My laptop has really slowed down over the past couple of weeks. I have lots of stuff on my desktop, could this be the problem? Please help!
  • 4,281 Answers
For that press windows key+R key so you can see run then follow below.
(1)Type in run "%tmp%" without "' then press ok then you can see all temp files select all and delete all.
(2) Type in run "prefetch" without "" then delete all prefetch files.
Then type in run "chkdsk /r" without "" then press ok then press "y" then restart computer then it fix and recovers error on harddrive.
Also scan computer with updated antivirus.
Right click on my computer click on property click on advanced go to performance settings ->advanced click on "change" of virtual memory then click on set and custom size then set initial size to max size.
Then apply and ok restart computer for take effect then your computer get speed.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 14, 2010
  • Paddy Walsh May 15, 2010
    I did everything that you said and certainly once I'm logged in it is quicker. It takes about a minute to log in from putting in my user name - this seems quite slow. I will monitor performance over the next few days and drop you a note.
    Many thanks,
    Paddy
Slow download speed
Hi Mimi,
If you haven't checked to make sure your computer is free of malware, sometimes it can slow down your internet downloads. Here are a few programs I'd suggest you install and run:
  • ESET Online Scanner (scans from the web, will take a while)
  • SuperAntiSpyware (download and install)
  • Malwarebytes (download and install)
ESET will scan your computer this one time, and may take an hour or more. SAS and MWB will reside on your computer and can be run every couple weeks. Make sure you always run the updates before you scan with them.There are always a lot of things that can effect your Internet download speed.
Malware infection is just one of the common things that effects Internet Speed. Let us know a little more, like... did your connection recently slow down (used to be lot faster)? Is your computer slow overall? Or did this just start?
Jon : )
Jun 02, 2013 | HP Compaq Black 15.6" Presario cq57-339wm...
Tip
If your laptop is running slow and applications are taking a long time to load...
If your laptop is running slow and applications are taking a long time to load here are some tips that may help you solve your problem. Laptop computers are not much different than desktop PCs. They both require maintenance to keep them preforming the way they should.
First of all of if this is a recent problem that started after you’ve installed or uninstalled a program. Use your restore feature and go back to a previous state when you know your computer ran good. You will also want to update your antivirus software and run a full scan, the same with your spyware software.
Be sure to update the definitions on each program before you run your scans. You want to make sure your computer is free from any viruses or spyware as these will really slow your laptop down.
Unless you have a hardware problem like not enough memory or your hard drive is going bad.The biggest reason for laptops running slow is because of a corrupt registry. Especially if you are running Windows Vista. You may have found a lot of incompatible programs or software, and had to uninstall them. They leave behind invalid registry keys and orphaned entries.
You need to clean these out.
Your Windows registry is like a large database, all your software has to reference it when it loads to check for the correct settings. The same as when your computer starts up or shuts down. Your registry is a heart of your system. Any corrupt or damaged, registry entries will really slow down your operations.
Cleaning and maintaining your Windows registry is very important. It’s sort of like giving your computer a tuneup. Windows does not have a tool built in for you to do this with. So you’ll need to download a third-party software program for registry repair and cleaning.
You can edit and repair your registry manually, but it’s not recommended. Even experienced computer technicians have a hard time doing this. They all use software. Besides a few delete or alter the wrong file your computer may become unusable. Software that is made for registry repair is much safer and efficient. With a click of your mouse you can scan your entire computer in a couple of minutes. You can also make a backup and restore point before you make any changes just to be safe.
Depending on how much you use your laptop. You should preform weekly registry maintenance, of course, this applies to any other computer you own to. If you follow the tips above your laptop should not be running slow anymore.
The only other thing I can think of is if you upgraded your operating system to a newer version of Windows like Vista you may not have enough memory now. Memory upgrades have really come down in price lately, and are fairly easy to replace in a laptop.
on Jul 02, 2010 | Computers & Internet
Unit gets very hot within 5 minutes and slows graphics down to a crawl or crashes the machine.
I solved a really familiar problem 2 days before here at home.
The problem is, that your notebook gets really hot within minutes. As it gets to an exact temperature, the CPU first slos down, then shuts down, to prevent damage, and to cool down. If it's an "old" notebook (I mean at least 1,5 - 2 years old), then the thermal paste on the processor got dry, and it doesn't do its job anymore. You have to apply a new amount of thermal paste (BTW you really should do it at least once a year).
