Question about Maytag Dryers
My dryer stops running after a few minutes. The fuse has been replaced and the repair man replaced the motor and it stills runs for a few minutes then stops. HELP!
  • 494 Answers
Did you clean it out too? Check the venting for clog behind dryer or at the vent cap? Is the house breaker clicking off? Is the dryer motor humming or just stopping? Does it restart every time you try or do you have to let it cool down for a bit to restart? Need more info to be sure. You may have a bad sensor, but you'll need a repairman to check that.
Posted on May 15, 2010
I have a DV42H5400 dryer less than a year old that runs for a few seconds than stops. No error code but the cooling light flashes. After a few minutes it repeats the process.
Clothes Dryer Stops and Starts ' HomeTips
www.hometips.com/repair-fix/clothes-dryer-stops-and-starts.html
Apr 23, 2015 - The dryer's heating element works and the motor runs smoothly, But it... and then running the dryer with nothing inside for a few minutes-if it ...
Sep 26, 2015 | Dryers
Troubleshoot kenmore dryer
When I had the same problem I had to replace the dryer drive motor. The non replaceable thermo switch built into the motor is what kept stopping the dryer motor. On line videos were very helpful regarding changing the motor. I'd advise watching a few if you've never changed the motor before. The motor has a double ended shaft. One end drives the dryer. You probably saw that. Thing is inside the back of the dryer the other end drives the fan. Be very careful removing the back fan blade, it's plastic and not easy to remove without breaking it.LOOK FOR A VIDEO SHOWING THE FAN REMOVAL.
Feb 21, 2018 | Dryers
Maytag med5740tq0 that shuts off after running a few minutes. It runs fine and heats up, but then shuts off after a few minutes. If I hold the start button in it will run until I release it. After...
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse (part#7 in this picture). When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair.It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test the fuse for continuity before replacing, if the fuse is fine then check the thermostat (part#8) and thermal cut off (part#9) in the above picture. Please get back to me if you have any other questions.
Kevin
Apr 27, 2011 | Maytag Dryers
Have had a repair man out 3 times. Replaced igniter and gas regulator. Dryer will heat for a few minutes then stop heating. When I try to turn it back on, it will not turn on at all for about 10 minutes.
Are you saying the dryer will not start again after a few minutes? That is a motor [problem. Replace motor.
Are you saying dryer starts after a few minutes but will not heat? That is an air flow problem or a gas valve coil problem. Thoroughly clean EVERY single air passage in the dryer and vent tube. If that does not cure it, then replace gas valve coils if the igniter comes on and off.
Jul 02, 2010 | GE DCVH515GF Gas Dryer
Kenmore Dryer Mod. #110.68932792 Ser. MJ1907445 Dryer in heat cycle starts and runs 10 to 15 minutes then motor stops, after about 2 minutes motor starts back on it's own, operator doesn't have to do...
there is a motor relay in the consol part 3405281,there is also a heat relay too,you can swap em out to see if this is the problem, the one on right side with blue wires is the motor relay let me know how you make out
Nov 19, 2009 | Kenmore Dryers
Whirlpool dryer
If your dryer stops during its cycle, wait ten minutes and start dryer again. If dryer starts, then the motor was overheating.
Solution, Check for lint blockage around the motor and for possible overloading. If dryer repeatedly stops during its cycle, especially during consecutive loads, replace motor.
Good luck
Aug 10, 2008 | Whirlpool LER5636P Electric Dryer
Dryer shuts off when releasing start button. Will run while pressing down start button, but no heat is generated. Sears repair man wanted to replace Even Heat Control Board for $350. I bought the part...
replace the motor, as you are holding in the start button you are making the dryer run in the start winding of the motor, it is designed to only stay in this winding untill the centrifigual switch on the motor automaticaily switches it to the run winding, when the motor switch knows that it is using the run winding it closes the motor switch contact for the heater to come on, replace the motor
Apr 12, 2008 | Kenmore 63942 Dryer
No heat
mcwilliams if you pull the over off the front of the dryer at the bottom you can see the gas burner assy. Put the dryer on time dry and start the dryer, you should see a glow from the ignitor, then hear a click, then the heat come on. In the auto dry mode, the timer advances along with the dryness level. No heat, No timer advancing. If you don't see a glow, there should be a thermosat on the heater can, see if it is tripped. If so if it is resetable, reset then try again. You may have a bad ignitor.
Feb 03, 2008 | Estate TGDX640JQ Gas Dryer
Dryers Logo
366 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
