Question about Toshiba Portege 2000 Notebook
Ethernet is not working. Enabled in BIOS. Device Manager says it is working. Known good cable and connection. No lights at ethernet port.
    Sergeant:
    Champion:
  • 389 Answers
Try updating the driver for it,iv run into this problem before and the device manager still would say its ok.Go to the tashiba web site and download the driver from there.
Posted on May 14, 2010
ETHERNET CABLE
You will have to open up your network connections.
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled.
Click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow Question / Exclamation mark ? ! or a Red X you will need to update/reinstall the driver for the device
You only need check the following if you cant install the driver
Make sure you Ethernet/internet is enabled in bios.
Restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press Enter make sure its enabled
then recheck the driveri t should be there
k the driver it should be there
make sure its enabledPci device arrows key scroll to nstalled
if you computer came with a motherboard disk the driver could be on it
or this disk provided by your ISP provider Internet Service Provider
or you might have to download one
http://download.cnet.com/wireless-atheros-ar5b91-7/3000-2112_4-202570.html
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
if these packages are not the right
http://download.cnet.com/2000-20_4.html
On the home page you should see a search tab just type in what you are looking for
tick in the box for windows software or all software box
IE: Motherboard name Wireless or Ethernet driver
you might have to try a few times to get it right
Jul 11, 2013 | Computers & Internet
How to fix orange blinking light on ethernet
orange blinking on ethernet means that your connection is 10 Mbps and green blinking means 100 Mbps
there's nothing wrong with it
Aug 27, 2012 | Toshiba Satellite M35X-S163 Notebook
Ethernet connection appears not to work, though Windows XP device manger says the device is ok
Try to use a known good ethernet cable. Check if lights at the ethernet card is lit up. check also on router if the indicator light will lit up when you connect the ethernet cable.
Mar 23, 2010 | Dell OptiPlex GX260 PC Desktop
Second computer connected to this model gives message "Network cable unplugged" when it is not! network connection intermittent. What can we do please?
Hi Jackie!
It sounds like a communication problem between the router and the computer. Try the following solutions to solve this:
1.Connect the LAN cable to other free LAN port in the router.
2. Try using a different LAN cable.
3. a. Open Device Manager
b. Go to Network adapters. Click on the "+" sign next to it.
c. Double-click on your network adapter.
d. On Advanced tab, look for Speed/duplex settings (or Media Type)
and change it's value to Full autonegotiation (or AutoSelect).
e. Click OK on all windows.
f. Close the Device Manager and restart your computer.
4. Reinstall or update your network adapter device drivers.
A "workaround" solution - use a wireless network adapter to connect wirelessly to the router.
Hope I helped,
Pelu.
Mar 16, 2010 | Belkin F5D7630uk4A Wireless Router
How can i connect a toshiba runniung windows me. to the internet via ethernet cable? is it possible with just the cable and no card? is there a programe i can download to help my laptop? what can i do?
It should have a LAN (network card) built in to the laptop.
First of all make sure you have the LAN (network drivers) installed. You can do this by checking in device manager.
To open device manager click Start, point to Settings, and then click Control Panel.
Double-click the System icon. Click the Device Manager tab and look in the list for network adapters/controllers.
If the driver is installed you should be able to directly connect the ethernet cable to your laptop.
I'm not quite sure where the ethernet port is on that particular laptop but it will be on the back or sides of the unit and it will be the only port the ethernet cable fits into.
From there you should be good to go, if you can't get a connection reset the modem by removing power from it for 2 minutes, connect the power again, wait another 2 minutes for the device to settle and try the internet connection again.
Regards.
Oct 01, 2009 | Toshiba Satellite 1715XCDS...
Ethernet port does not work in computer. The cable company set up a USB connection which worked, but now I installed a wireless router. The ethernet cable from the pc to the router does not show a...
Here are some things to check.
  1. In the system setup, ensure that the network adapter is enabled.
  2. Check device manager and see if the driver is properly installed.
  3. If the integrated NIC doesn't work, you can disable it in the BIOS and install a PCI NIC (Less than $20) and the system will work that way.
Sep 30, 2009 | Dell Dimension 3000 PC Desktop
My device manger says that the realtec RTL8168C is working properly. However, when I plug and ethernet wire into it, it does not light up, nor does the modem. I have replaced the modem and cables. I have...
You need to go into the BIOS and see if the LAN port had been disabled.
To do this restart your computer and hit the Del key, that will get you into the BIOS, look for On-board Devices and check that the LAN is enabled.
Good luck.
Aug 18, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
When i plug my ethernet cnnection into my Acer One notebook,it comes up as disconnected-how do i put this right?
it might be not working due to problem in driver of ethernet port.you can try to reinstall the driver from the cd which is provided by the company
Apr 21, 2009 | Acer Aspire One AOA110-1113 Netbook
Ethernet port not "active"
Hi there.
