My Celeira Split system has a non standard Charge port fitting that does not interface with my AC technician's gauge connector. Is there an adapter that can easily allow connection? Thanks
  • 674 Answers
It' possible to get an adapter that goes from 1 size to another.
Posted on May 14, 2010
Add refrig charge! Model nppac8kwgx. Where?
Hallo
Fit ******* port(blue) to charge nipple onto the compressor.
Fit manifold port(yellow) to Refrigerant(keep tank close)
Fit discharge port(red) to vacuum pump.
Then:
1)First vacuum your system for atleast half an hour.
2)Close both values on gauge when half an hour is up.
3)Switch off vacuum pump.
3)Turn Refrigerant tank upside down and open it.
4)Now gently open ******* side a bit and close, repeat until no longer in vacuum.
5)Then turn fridge on and charge no more than 11psi.
I would strongly advise not doing this, let a professional refrigeration technician operate the recharge. Before changing remember if there's no refrigerant in the system then theirs a leakage.
Be sure that it's a shortage of refrigerant and not a blocked pencil dryer, low efficiency compressor, blockage in system and that all the controls operates as they should.
***Most fridges and freezers, basically all domestic refrigeration compressors enquiries a refrigerator technician to weld a charge nipple onto the charge port.
Regards
Jun 07, 2016 | Refrigerators
The charging port of my acer 5251 is broken, so I cannot charge my battery. Is there any way to charge the battery externally? Thanks
Charger connector breakage is a common problem in this type of device. The practical answer is to repair or replace the connector so that you can recharge the battery in the normal way.
Nov 28, 2013 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Ac not working
The first thing to do is check the charge in the AC system with a set of AC pressure gauges that attach to the charging port, if the pressure is low or non existent then you have a low charge and this means you have a leak in the AC system. The leak must be found and repaired and then the system evacuated and recharged with the correct level of refrigerant
Jul 08, 2012 | 2002 Mitsubishi Eclipse
Where do I charge r134 coolant? the adapter on can fits the high pressure valve and the low pressure valve is too big? please help..
can't be.the larger port is the HP side, and the hose on your can will only fit the low (small) pressure side-you CAN fill a system on the HP side, engine off, by hooking up to the HP side and inverting the can so that liquid 134a fills the high side-but it is not recommended if you do not have manifold gauges and aren't experienced with AC systems.
May 31, 2011 | 1998 Toyota Corolla
Chargeing Unit
The old 410A fittings are different than the r-22 fittings. There are adapters available on ebay. Remember 410A runs at higher pressures than 22. Be sure to use gauges for 410A! Use the right gauges with the right hoses! High pressure.. Use the right gauges and the right hoses!
Jul 30, 2010 | AmcorAire UCHW-H18AF2 Split System Air...
Need special fittings to hook up gages. Repair mans standard gages won't fit on compressor unit. Where can I get fittings to adapt to your machine?
It may be a 410a unit. regular R22, R134 gauges will not work. You will need 410a gauges as it has much higher pressure in the system.
Apr 12, 2010 | Amcor Aire UCHW-H09AF2 Split System Air...
AC booster recharge hook-up
You can only attach the the recharge hose from the kit to the low side ( A/C service port) and the cap should be blue with a leter L on it. Good luck and follow the instruction and don't over charge the system. With the AC on the coldest setting, use a thermometer in a middle vent. Normal vent temperature readings will vary depending on the (ambient) outside temp. The vent temperature should range from around 42-55 degrees in my experience. If normal gauge readings are obtained and the vent air is cold - STOP don’t overcharge the system. The only proper way to remove refrigerant is with a AC recovery machine so if this is being done at home I can’t emphasize enough not to over charge the system. And actually the best way to insure the proper charge is in a system, is to use an AC machine to recover the R134a and then evacuate and recharge the system with the correct amount. Most cars have the specified amount on a decal under the hood.  Good luck and hope this helps.
Jul 03, 2009 | 2000 Saturn SL
AC Adapters in laptops
It is not a special chip that dictates if a charger can charge a certain laptop, but these two factors:
1) You need to have a power adapter/charger with the correct voltage and amps. Some common Dell laptops use 19.5V (volts) and 4.62A (amps). I have seen some Dell adapters with 3.34A (amps) as well. If you use an adapter with the wrong voltage and amperage, you could cause damage to the laptop's power supply and/or motherboard...or it just won't work at all.
2) The type of connector to the laptop. Different manufacturer's use physically different connector sizes and shapes. Some are larger and circular with a pin in the middle, while some are smaller with no pin. It depends on the laptop.
You can look at the voltage of the original charger on the brick part (the middle of the cord that looks like a brick). Make sure you get one that matches exactly.
Mar 19, 2009 | Dell Inspiron E1505 Notebook
Notebook not charging
if the AC adapter port itself on the computer is loose even if you tried different AC adapters, the motherboard of your system will need to be replaced. If the warranty of your computer is still active, you can request a replacement motherboard from Dell. Otheriwse, if the warranty is no longer valid, you either need to purchase a replacement board, or try to use electric tape around the end of the AC adapter to fill it the gap when attached to the port on the computer.
Mar 16, 2009 | Dell Latitude D600 Notebook
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
