Question about Sony STR-DE375 Receiver
"Protect" First off i had the hardest time looking for the fuse that your suppose to use considering its "outdated" which is 4a 125v.... Right?? Anyways I put in a new fuse and it will turn on which is great but 2 seconds later... it flashes protect. It is in good condition and has worked for me for 4 years, then the fuse blew and now I'm lost.
  • 1 more comment
  • Mitcheal French Mar 30, 2008
    Here is a Video of the situation
    http://ca.youtube.com/watch?v=E8WzwYeBKg...
    Solution #1
    posted on Apr 01, 2006
    shawnboy
    Rank: Apprentice
    Rating: 85%, 55 votes
    shawn... indicated that his solution for
    STR-DE345 5.1... Problem
    is valid for all Receivers
    check to see if you put the correct fuse in the receiver, and if it is the correct one, you will need to check the protection circuit because with it being turned up so loud the amp was probably damaged. in most cases with protection circuits you will probably find your problem with an output transister. than check for blown caps.
    sorry but I'm a little illiterate when it comes to technical terms... So what am I looking for? where is the protection circuit? how do I know if something is wrong with it? same with the output transister and the caps? Thanks !! : )
  • Mitcheal French Apr 07, 2008
    I don't mean to be rude but can someone translate that?
    Thanks!! :D
    Genius:
  • Sony Master
  • 1,550 Answers
El circuito amplificador de audio esta dañado o dañados si trae mas de uno.
Posted on Apr 04, 2008
Had a blown fuse on main board 125V 4A replaced and indicator came on green light flahes twice and goes off
Something else went when the fuse blew---voltage checks are needed and someone needs to check for shorts on the set to ground.
Apr 02, 2012 | Televison & Video
It keeps blowing the 4A-125V fuse every time I plug it in...
There is something shorted in the system. often it is the audio output which fails especially if it is run at high volume levels. Unless you are trained in electronics, I suggest you find a repair shop that repairs audio equipment. (Sorry) Hope this helps
Jan 03, 2011 | JVC MX-D602T Shelf System
I plugged it into 220V outlet and Brother HL 2140 only accepted 110-120V. Is there a fuse somewhere I can access and replace? THank you.
hi. I had the same problem and to fix it you need to take printers right-side cover off. Underneath you'll find a Power Supply Board - hidden under metal cover. Take it out and disconnect two cables from it. Now, I had to replace an fuse 125V 4A and varistor E241AD 83P on the Power Supply Board in mine HL-2140. It works fine now.
Note: I could not find the exact replacements in electronic store so I used:
- fuse: 250V 4A
- varistor: FNR 10K241 (241 is the important number)
Hope it helps.
Oct 28, 2010 | Brother HL 2140 Laser Printer
I have a Brother HL2140. It was plugged into a 220v outlet, is there a fuse that can be replaced?
- fuse: 250V 4A
Hope it helps.
Oct 15, 2010 | Office Equipment & Supplies
4a/125v fuse blows every time I plug the TV in.
the smps needs repair.the primary circuit is shorted.stop the game with the fuses and contact the service! dont mess with the board of the smps. the voltage there is at least 200v dc and the current is strong enough to kill somebody!
May 04, 2010 | Sylvania LC320SL8 Television
Pioneer sd-643hd5 fuse issue
The fuses may not be your problem--I have fixed several of these---The large power board is on the right side as you look from the back?
Lots of these sets develop bad solder connections on that board--several sites on the internet offer to have you remove and send them the board to resolder--this set used lead free solder and after some years has problems--a few I have opened had clearly broken solder joints--I usually in this case remove the board(mark all the many plugs and make a diagram) and solder almost all of it by hand----usually fixes this kind of trouble.
I do this here for free so if this information was helpful give me a vote here....I am here to help people.
If you have any questions or need advice reply to this posting here.
SD TECH
Sep 12, 2009 | Pioneer SD-643HD5 64" Rear Projection...
JBL will not come on
yes, there's 2 fusen inside near the power supply.
Jul 09, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Sanyo tv blows fuse when you turn it on
u have a short in the power supply section
Oct 24, 2007 | RCA F27242GY 27" TV
Mitsubishi ws 55513 rear projection HDTV
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT
Aug 10, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Sony STR-DE375 Receiver Logo
255 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