Restart the PC and go into the bios to make sure the on-board LAN is enabled, if it is try as jery says and try another ethernet cable.
Post back please and good luck
Apr 21, 2009 | Dell Latitude C400 Notebook
My dell computer suddenly is not connecting to the internet and is showing "network cable unplugged" error
  1. start the troubleshooting process by making sure that everything (routers,switches, hubs, modems, and computers) is firmlyplugged in.
  2. If your computer is on and the other end of the Ethernet cable isconnected to a network device, the link or activity LED should light.If the light remains dark after you plug in the cable, replace thecable. If replacing the cable gives the same result (no green light), then go to the next step.
  3. Once you’ve eliminated cabling as a source of the problem, it’s time tolook to your computer. Start by making sure that your computer is able toaccess your Ethernet card. A good tool for doing this, and subsequentnetwork troubleshooting, is the command prompt.
  4. Select Start, All Programs, Accessories, and then Command Prompt. When the Command Prompt window opens, type ipconfig –alland press ENTER. Various lines of information will display, dependingon how your system is configured. Look for a section labeled EthernetAdapter Local Area Connection. This section should include a linelabeled Description, which should be a description of your Ethernetcard. If you see it, then your computer knows about your Ethernet cardand has successfully loaded the necessary drivers. If the Descriptionline is blank or missing, you will need to reinstall the drivers foryour Ethernet card.
  5. Your Ethernet card doesn’t detect a connection to the Ethernet cable. Open a command prompt, type ipconfig –all,and press ENTER. If the section that starts with Ethernet adapter LocalArea Connection contains a line labeled Media, with a status of MediaDisconnected, then your computer is unable to detect that a link hasbeen made from your Ethernet card through the Ethernet cable to anothernetwork device, such as your computer or router. Recheck the cabling.Use a known good cable to connect your computer to a known good networkdevice and then perform the check again. If the status is still MediaDisconnected, and you are sure that the cable and the network devicethe cable connects to are good, then you may have a bad Ethernet card.Reinstall the Ethernet card. If the problem continues, you may need toreplace the card.
  6. Other things to check:
  7. Bad connection, bad cable, or wrong cable. The ports on arouter, hub, switch, wireless access point, and print server can, likeany other device, go bad. However, the most common problem is not a badport but a bad or loose connection, a bad Ethernet cable, or the wrongtype of cable. Refer to the Cabling section above, to eliminate thesepossibilities.
  8. Wrong port. One possible cause of Ethernet port problems isusing the wrong port on a network device. For example, routers have WAN(wide-area network) and LAN ports. These ports accept the same Ethernetcabling but are not interchangeable. The same is true of hubs andswitches that have uplink ports, which are specially wired LAN portsthat allow easy cascading of multiple hubs and switches. In some cases,the uplink port is also a normal LAN port controlled by a switch on thedevice. If you’re using the uplink port as a normal LAN port, make surethe device is configured properly for this type of use.
    If aport doesn’t appear to be working, you can use the link light toconfirm it. Port link lights should always be lit when a good cable isconnected between the port and another working network device. If youuse known good cable and a known good network device to test the portbut the link light isn’t lit, you may have a bad port. You can eitherreplace the network device, or in the case of a hub/switch, add a hubor switch to gain more LAN ports.
  9. You cannot connect to other computers or router/Internet. Whenother computers in your LAN can connect to each other, as well as tothe Internet or other services, and your computer cannot, this may bean indication that your computer did not receive an IP (InternetProtocol) assignment when you booted.
  10. Open a command prompt, type ipconfig –all, and press ENTER. Inthe section labeled Ethernet adapter Local Area Connection, look forthe line labeled IP. If it starts with 169, you have a self-assignedIP, which indicates that your computer was not able to acquire an IPassignment from the DHCP (Dynamic Host Configuration Protocol) server.
    Test your access to the DHCP server by using the ping command. Open a command prompt and type pingfollowed by the IP address of the DHCP server. Your DHCP server isprobably the same as your router. For example, if your router’s IP is192.168.1.1, then type ping 192.168.1.1 and press ENTER. Youshould see four lines of text, starting with Reply From 192.168.1.1:Bytes 32, followed by time values that indicate how much time elapsedbetween the ping command and the router’s response. If you see fourlines that say Request Timed Out, then your computer cannot reach yourrouter/DHCP server.
    Make sure the router is plugged in,turned on, and properly configured to provide DHCP services.
These are just a few things to try to help figure out if it is your cable, ethernet card, router, or some other problem.
Jan 19, 2009 | Dell Ethernet Card Network Adapter
Toshiba Portege 2000 Notebook Logo
65 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
