Question about Emerson EWL20D6 Television
DVD Player I bought my Emerson Flat Screen TV and DVD Combo about two years ago and lately I've been having problems with my DVD player. Originally it started out with my DVD player not recognizing DVD's right away but eventually it would work. Now when I put a DVD in it tries to read it and then immediatly spits it back out. It's exceedingly frustrating, is there anything I can do to fix this?
  • kaseen May 18, 2008
    not reading the dvd
    Scholar:
  • 42 Answers
Try a lens cleaner, the laser may be dirty and need to be cleaned. The best way to do it is to buy a lens cleaning dvd:
http://www.amazon.com/s/ref=nb_ss_gw/104-2547987-8787949?url=search-alias%3Daps&field-keywords=cleaner+dvd&x=0&y=0
Otherwise you can take a can of compressed air and spray it into the drive when the door is open, but that has just as much risk of putting more dirt on the lens as it does cleaning it off.
Posted on Mar 30, 2008
My friend took out the dvd player so the light stay on an when i tuurn it on it waits a sec then does red then green screen an goes to standby
The TV is indicating that a part of it is not working, like the dvd player that is missing. Modern electronics go through a set of tests and if a fault is found the stop working. Replace the dvd player, or get the set to a repair shop.
Apr 30, 2015 | Emerson LD190EM1 19 in. LCD TV/DVD Combo
Toshoba tv/dvd combo. won't play many dvd's. makes clicking sound as it tries to load movie?
Dear Lesley!
It looks, like your DVD lens might get contaminated with dust and/or dirt, which is being picked up off DVDs. Let's try to load music CD, instead or DVD. If it loads well, I will suggest, that your DVD player is at fault and you must give up using it. External basic DVD players are quite inexpensive and easy to connect to your TV. But: if no CD, nor DVD load, the solution might be much simpler: use lens cleaner CD with brushes. good ones might even have a special fluid, which applied to brushes(alcohol based). Just load it into your TV's player and follow audible directions. After couple attempts, your lens should be clean enough to play DVDs. Please, don't try to use any "ear swabs", instead. The lengths is not long enough, plus it may damage load mechanism or get stuck inside. I've seen such a cases lately.
Good luck,
Thank you,
Alex.
Dec 15, 2011 | Toshiba 32CV100U 32 in. TV/DVD Combo
Akai 32" wide screen lcd tv/dvd combo LCT3201AD
This may be an instance were the idea was great but the execution wasn't thought out. I've heard of several related problems that may be related. Both the TV and the DVD player tend to produce heat, not in great abundance, but together a sizable amount of heat. The power supply may have been ample for the TV at first but with the addition of the DVD player was not able to handle the extra load. If still under warranty you're all set. If not you might call Akai and see what they might be able to do for you.
Sep 29, 2011 | Akai LCT3201AD 32 in. LCD Television
I have an old emerson TV/VCR (Digital Tracking VHSHQ) The TV works fine, but when I put a tape in it is ejected and part of the tape stays inside, but can be pulled out.
Try a VHS Cleaning Tape Cassette. Follow it's instructions. If no better result it's not worth throwing away money on having repairs done but better put toward, if you can afford to, buying:
Option 1. A VHS/DVD player (combo as these are known) and plug that into the Emerson AV input.
Option Two: A VHS/DVD twin recorder combo deck - and plug that in.
Then start on copying any VHS tapes you cherish to DVD on this device.
Option Three: Forget the Emerson except for just using as a TV and buy a new TV with DVD player built in - the latest type of combo.
(I'm having to guess whether you've just used tapes to watch or record and watch)
Sep 26, 2011 | Televison & Video
19 inch slyvania tv/dvd combo turn on play button stays on and the the tv goes to red green yellow and blue screen and won't do anything else
I have been having just about the same problem with mine, i can watch the tv for about 20 min and then the dvd player comes on by itself then it goes to red, green, yellow, and black and white, i've tried resetting the dvd player to default but it hasn't helped mine.When i try to turn it off it automaticly comes back on so i have to unplug it.If i find a way to make mine work right i will send you a message to let you know so you can try it on yours. I've had mine just over a year and i don't have a warrenty anymore.
Aug 08, 2011 | Sylvania LD195SSX 19 in. LCD TV
Dvd polaroid tv/dvd combo tda-o3211c dvd stop
Not worth repairing,just get a seperate DVD player hook to the tv.It very cheap these day.
Dec 05, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Hello, im sorry i speak little english, but i have a 19" emerson tv combo lcd, its new i buy it 2 days ago, and now has a dvd inside, and wont eject, and dvd dont work, what can i do?
On the DVD player face, look for a small hole about the size of a paper clip wire. Push a paperclip or toothpick into the hole and see if the DVD opens up.
Jan 31, 2009 | Emerson EWL20D6 Television
Tried connecting DVD player to ILO 27 in, no go
go to video on your remote, then go to composite... it should work on composite mode. Took us a while, don't feel bad. Hope that works for you.
Nov 14, 2008 | iLO 3200 32 in. LCD Television
DVD doesnt work
Replace the laser on DVD player and that will resolve your problem. Todays lasers are not that reliable
Nov 29, 2007 | TruTech PLV16260 Television
Emerson EWL20D6 Television Logo
121 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
