Pavilion desktop to sharp aquos pc input
I hooked my computer to my tv,but the tv says incompatible signal. What do i need to do?
  • Chris M
    Chris M May 11, 2010
    Are you using S-Video output on your computer or?
    Sergeant:
    Champion:
  • 293 Answers
What type of cable you are using?
do you have video card in your PC?
* lower the resolution on your PC and connect the TV.
Posted on Mar 30, 2008
SOURCE:
My SHARP AQUOS TV is displaying "an incompatible video signal has been received" for my Bell FIBE TV box.
Might try posting your question to the correct category. This is for sewing machines.
Mar 22, 2018 | Sewing Machines
I have a Sharp LCD TV and a Toshiba Satelite laptop. I have never had any problems connecting my laptop to the tv using a vga cable. It isn't working anymore however. I checked the cables and...
I would check the video setting on your laptop. The resolution or refresh rate might have been changed and the LCD TV might not be able to process the signal. Try changing the laptop's resolution to the lowest setting(right-click on desktop and pick properties) and see if the TV produces a picture. Also verify the video output on the laptop is working by hooking it up to a computer monitor if available.
Jan 09, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How do i unlock inputs 1 2 and 3?
As soon as TV detects signal on input 1, 2 or 3 it will make an input selectable. Supply signal first then select an INPUT. In other words, something has to be hooked up to those inputs before you can select them.
Jan 05, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Will not show picture from PC. When we use the computer with this tv, it says singal incompatible
Since the unit does not have a DVI input, you must use one of the HDMI inputs and the pixel ratio resolution should work at 1280x720.
If it does not work, the Main Board will probably need to be replaced. If needed, call Sharp Customer help line at 1800BESHARP.
Hope this helps,
Skyassoc
Oct 21, 2009 | Sharp Aquos LC-32D40U Television
Sharp Aquos 40lcd will not play bluray
You need to change the resolution on the Blu-ray to 720P to match the Tv native resolution.
Jun 26, 2009 | Televison & Video
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Incompatible video signal has been recieved
I just had the same problem and it turned out to be the HDMI cable.
Apr 08, 2009 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Trying to connect a sharp aquos lcc3234u tv to pc using hdmi
it sounds like your computer isnt set up to send the signal out. try right clicking on your desktop and selecting a dual monitor setting. It should be found under graphics options or something similar.
Jan 24, 2009 | Televison & Video
My Sharp Aquos 46" LCD
Digital inputs on Aquos TV's are "always on," usually the HDMI inputs and DVI inputs. As opposed to analog inputs 1, 2, or 3, are only activated once something is plugged in.
Try plugging in another HDMI sources into input4 or 5, if its still not working, the TV needs a new Main Board. Try calling Sharp 1-800-237-4277 and locating a local service center in your area.
Mar 14, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
HP Blackbird PC Connection 'Incompatible Signal'
You may have the wrong type of DVI, I would try a different cable to hook it up with.
Jan 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Computers & Internet Logo
112 people viewed this question
Ekse
Alun Cox
