Question about Epic 425 Mx Treadmill EPTL88105 !
Belt will not start up and move.
The unit will start up and the console lights up, the incline will raise, but when the start button is push to activate the belt nothing...
    President:
  • Epic Master
  • 832 Answers
The single most cause of no motor output is failure of the DC motor control. Look for any test lights on the power boards beneath the motor hood. Use caution when removing the motor hood because you may still have electricity ( capacitors are charged) in the motor area even if the treadmill is unplugged.
If you have a multimeter, you can test to make sure you have DC output from the controller spades ( Drive Motor Connectors) by clipping on them and then pressing the start key you should have a DC voltage reading if not the controller board is defective.
The motor can be tested by using a simple DC cordless drill or lantern battery this will turn the motor if the motor is good the controller board will need replacement , if not their won't be any belt moment the problem is the motor then the motor will need to be replaced. ( if you don' t have a multi meter this method of testing simple and easy)
Posted on May 17, 2010
I have a Proform 1026 EXP treadmill that began running at full speed whenever it is turned on. The incline controls function normally but the belt speed is incredibly high. When set to 1.5 MPH (the slowest...
please run the Software calibration see the instruction.
GOD BLESS you
The Steps for Newer Style Console Calibration
1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10. Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Sep 18, 2013 | Proform 1026 Exp Treadmill Motor Control...
Enginerring mode not working
follow the next steps and fix it.God bless you
15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Jun 28, 2013 | Exercise & Fitness
Incline position stuck fully raised.
lube the rack and pinion, and adjust the small POT. see the diagram attached.However RUN the software calibration for easy troubleshooting and fix it. God bless you
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif
Apr 04, 2013 | Exercise & Fitness
X9i incline trainer clicking
Step 1:
RUN the calibration software . and fix it. God bless you
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Step 2:
Feb 07, 2013 | Nordic Track Incline Trainer X9i...
PaceMaster Bronze Basic err 119
Run the software calibration for easy diagnose, and troubleshooting see the steps. and Block diagram
God bless you
Jan 14, 2013 | PaceMaster Bronze Basic Treadmill
Tempo 621T treadmill incline Incline reads 0.0 but is not all the way down. How to bring it down.
you must RUN the software calibration, for troubleshooting and fix it.
See the steps.
The Steps fhor Newer Style Console Calibration:
    1. F" appeared in). Troubleshooting the failure would be the next step.
Jan 09, 2013 | Exercise & Fitness
Tempo 621T treadmill stuck in incline postion scale is reading 0 but it is not completely down..How to reset my incline button
Run the software calibration for troubleshooting and fix it. See the next steps. God bless you
Lube the elevation motor, shaft and gear. adjust the POTentiomer,
Milestone 1200 series
RUN the software calibration see the steps.
However lube+clean the elevation motor, shaft and gear, and adjust the small POTentiomenter for fix it.
God bless you
Treadmill wont speed up
RUN the software calibration for diagnose, and fix it.
God bless you
The Steps for Newer Style Console Calibration:
Jan 06, 2013 | Exercise & Fitness
How do you recalibrate A2050 incline
Sep 06, 2011 | Nordic Track NordicTrack Treadmill, A2550
Epic 425 Mx Treadmill EPTL88105 ! Logo
383 people viewed this question
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Colin Stickland
Colin Stickland
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
