Question about Frigidaire FRS26R4A Side by Side Refrigerator
Have a fridiare fidge( how safe t odrin is hte
Have a fridgidaire fridge(how safe is the water that comes through the hose in the back of fridge (10years old) has a water filter in fridge . Would the water be bad to drink after going thru that same small plastic
hose after 10 years?
  • 51 Answers
Well if your worriedabout you could replace it or if there was some way to get vinager to go thru it this clean it out and it's safe for you
Posted on May 14, 2010
Why do I have warm water coming out of my new Fridgidaire french door style fridge
Check to see if the supply line coming into the unit from the rear is not near the compressor. The heat from the compressor will make the water hot.
Oct 17, 2012 | Electrolux EI26SS55GS Stainless Steel ...
Water is not getting into the washing machine. Fridgidaire Crown series. Water is coming through the hoses. Detatched hose from washer, water still comes out. Cleaned screen on back of washer. No...
Hi. sounds like the pressure system is blocked if it goes through a cycle with no water. Find the pressure switch in the top of the machine its the size of a small coffee jar lid, it has wires and a thin rubber pipe to it, pull the pipe off and see if the switch clicks as you do so. If it does you need to follow the pipe, at the end it goes to the pressure chamber.It will be blocked with gunge and will need cleaning out, also blow through the pipe to make sure thats clear. Make sure you fit the pipe back with no air leaks or the machine will over fill and flood.If you don't feel confident in doing this Please call an engineer.Best to be safe, it could also have damaged the heater or thermal cutout
Regards Elect App
Jul 14, 2011 | Washing Machines
Hi, i noticed water coming from the back of my fridgidaire fridge model ftr81sgh
sounds like a frozen water inlet to ice maker . needs too be defrosted and may need a water valve as it may not be shutting of completly .mm
Aug 10, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
We have an rca fidge in which we think the defrosting thermostat is blown and we need a new one. b/c the fidge is not cooling and the freezer is freezing. unfortunately stores are saying they do not carry...
1ST OPEN FREEZER DOOR AND HOLD THE DOOR BUTTON IN WITH THE DOOR COMPLETELY OPEN UNTIL YOU HEAR THE FAN RUNNING, MAYBE 5 TO 10 MIN. THE FAN SHOULD RUN FAST NOT SLOW. WHEN YOU HEAR THE FAN RUN FAST YOU KNOW IT IS WORKING PROPERLY. IF IT RUNS SLOW CHANGE FAN MOTOR.
CHECK FOR CLOGGED DRAIN HOLE AND BLOCKED AIR FLOW DUCT IN THE TOP PART OF THE FREEZER. IF THIS IS BLOCKED WITH ICE DEFROST WITH HOT WATER UNTIL BLOCKAGE IS REMOVED. IF THE FAN IS RUNNING PROPERLY, AND ALL IS CLEAR THEN THE AIR WILL FLOW DOWN TO THE FRIDGE. ALSO MAKE SURE YOUR FREEZER IS NOT JAMMED FULL OF FOOD AND THAT ALL VENTS ARE CLEAR OF OBSTRUCTIONS. SET YOUR DIALS ON THE PROPER SETTTING. IT TAKES ABOUT 24 HRS. TO ADJUST. IF DEFROST WAS BAD IT WOULD NOT BE COOL UP TOP.
THE DEFROST OR THERMOSTAT CONTROLS THE TIMING OF DEFROST MODE WHICH IF BAD THE COMPRESSOR WOULD NOT WORK AND THUS NOT COOL AT ALL.
TO ANSWER YOUR QUESTION ABOUT WHAT BRAND TO USE CALL A COMPANY NAMED WILMAR OR HOME DEPOT SUPPLY, TELL THEM THE PART # IF YOU WANT TO REPLACE YOUR THERMOSTAT AND THEY CAN TELL YOU WHAT ONE YOU CAN USE WIT YOUR RCA..I'M PRETTY SURE YOU CAN USE FRIDGIDAIRE OR GE HOT POINT WITH MINOR IF ANY ALTERATIONS. TRY WHAT I SUGGESTED 1ST BEFORE ATTEMPTING TO CHANGE THERMOSTAT OR FAN.
Apr 12, 2010 | Refrigerators
Water leaking from underneath. Not currently
This could be a blocked drain.Behind the fridge is a hose/pipe running from the inside of the fridge down to the compressor where the water will then evaporate.If this pipe is blocked,the water will push up back into the fridge.Try to blow the hose clean from inside the fridge.This should solve your problem.
Regards
Andre Nagel
Mar 13, 2010 | Freezers
Fridgidaire Defrost Water Pan
i found my drain tube was not draining into drain pan, but onto floor
May 13, 2009 | Frigidaire FRS26H5AS Side by Side...
Leaking water inside fridge
With mine I turned it off for 24 hours until totally defrosted. Checked behind the panel of the freezer and removed one stubborn piece of ice. When I restared the fridge it was all good. I have this problem when we have had a lot of humid weather.
Feb 22, 2009 | Fisher and Paykel Active Smart E522B...
Water coming straight through LG SxS fridge freezer
Most likely the pipes were disturbed a bit while remodeling, causing a particle to flow to the inlet water valve and prevent it from closing completely. You will probably have to replace the water valve part number 6877JB3053D (note, if you would have run a gallon water out the water supply tube prior to hooking the water line back up to the refrig. you would not have had this problem)
Nov 21, 2008 | LG LSC26905TT Side by Side Refrigerator
Ice Maker not working
water dispenser works but hte ice maker does not work
Dec 26, 2007 | KitchenAid KSRS25IL Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
62 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
