sounds like the DVDR is recording from the digi-box through the TV, so when the TV is switched of or into standby the signal is lost, causing the recorder to pause.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
Feb 05, 2008 | Philips DVDR3380/05 DVD Recorder
Recorder problem
panero,
it sounds like your setup is incorrect. You need to stick the antenna cable into the dvdrecorder so it can get a tv signal then the from tv recorder back out to your tv via your tv modulator. What this means is that you will need to tune your tv to a particular channel ie. channel 3 is the common one to use then change your tv channels via your dvd recorder so it record and if your dvd recorder will passthrough the signals you can probably wtach tv on one channel and then record on a different one.
good luck.
smeags.
Jan 04, 2008 | Cyberhome DVD Recorder - DVR1600
iLO DVDR05 DVD Recorder Logo
67 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
