Sharp Sidekick LX Smartphone Logo
Posted on May 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant get my menu and jump button to work
My menu and jump button wont work on my sidekick lx 2009 after i dropped is there anything i can do?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
108
Points
How to set incoming call ringtone
Anonymous
Level 2:
New Friend:
  • Expert 92 Answers
  • Posted on Jun 16, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
92
Questions
0
Helped
20905
Points
155
Try calling the manufactur
How do you unlock sidekick Lx 2009
To Unlock SIDEKICK 2009 LX get the Unlock code from the site
Classicunlocking.com/sidekick-lx-2009/rs17wp9/ and Unlock it easily..
My sidekick lx 2009 didnt ask to enter code, plz help me thanks u
It says just Network lock only,You need to enter the Code if it locked Network mean.You can get the Unlock code at here
http://www.superunlockcodes.com/sidekick-lx-2009/rs12wp9/ and Unlock it,get the Unlocking Instructions below to unlock it step by step.
Sidekick LX 2009 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Sidekick LX 2009 mobile phones. If you enter over a certain amount of wrong unlock codes on your Sidekick LX 2009 mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your Sidekick LX 2009 with a Not ACCEPTED SIM Card.
2. If your Sidekick LX 2009 asks for a PIN code, then enter your SIM card PIN and press OK.
3. Sidekick LX 2009 will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your Sidekick LX 2009 is now unlocked.
*NOT ACCEPTED : We mean, to use a Sim card from a network other than the network your Sidekick LX 2009 is locked to.
Each Sidekick LX 2009 mobile phone has an unique unlock code. You can buy the unique unlock code for your Sidekick LX 2009 mobile phone using the form above.
I forgot my sidekick lx 09 code is there a master code?
THE ONLY OPTION FOR THIS IS A HARD RESET WHICH WILL DELETE ALL DATA.
Hard Reset
1. Press the Menu button.
2. Scroll to and select Settings
3. Scroll to and select System Info
4. Press the Menu, Shift and X keys simultaneiously.
5. Select Erase to erase the flash settings.
6. At the System Info screen, press the Menu, Shift and R keys simultaneously.
7. Select Erase to erase the Sign-In information.
8. Insert a paper clip in the reset hole while holding down the Power button.
Note: The device vibrates if all steps are performed correctl
1helpful
I turned off my sidekick lx 2009 (off button) and it wont turn on
what i did was take out my sim charg it den cut it on it will cut on put sim bak in afta u cut it off and try again do a couple of time it will work
1helpful
My sidekick lx 2009 got water damage, and now it
Let it DRY up! Remove the battery and let it sit, open, for several hours, if not days. It needs to dry up completely before it can operate again, if you're lucky. My wife dropped hers in the toilet, but quickly did what I suggest, and the phone was fine the following day.
Sep 11, 2009 • Cell Phones
2helpful
3answers
My sidekick lx speaker wont work
unfortanetly the device uses smd components and very small form factors to rteplace componanets. good news is many people had this issue and many people got their phones replaced. for free just tell them that you did not drop it or damadge it and it stopped working for no aparent reason, they suld honor that and help you out.
25helpful
Forgot my security code for sidekick lx
OK WHEN U GET TO THE THREE CODE THING HIT THA CALL BUTTON 2 TIME AND THEN HOLD MENU SHIFT AND Q AND THERE U GO
1helpful
I have the Sidekick LX and the scrollball stopped working.
More than likely, the trackball on your Side LX is really dirty. Overtime, dirt and grime gets in between the ball and the sensors.
It is really easy to clean it, you will need q-tips and IPA alcohol.
Check out the Video at the following link to see how the trackball cleaning on the Sidekick LX is done
Clean the Trackball on a Sidekick LX
3answers
Sidekick lx
I can tell you that if you have pictures on them they have to be put into a specific folder to view on the phone. The easiest thing to do is format the card on your computer. After I did that the sidekick had no problems reading mine. If you ever add photos to the card from an outside source such as usb cable make sure you put the pictures in the exact same folder the sidekick camera puts them in.
14helpful
Sidekick lx spacebar
Go to:
http://www.fixmysidekick.com/sidekick-lx-or-sidekick-2008-space-bar-not-working/164/
Or just read this...:
sidekick2008spacebarpicture.jpgIs the space bar on your Sidekick LX not working when you are trying to text or in AIM? Do you have thesame space bar button problem on your T-mobile Sidekick 2008? Does the Sidekick spacebar work in other apps though?
If so then this fix is for you.
1. Open the AutoText & Spelling screen. From the Jump screen, press the MENU button, then select Settings > AutoText & Spelling.
2. Uncheck the following settings:
    • Highlight misspelled words
    • Auto correct spelling
3. Exit out of the settings screen and try it out.
Hopefully, this will have solved your issue.
How to check for misspelled words with these two options unchecked?
Run a manual spell check on T-mobile Sidekick: To run a spell check while in a text field from any Edit Text submenu, or by using the keyboard shortcut by pressing MENU +S.
Top Sharp Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Ngoro
john h
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