1. Turn the notebook upside down
2. Take out the screws from the biggest panel (must be next to the heat grille)
3. Take out the screws from the cooler of the CPU
4. There will be a lot of white stuff on the CPU, clean it VERY carefully (tissue with alcohol, but NOT brush)
5. Apply a little thermal paste on the CPU
6. Take the CPU cooler back, and take the screws back
7. Take the bottom panel bake, and take the screws back
Here is a tutorial of it: http://www.youtube.com/watch?v=g3Izxh7J44s
The other solution is to buy a notebook cooler: http://www.notebookcooler.info/media/ante-notebook-cooler-s.jpg
Hope I could help.
Dec 29, 2010 | Dell Latitude D620 Notebook
Very very slow machine
Before trying to reinstall this systm ste_fou, try these steps:
Turn off the pc
remove cables on the laptop or desktop
remove battery if it is a desktop
press and hold the power button for 5 seconds
reinsert the battery for laptops
reinsert cables on the pc
Turn on the system and check if it is slow...
Then that is the time for you to decide whether to reinstall the system or not...
May 15, 2010 | HP Computers & Internet
My windows are slow to go up and down... especially if the car is not in motion. Same is true for the wipers. They all go faster if the car is in motion. Have a new battery and the alternator tests...
I got some silicone spray and sprayed it around all the rubber edges of the window frame that the windows slide in, i had to do this a couple of times and to be honest i made a mess but after putting the windows down and back up about 5 times they worked like new.
Several opinions about this:
Silicon Spray
Guys dont use Silicon Spray - I tried it (expensive stuff) and the windows were great for couple of weeks, then they got really really bad, much worse than how it was originally. The problem is that gunk and dirt get into the silicon and get stuck in it.
It took me months to get rid of the silicon **** using detergent.
WD40
WD40 is too thin and wont last long. It can also affect the window tinting.
Carbon/Graphite Powder
This is the best stuff to use. Dust does not get caught in it.
It works instantly and lasts for weeks - depending on how worn down the window rails and rubber are. If the windows start to go slow again, just put some more in. I keep a bottle in my glove compartment. If it rains heavily, it can wash away the carbon though. But at least it wont seize up like silicon grease. I think this is what the factory does to new cars anyway.
For the last choice, visit Auto-One stores:
Its cheap - around $5 I think. You can get it from any auto shop such as Repco, AutoOne, etc..
Hope helped.
Feb 11, 2010 | 2003 Mitsubishi Diamante
Trouble shooting for dell inspiron 531,very slow to log on and log off,its takes about 10mins,I already deleted some of the files and downloads thinking that's the cause of it to slow down but it's still...
Here are a couple of articles you might find helpful.
http://www.microsoft.com/windowsxp/using/setup/expert/northrup_restoreperf.mspx
http://www.ccleaner.com/ - keeps stuff from bloating your system. Removes temp files, and orphaned registry entries. Very nice free program.
make sure your system is free of the nasties... use online virus scanner.
http://housecall.trendmicro.com/ - online virus scan, again free!
Please let me know if this helps. Good Luck!
Mar 03, 2009 | Dell Inspiron 531s Desktop Computer
My new desktop is so slow..........I want to throw it in the trash. (bought 6 weeks ago from Tiger direct.ca) Do you have a solution?
There can be a number of things that are slowing your computer down. First queston is, are you talking about it not running fast on the internet of in general running slow. I am going to take it your talking about it running slow over all. With new computers they (the maf.) but a lot of unecssary software in the "Start "", that really slows down the computer. I am going to tell you how to take care of this problem.
Go to Start-Run, when the winodw pops up type MSCONFIG (it looks like a lot of stuff, but's it only a teddy bear), go to the START UP TAB. You will see check markes next to all the software that is starting u and using a lot of system memory. Yo simple uncheck the ones you do not want to run at startup, now when you uncheck these the program will still run, but only when you tell it to,
When you have selected what programs you want to or do not want to run, Click on APPLY and then OK. The computr will restart and should begin to run faster.
When you have completed this, please let me know how it's working, and if still slower than you think it should be, then we will go to the nextstep.
Jack
Jun 13, 2008 | Acer Computers & Internet
Jumpy color changing screen with slow speed. Please HELP!
When booting your computer press (F8) And go to "Safe Mode" then when you are on your acount go to: Start>Run>type "msconfig" then go to "startup" And disable All then click apply and close then restart. Hope this helps you.
May 16, 2008 | Toshiba Satellite M45-S169 Notebook
Very..very slow ...
Hey,
I think there are lot of application that load at the time of startup and ecause of which your system is slow. To clean up startup items you can use MSCONFIG. this appoints you as a boss of your computer and you can select what programs should load and the ones that should be not allowed to load.
heres how you use this utility.
http://www.netsquirrel.com/msconfig/msconfig_xp.html
Do let me know if this helps.. :) best of luc...
Dec 20, 2007 | Toshiba Tecra A3 Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
