Question about Exercise & Fitness
Front roller spare part for Vitesse Treadmil
I'm looking for a front roller for my Vitesse Extreme Motion Treadmill, which I bought from UK Sports Imports. They have stopped selling this treadmill & they don't keep spare parts of this model any more. Can any body help?
I'm looking for a manual for the same treadmill can you help.
Posted on Oct 11, 2011
    President:
  • 832 Answers
In most cases when a product is discontinued and manufacturer no longer has parts and depending on the age of the unit it will be very difficult to find parts in some case I have even gone to their vendors and come to find out that they made certain components obsolete. The only other thing I can suggest is that you take that front roller to a machine shop and if the bearings are the problem they should be able to replace them at somewhat minimal cost but . Good Luck
Posted on May 14, 2010
Hesitation in belt when running
Mine did this, I just bought a new drive roller...still trying to figure out how to get the old one out.
You can pull the hood off the front of the treadmill. On the left side of the front roller, you'll see a thicker part on the roller. If you paint a little nail polish or whiteout on both the raised part and the roller, then try run the treadmill and get it to do the hesitation thing again. Once it does, take a look at the line you painted on the roller. If its separated, you need to replace the roller.
Apr 29, 2014 | Exercise & Fitness
How do you reinstall the drive belt on a T6.3 treadmill?
  1. Remove the drive belt
  2. Loosen rear roller screws
  3. Remove the screw holding the front roller
  4. Slip out the roller
  5. Slip on drive belt
  6. Put back together in reverse order
Dec 29, 2013 | Nordic Track NordicTrack T6.3 Treadmill
Ifit com treadmill
Could be one of three things.
  1. Drive belt loose or worn
  2. Walking belt loose or worn
  3. Front roller pulley separated from shaft.
Go here to get the roller repaired if thats the problem.
Dec 27, 2013 | Exercise & Fitness
Vitesse endurace xt front roller rubber balloned
see the video and fix it . LUBE the rollers bearings too.
God bless you
Jan 09, 2013 | Exercise & Fitness
I need to replace a cracked deck and worn belt. I need the instructions on how to do these things.
1st take side rails off front hood .you have afront roller and a back roller. for the front take out the two or one bolts holding the the roller in placenow the back roller take out the bolts that hold the roller in place . now on the deck there is 3or 4 screwson each side holding the deck in place. slide w/ belt off put on new deck.install screws, rollers ,bolts.. now center w/belt and adjust tention on w/belt
Feb 28, 2011 | Cardiozone Supersport Hr Club Commercial...
When I power up my treadmil the belt does not move. If I step on the side the belt would then start to move until I move my foot.
In order of most likely cause. 1) Worn motor belt needs to be changed. Rear roller bolts need to be tightened as the walking belt has too much slack(2-3 inches lift on the edge of the belt in the middle on each side) 3) the nylon pulley on the front roller is slipping and a new roller is needed.
Oct 03, 2010 | Reebok 8050 ES Treadmill
CONVEYOR BELT NOT MOVING ON THE IMAGE TREADMILL
This could be because the belt on the motor that turns the belt you walk on is worn out. it has grooves on this belt that must be prominant to stay in the groves on the front roller and motor. The motor belt can be ordered for about 20$ shipped on ebay the motor belt number is 118016 this is a universal belt and fits this treadmil. Before buying the replacement belt check to see if this is for sure your problem. you can tell by opening the front of your treadmill and looking at the belt. You will see worn spots on the motor belt, or as I noticed when mine went bad, it will look like someone threw a bunch of rubber eracer shavings in your treadmill.
Aug 16, 2010 | RTO Image 15.0R Treadmill Walking Belt
Sportart 6310 treadmill - check speed sensor
Unplug unit and check the motor brushes they maybe worn and need to be replaced call Sports Art Fitness customer service @ 1-866-709-1750 they will sell you the brushes
Mar 13, 2010 | Sportsart 6300 Treadmill
Proform Crosswalk Dual Motion Cross Trainer Treadmill. motor works great. Rubber on right side under the moving belt has come off so belt slips when in use
I think you are talking about the front roller. It has a rubber sleeve that helps to grip the walking belt. Sometimes you can tighten this enough to keep it from slipping but you run the risk of overtightening and damaging both rollers. We recomend replacing that roller.
Oct 24, 2009 | Proform Crosswalk 500 Treadmill
Squeaking when i run on nordic track 5100r
My treadmill (American Motion Fitness) squeaks when only when  it warms up. I spray CRC oil onto the front roller bolts which bolt it to the swivel housing and onto the bolts which bolt the swivel housing onto the main frame also onto the rubber bushings which allow the front roller to bounce every time my foot hits the deck. I seem to have to do this 1 per week but it is easy to get at and takes 2 minutes. cheers johnO
Apr 29, 2009 | Nordic Track Nordictrack Apex 4100i...
Exercise & Fitness Logo
97 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
