Question about Garden
Petrol Briggs & stratton 3.5HP engine 'hunts'
How do i get my Petrol Briggs & stratton 3.5 HP engine to run smoothly, so that it doesnt ''hunt''. Have changed the air filter element for new, used new fuel & checked that the oil is topped up. It is secondhand from a friend.
jj505
  • 195 Answers
SOURCE: Have a Briggs & Stratton lawn mower engine, 4.5
Is Blade new or causeing vibration .Chge blade,
Please rate Thank you jj505
Posted on Mar 30, 2009
  • 41 Answers
SOURCE: Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Posted on Aug 04, 2009
  • 512 Answers
SOURCE: Briggs and Stratton 19.5 hp 42e707 Hunts and Surges
Are you sure you got all the passageways in the carb cleaned out?
How did it look when you first disassebled it? Full of rust and gunk or just shellac on the surfaces?
Take the fuel line off at the carb and MAKE SURE that fuel flows freely. I have seen trash get in the tank and plub the other end up. Does it have a vaccuum operated fuel pump?
Posted on Sep 10, 2009
heres2maine
  • 84 Answers
SOURCE: My flymo briggs & stratton quick silver 46d
Your carb needs to be taken apart and cleaned
Posted on Jul 10, 2010
  • 150 Answers
SOURCE: omega 42 petrol mower hunting then cuts out.
Check high speed adjustment on carb. Back it out (counterclockwise), if there is no adjustment screw the you may have to drop the carb bowl and clean, blow out jet with air
Posted on Oct 11, 2010
Engine not running smooth until blade is activated
ill bet this is an older briggs engine ? as they seem to need a little tlc on there governor speed control spring for it's feedback to the throttle , this makes the engine surge a bit (hunting) till a load is placed on it then it runs smooth , now if it doesn't smooth out under load id suspect a carb fuel flow problem
Sep 02, 2015 | Briggs & Stratton Garden
We have a 27hp v twin briggs & strattion which back fires and surges when engine is hot
have you tried checking the lean,rich needle on the carb sounds like it's to lean. good luck
Aug 11, 2014 | Briggs AND Stratton Intek Briggs &...
My Briggs & Stratton Diamond I/C 13.5 HP has
it could be worn out piston rings letting unburnt fule past into the sump oil
Jun 20, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
12.5 HP Briggs starts ok but constantly hunts or oscillates.
check air filter it sounds like its blocked if that dont fix it strip the carb and clean out the running jets with card cleaner dont go poking wire into the jets or you could distroy them
Mar 27, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 3.5hp running problems. I am unable to get my B&S to run smoothly It starts and runs but continuously but hunts all the time and does not get up to full power. any sugestions of...
people often leave petrol in these types of engine when not in use for long periods and susequently the petrol then turns bad, the only way to resolve this is to take off the carburettor and clean out espesially the main jet
Mar 21, 2010 | Briggs & Stratton 30-Amp Extenda Panel -...
Briggs & stratton Modal No 490179 carburettor linkage
it sounds like the governer needs to be set and the carb needs to be cleaned out> I would get a carb rebuild kit and go to briggs online and look up how to set the gov dont run it till you do or you may blow the motor
Aug 31, 2009 | Briggs & Stratton Power Products 5,550...
Briggs & Stratton 18 hp v-twin engine surges while running.
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Jul 12, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
