Question about SaniServ 501 Twist 22 Quart Ice Cream Maker
Sani serv repair service in houston - SaniServ 501 Twist 22 Quart Ice Cream Maker
Our Taylor soft serve ice cream machine model 142-12 is making a loud banging noise when turned on. Almost sounds like an uneven washing machine. Please help!!!
Phone: 416-266-2791 or 1-800-335-5018
Fax: 416-751-5691
Hours of Operation:
Mon - Fri 8am - 6pm
Saturday 9am - Noon
Sunday Closed
Equipment & Smallwares Sales: geoff@accurate-repairs.com
General Inquires: accu@accurate-repairs.com
Parts: paul@accurate-repairs.com
Address:
Accurate Repairs / Food Trade Service
763 Warden Ave. Unit 1
Toronto, ON
M1L 4B7
Jun 10, 2014 | Ice Cream Makers
Deni 5500 Scoop FactorySoft Serve Manual
Hi Marion: The Manual for the Deni 5540 Soft Serve Ice cream maker can be obtained from the Deni website:
http://www.deni.com/files/5540.pdf
The manual for what I presume is an earlier model, the 5500, is not posted. I expect if you send an inquiry via their Customer Service webform they would be happy to provide. See here:
http://www.deni.com/index.cfm?fuseaction=page.contactUs
Thank you for using FixYa!
Oct 21, 2011 | Ice Cream Makers
I have a Sani-Serve countertop soft serve ice cream machine. I do not have a manuel and I was wondering where I find the model and serial number on the machine. I need to replace the front cover that...
the model number should be on a plate on the back of machine,and you should be able to go to the sani serve web site to get manuel,I just downloaded one myself
Jun 10, 2010 | Ice Cream Makers
Where can I find a repair man for Taylor Frozen yogurt machine? I live in Los Angeles, CA zip code 90024.
Call toll free number 1-800-665-1125 or www.dslinc.com and they will tell you who you can get in your area. The name of the company who services Taylor is DSL
Apr 09, 2010 | Taylor 632-27 Ice Cream Maker
Machine won't come on
Check and see if all of the wires are on the freeze/cleanout switch. make sure the switch is in the freeze position. There is also a torque switch in back of the unit where the belt is,the belt tensioner engages and disengages this switch to control the viscosity of the mix in the barrel.check to make sure the metal arm of the switch hasnt been bent so far that it will not move, and that it does not have mix in it. Also check the voltage to the contactor coil. if you have correct voltage at the coil, then it is a bad contactor.
Jan 15, 2009 | SaniServ 401 20 Quart Ice Cream Maker
Taylor ice cream maker single serve
You can't. Taylor won't send you one unless you are a foactory trained technician. Sorry
Oct 19, 2008 | Taylor 632-33 Ice Cream Maker
Saniserv A 4071M
I have that machine and have the manual for it as i bought it new 8 months ago. I can copy and post for any who need it. Will post COD.
Mar 27, 2008 | SaniServ 407 10 Quart Ice Cream Maker
Opertational Manual for SaniServ 401 1A (20 Quart)
I called:
A Service Provider
(305) 279-9544 Office
but don't tell sani-serv. They are anti-DIY and will politely try not to help you.
Oct 13, 2007 | SaniServ 401 20 Quart Ice Cream Maker
SaniServ 501 Twist 22 Quart Ice Cream Maker Logo
56 people viewed this question
Top SaniServ Ice Cream Makers Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Are you a SaniServ Ice Cream Maker Expert? Answer questions, earn points and help others
