Question about SNK Xbox 360 Arcade Console
Green lights in wrong place on xbox
When just one person is playing the xbox, the green light indicating one player connected, flashes between players 1 and 2. why is this?
    Scholar:
  • 161 Answers
There is a sensor in the xbox that determines if the xbox is in a horizontal or vertical position. That sensor is probably broken causing the ring of light to go haywire. I am not even sure what you should do first.
Attempt to contact microsoft if you think its that big of a deal.
Posted on May 14, 2010
DVD Player will not power on. Indicator light flashes repeatedly.
Since the players of this kind are not repaired because of the low cost of new, just replace it.
Jul 06, 2017 | Televison & Video
DVD Player will not power on. Power Indicator Light flashes repeatedly.
Plug out the device,Open the outer shell or strip the outer shell take a hair dryer heat up the board slightly until it feels slightly warm then plug in and switch on and remove disc.Then put outer shell back and fasten screws that where removed.
Jan 06, 2014 | Sony DVP-CX860 Multi-disc DVD Player
When I turn on my ipod shuffle & hit play it blinks green and orange several times and won't play
The Apple iPod shuffle is a digital music player that contains a single indicator light that relays information about the device's battery condition, computer connection and any errors the device is having. The indicator light is capable of blinking red, green or orange as well as displaying a steady red, green or orange light. The iPod Shuffle includes a Universal Serial Bus interface and buttons on the front of the device for controlling music files.
Blinking Orange A blinking orange light indicates the iPod Shuffle is receiving an update via iTunes to the device's internal components. The update could include a patch to repair an error the player encountered once before, an update to the player's file-saving software, or a combination of security, repair and software updates. Updates are free and automatically sent directly from Apple through iTunes to your iPod shuffle before a sync process starts. Disconnecting iPod Shuffle When the player's light is blinking orange, do not unplug the device from your computer's USB port this will stop the update process and possible corrupt the device's internal hard drive. Let the update process and sync process finish before clicking "Eject" within iTunes and removing the player. Disk Use Enabled If you use your iPod Shuffle as a flash drive and not as a music player, a blinking orange light means that the device is connected to your computer and ready to accept files. The "Disk Use" enabled setting is changeable within iTunes if you decide to use your iPod Shuffle for music storage instead of file storage. When set up as a flash drive, the iPod Shuffle is assigned a drive letter by your computer's operating system and the drive lets you "drag and drop" files to the device. b> Charging If your iPod shuffle's battery is completely depleted or low on charge, connect the player to your computer immediately for charging then leave it connected to receive any updates to the device's software and internal components. Its indicator light may or may not blink orange until after it is fully charged. If the battery is low on charge or completely depleted, you may receive an error stating that the iPod is corrupt or needs restoring, close the error message and let the device fully charge.
b>
Feb 12, 2013 | Apple iPod Shuffle Second Gen.1 GB MP3...
MY APPLE IPOD A1112 IS NOT PLAYING MUSIC , THE ORANGE AND GREEN light JUST FLASHES
Aug 16, 2012 | Apple A1112 Ipod Accessory Personal Mp3...
Two red flashing lights on top and two green on bottom
Two red lights generally indicate hardware failure. Two green lights indicate two controllers are connected. Both green and red lights will not be lit at the same time. The green light in the middle indicates that the console is turned on. For more help deciphering red light flashing errors, see this guide HERE.
Feb 02, 2011 | Microsoft Xbox 360 Console
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
I have just purchased another wireless controller for the xbox 360 and do not know how to connect it.
sync the controller to the xbox :-)
press the little button on the controller (near the LT LB buttons) and with-in 2 seconds press the sync button on the front of the xbox !
pressing These will make the green lights on the controller & the xbox rotate until eventually just the first player L.E.D stays on indicating player one :-)
play & enjoy :-)
hope this helps ??
Feb 17, 2010 | Microsoft Xbox 360 Controller
While playing game the circle is green then lights up red
If your xbox is lighting up red on the player one and player sections( being the top left and bottome left) the problem is your xbox is overheating, u need to
a) if under warranty seek microsoft advice as your fans/cooling system may be faulty OR
b) pull apart and clean and test fans for functionabilty.Good Luck.
Nov 15, 2009 | Microsoft Xbox 360 Console
Player frozen, green light on
i had my GFs mp3 player and it was flashing green light, not solid, but still was frozen and couldnt even bring it up on my computer after plugging in the USB cable. but i just tapped the reset button on top right side, and it stopped flashing and turned off. i turned it back on and started to play normally. not sure if it will be the same since the light situation is different, but the reset button worked for me. good luck
Jan 28, 2009 | Creative Labs ZEN Stone MP3 Player
I keep getting three red rings in the part where it shows how may controllers are playing and i can't get any of my games to play or my controllers to work
Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console.
You can try one or two things.
1. Turn on your xbox and check to see if the power supply light is green. If it is green there is a problem with the system. If it is red it means you should check your connections and restart the xbox.
2. These rings have a tendency of meaning that there is a problem with the system itself. Most companies sell extra insurance to cover this "ROL" Ring of life. You can contact Microsoft by calling them. The number is usually listed on the back of the video game booklets.
I wish you the best and I hope this resolved your problem
Happy Gaming
http://support.microsoft.com/kb/907534
Oct 18, 2008 | Video Game Consoles & Games
SNK Xbox 360 Arcade Console Logo
81 people viewed this question
Top SNK Video Game Consoles & Games Experts
James Wishart
Are you a SNK Video Game Console and Game Expert? Answer questions, earn points and help others
