Question about Garden
My Stihl BR320 will run only with the choke fully on & won't rev up(with or without the air filter). I've checked the spark plug & not touched the high/low carburetor screws. Any suggestions? Rich
  • 63 Answers
Adjust the carb. the fuel air mixture is messed up. try adjusting both screws to the right
Posted on Jun 28, 2010
Stihl fs 80 trimmer, replaced carb, air filter, spark plug, ignition coil. still doesn't start. Next? not getting spark from plug
Loosen coil screws, adjust coil to magneto flywheel magnets with a double sheet of common paper, tighten screws, so that paper will pull out without tearing. That will give you the best chance for a good spark, with all you have done. Pull spark plug out , put top of plug back in spark boot.......crank ovr with rope, and ground spark plug on top of motor(metal), observe the blue spark. If none, check the short wires for any breaks from coil to switch. You can open handle and take out switch, if nothing else works.....then try and start. The wires are just to break the ground, to turn off motor. Can choke motor to stop.
Jul 29, 2016 | Stihl Garden
Will fire,wont stay running.wants to be full choked,open choke,it dies
Jerry, First thing to get is a new plug gaped correctly and try. Could need carb. adjustment, fuel filter replaced, bad fuel line(cracked/pinched), Dirt/faulty diaphragm in carb. plugged spark arrester in muffler,etc.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://answers.yahoo.com/question/index?qid=20090528073906AA0y882
Chainsaw will only run with choke
Stihl Chainsaw starts but won run
http://tekindoor.com/miscellaneous/stihl-chainsaw-troubleshooting
May 28, 2016 | Garden
My stihl whipper snipper loses power and cuts out when i try to rev and apply throttle.
With 2 strokes I always start with 'AIR' 'FUEL' 'SPARK' from the sounds of it the choke might be stuck on (choking the motor ha ha) also check the air filter, You have fuel and its moving through but the fuel filter might be slightly clogged. As its starting and going on low your spark unit is ok but you might need a new spark plug.
Dec 21, 2015 | Stihl Garden
Briggs Stratton 5hp I/C starts ok, runs, but will not rev
My money is on a partial blockage of the main jet or the passageway to it. You're having to force it to run through the idle jet by fully choking the incoming air. There's not enough gas coming in with the choke open to allow it to run.
I'm thiniking total carb disassembly, carb cleaner and an air compressor combined with a ton of patience will take care of the issue.
Mar 31, 2015 | Briggs & Stratton Briggs Stratton...
Stijl brush cutter spark plug gap
buy a new sparkplug
dont bother with the gap
if it wont run its usually fuel related
prob a leef in the tank or a blocked filter or carborator jet
Mar 06, 2014 | Stihl Br420, Br400, Br340, Br320 Back Pack...
Stihl brushcutter [four stroke] wont rev.
Check the valve clearances, remove the rocker cover to expose the tappets. Adjustment tools can be bought online or from your local dealer.
Jun 18, 2012 | Stihl String Trimmer Brushcutter Service...
Stihl BR600 leaf blower starts but won't make any power. This blower was bought brand new in 2009 I think. I haven't really done anything to it and it has always ran great. I have always used the...
Check the air filter and clean or replace if needed. Clean or replace the spark plug. Check the in-tank filter as well (located in the tank attached to a freely moving fuel line) Also, the Stihl 2-stroke machines have a spark arrestor screen located at the outflow port of the muffler, either in the form of a bolt nozzle, or screen plate. Remove that screen and clean it or replace it if its dirty. Clogged exaust is a typical problem! All of these things are VERY easy to do, good luck!
Sep 26, 2011 | Garden
Stihl fs-46 string trimmer wil staqrt and run(idle) but will not run high rpm or accelerate. Cleaned out carb and checked spark plug already. Grog
2 things to check firstly run it without the carb foam filter see if it revs then and secondly thin gas mixture by half for testing see if that has any effect. You are basically testing fuel mix ratio and testing that it is receiving enough air.
Jul 04, 2011 | Garden
Will start with some amonut of choke on, but will ...
Carby carby carby!
Give the carby a flush with some Carby Cleaner. (retail 400g aerosol can)
Check condition and clamping of inlet manifold for cracks, warping or air leaks.
Reset Slide Needle one notch down.
Turn air mixture screw fully in and back out one and one half turns and try idling now.
When you get engine idling turn the air mixture screw in or out to the highest revs without use of throttle. Reset idle to optimum speed with throttle stop or idle screw.
Cheers.
May 19, 2010 | 2001 Yamaha SR 125
Garden Logo
318 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
