Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mower blades will not disengage - Craftsman 42 in. Deck 19.5hp Lawn Tractor
There's a bolt with a shoulder (bolt shoulder) and a cam follower (plastic sheath) down there on an arm assembly, the bolt and sheath on mine worn down so one side was flat,.... it got caught where it was supposed to slide to disengage the blades,... there another bolt just like it on the other arm assembly,. I switched them out because the other one just slides in and out,... so the worn part wouldn't affect the action as much,... works just fine now,....
Posted on Sep 21, 2010
Model 917.20381 riding mower. Why don't blades disengage?
Terry, Deck full of debris around belt tensioner not allowing it to release, tension arm seized/spring broke, wrong/small belt installed.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CRAFTSMAN 42 MOWER REPAIR
My mower deck will not disengage
Blade will not disengage Craftsman 917 270662
https://answers.yahoo.com/question/index?qid=20090407155731AACRvsq
Sears Craftsman 917 272481 LTX1000 Riding Mower Deck Belt Blade...
Apr 08, 2016 | Craftsman Garden
Mower will start fine when I engage the blades it will mow for a short time then the mower wants to stall and will if I don't disengage the blades
Are the blades turning freely when disengaged. Is it possible something is interfering and binding them somewhat (for example, if the mower picked up some rope and it wrapped around the shaft to the blades)?
Apr 02, 2016 | Garden
I have a 42 inch troy-bilt riding mower the blades won't disengage.
Sounds like either the switch for the blades is not shutting off the power to the electric clutch or the clutch itself is not disengaging. I would shut the mower off and unplug the wire to the electric clutch and then start the mower and make sure the blades do not turn you may have the belt for the blades on the wrong pulley and it might be causing the blades to turn. Hope this helps.
Apr 18, 2014 | Troy -Bilt String Trimmer/Blower...
I have a poulan pro PR1842STC; the blades won't stop turning after I disengage the mower belt
On the top of the mower deck, there is a spring that will pull to disengage the blade idler pulley. At the same time, it will release two springloaded arms with brakes that press on the pulleys at the top of the blade spindles. On top of the mower deck at the back, the two spring loaded arms may be held out of the braking position by a cam. Make sure the cam is free to allow the blade brakes to activate when you disengage the blades. If arms are out of alignment, or the parts are too worn, the blade brakes won't move and the blades keep spinning, even after you have disengaged and the safety switch is deactivated. This is a dangerous situation and should be fixed soon. Good luck.
May 09, 2013 | Poulan Garden
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mower will not disengage
this is because your belt that drives the blades is to tight i suggest getting a looser belt
May 10, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Cutting blades won't disengage
Check you blades to see if one is bent. Do this with the mower NOT RUNNING and the KEY OUT of THE IGNITION! Look under the deck to see if one is bent. This will cause the wobble. As far as no disengaging your electric clutch could be bad. The bearing could have seized up.
Apr 24, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
After replacing the belt, new pulleys, and bolts, my mower wont disengage the blades when i disengage the lever. when i start the mower, the blades are off, but once i engage the lever, they start, but...
sounds like the linkage to your blades, check your lever, to make sure its working right may need some grease, it may be sticking and not fully engaging, or doing its job when its supposed to
Oct 17, 2009 | Craftsman Garden
Craftsman riding mower blades won't disengage
This is too late, but for the next person: There is an extension spring around the cable attached to the blade engage/disengage lever.
On my tractor one end of the spring had the hook broken off or it. Because it is around the cable it is still in place but doesn't stretch when you engage the blade (so can't pull the pulley out and slacken the belt when you disengage).
The replacement is a few dollars and can be bought on ebay or Amazon.
Aug 15, 2009 | Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
505 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
