Ideal isar 30 he making noise when going too low falme checked condensate trap replaced pcb n fan still noisy when on low flame
  • Heating & Co... Master
  • 3,238 Answers
. is the flame detection probe or its wiring harness, this sits right on the heat ex and over time melts and sticks to the heat ex so looses continuty.
To check if the detection probes faulty, get a multimeter pull the wiring off the probe stick one end of multimeter on probe connection, other end to the wiring plug, set your multimeter to mirco volts. fire boiler up. you want more than 1.5MV's or probes is knakered! Check continuity of wiring, also check wiring is full pushed in to the white molex connector too.
Posted on May 14, 2010
Ideal icos 18 fault code HF
According to pages 47-50 of the install guide, section on FAULT FINDING, the alternating H and F indicates Flame Detection Short Circuit Error. Actions are: Remove flame detection electrode terminal from PCB. Test for continuity between 2 terminal pins? If YES, replace flame detection electrode. If NO, replace PCB. If you need more diagrams and full guide go to http://idealboilers.com/installer/wp-content/uploads/sites/2/2013/08/203318_inst.pdf
May 19, 2014 | Water Heaters
Ideal mexico boiler HE 36
Check Gas Pressure, make sure you have correct pressure.
Apr 06, 2014 | Water Heaters
Baxi he 24 solo. Local Gas safe Engineer has replaced pcb, condensate trap, overheat and other thermostat, also igniter/sparker and flame failure sensor, Boiler still intermittently locking out (red...
Sounds like its an intermittent flame failure on trial for ignition. Look for the pilot flame drifting away from the sensor when the main valve opens.
Nov 24, 2013 | Heating & Cooling
Baxi boiler
Make sure the gas inlet & outlet pressures are correct (manometer) & that the primary air mixture is adjusted correctly. Check to make sure you have 1 square inch of outside air for combustion per 2000 BTU's rating on the boiler.
Do I need a new fridge
Check for air flow, clean the coils. May need a new condenser fan.
Jul 28, 2013 | Refrigerators
MY IDEAL LOGIC 30 HAS FAULT CODE L2 ALMOST EVERY DAY SINCE INSTALATION DEC 2010
is boiler still under warranty?
normal warranty lasts at least 2 years
if so get ideal to send one of their engineers out
L2 relates to flame failure
either boiler has failed to ignite
or
boiler has not detected flame once lit
several causes
failure to ignite
ignition electrode/spark generator
failure to detect lit flame
detection electrode/detection lead
blocked condensate pipe
or defective condensate syphonic trap
you really need an engineer to check these components
Mar 16, 2011 | Heating & Cooling
Boiler keeps blowing fuses in pcb ideal isar he 30
The model # you listed is for a vent-free, natural gas, space heater and requires no electricity to operate. Unless, you have the optional blower. If the blower accessory is what's blowing the fuses, there is a short in wiring to the blower motor. Other than that, there is nothing else about this heater, that would be blowing fuses.
Is the above, the problem you're having? If so, unplug the blower from the wall outlet, until it can be repaired or replaced. The heater will continue to operate and heat with out the blower.
For more information about your heater, go to the link below.
http://www.desatech.com/manuals/Vent-Free%20Heaters/107882-01.pdf
Mar 04, 2011 | Desa International CBN30T Central Heating...
Fan very noisy
It is unusual for fans to become noisy buy with the power off you can check to see if it the fan has something trapped in it - in which case remove it. Also check to see if there is any blade damage. Check to make sure it is securely fastened and if not tighten the screws / bolts that secure it. Spin the blades with your finger to see if it makes any noise, wobbles or is difficult to move. If so then it may need replacing. Make sure the blades do not protrude out of the casing - if so push down on the centre of the blade to see if it will go back into position. The power to the fan may be unregulated so the fan may change speed and effectively pulse and therefore change pitch – check the supply voltage and ripple content. Other than that the fan may just need replacing.
Nov 13, 2009 | Sony PFM-42B2 42 in. Plasma HDTV
DRYER IS MAKING A CONSISTENT BANGING NOISE WHEN RUNNING. DRUM IS TURNING AND DRYER DOES DRY OK.
There are several things that can cause a dryer to be noisy. There are a lot of moving parts in a dryer that can cause noises to occur when they get worn. Several parts support the drum, and may make noise or vibrations when worn out. Many times a dryer will squeak just a little bit as it first starts. This should go away in just a few seconds. Make sure nothing is loose inside the drum. Remove the lint trap and look below the lint trap holder for any loose items that may have slipped through the cracks. The blower wheel is always moving and lint is constantly going by it. If it’s noisy, it may have gotten clogged with lint, or it may be worn and need to be replaced. Clean out the area around the blower. If it’s still noisy, replace it.
Many dryers use a center spindle to support the clothes drum. This spindle may be a ball-and-socket support, or it may be a shaft inside a sleeve. When these component bearings get worn out, they may make a squealing or rubbing sound. Replace this bearing when it gets worn out. Many dryers also use plastic glides in the front end of the clothes drum. When these glides are worn out, you may hear a lot of noise. If the glides are worn, replace them as a set.
Some dryers use rollers to support the clothes drum. If these rollers or wheels are worn out, they can be extremely noisy. You ought to replace the whole set at the same time. A belt that has been damaged or frayed may make a thumping or slapping sound as the drum turns.
The gas valve solenoid will make a buzz type of sound as it opens. The valve itself will give a little click as it starts the heat cycle, when ignition begins, and when the burner is turning off. The burner flame itself makes kind of a low-pitched roaring wind sound.
Thanks for using Fixya.
May 28, 2009 | Frigidaire Dryers
Blank display on ideal isar 2 he 30
may just be a defective display PCB, byt more often than not, its the more expensive main primary PCB. Ideal actualy modified this PCB, and has a pre-fix of VF on it, and is orange in colour
Feb 18, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
127 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
