Question about Gateway 310 S PC Desktop
Instaalling new ram avoiding static problems.
Instaalling new ram on gateway 310 S avoiding static problems.
    Champion:
  • 218 Answers
You can get an anti static wrist strap hope this helps if it does please rate this answer
Posted on May 15, 2010
    Problem Solver:
  • 8 Answers
One way to avoid static, is to literally work naked, on a hard floor (avoid carpets), and allways hold a hand on the frame of the case. but, you realy don't need to work naked either, just make sure that you are properly grounded, (hold on to the frame to decharge yourself of static) work without socks, and preferably on wooden floors or similar. Have fun.
Posted on May 14, 2010
How to replace battery in ast bravo desktop computer
Turn OFF and UNPLUG the system, always keep one hand on the chassis to avoid static sparks from damaging your system... open the system chassis, look on the motherboard for a battery about the size of a nickel (like a big watch battery), its held in a simple spring loaded retainer. note its orientation ( which side is +/-). most systems use a CR2032 battery you can find at any hardware store
Dec 02, 2013 | AST Bravo MS PC Desktop
I have a Gateway 310 XL H desk top PC. After the storm, Isaac, It won't power on. The red and green lights come on, the red goes off after a short time. The monitor flashes a manfacture logo then
The system is powered up if green light on, the hard disk is powered up if red-light on for a few seconds then goes off, but I assume it's not loading up after that. You have no output to video.
Try holding f2 or f4 to load default bios when turning on. If that doesnt work then That would point to me that there is a problem with either:
1) processor burnt out, or needs refitting following a knock to the case causing a bad connection.
2) ram burnt out or not correctly installed. Try refitting the ram or using a different combination of ram.
3. Bios chip burnt out. Sometimes you can literally see the chip is slightly melted.
4. Other motherboard fault, look for melted chip or damaged component.
5. Psu faulty or not connected properly. Check connections, or bench test with another psu.
Have you moved the pc recently? Sometimes dust builds up under processor or along ram, and when moving pc giving it a slight knock can cause bad connection. If dusty, remove clean and re install.
Hope it helps.
Sep 05, 2012 | Gateway 310 S PC Desktop
Gateway lt2032u won't boot
Did you use a static mat or band to discharge any electrical activity out of the body, if not you probably had a static buildup and discharged it on the main board causing a disruption in the data flow, you may need to re-install your operational system.
Mar 26, 2012 | Gateway LT2032u 101" Netbook NightSky...
Please can I have contact number for the clarion gps map update.
Clarion Corporation of America
6200 Gateway Drive Cypress, California 90630
Customer Service: 800-347-8667
New & Existing Dealers: 310-327-9100
Phone: 800-GO-CLARION (462-5274)
Phone: 310-327-9100 (MAIN)
Fax: 310-327-1999
http://my.clarion.com/en-us/html/home
Oct 29, 2010 | Clarion GPS
My gateway computer won't turn on and now its beeping at me when I try to turn it on. What do I do?
The beeps you hear are BIOS Beep Codes. The computer's way of telling you something is wrong, and the area to look into for it.
For one example: One long beep, followed by two short beeps. Then a small period of silence, and the beep code starts over.
Without knowing the beep code you hear, it's like shooting in the dark when giving a diagnosis.
Also wish I had the Model Number of your Gateway desktop computer to help you further.
This is up on the side of the computer tower, or on the back.
[ Example.
Model: Gateway 7200X.
S/N = Serial Number. DO NOT give this out in a public forum. Only to a Gateway representative, or Gateway Support online ]
If I were to take an educated guess, it would be a problem with your graphics, or Ram Memory.
I would suggest opening the computer case, and removing all Ram Memory modules, then cleaning the gold plated contact pins on the bottom.
Clean the contacts with a pencil eraser.
FIRST!
Power unplugged to the computer. Work on a table. Unplug all cables to the computer. Open the computer case, follow Anti-Static Precautions.
(If you are not perfectly sure where the cables go, I advise making notes, and a drawing of where they go before you unplug them)
Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit) the hardware components inside a computer.
[ Some hardware components examples are; Processor, Ram Memory, Harddrive, Graphics Card, and Motherboard's chipsets ]
TOUCH the metal frame of the open computer case.
This action will relieve your body of Static.
Computer unplugged from power, you are safe.
Touch the metal frame, your computer is safe.
Should you leave your computer in the middle of working on it, upon your return be SURE to Touch the metal frame again.
This is a basic example of a Ram Memory module, ('Stick'),
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
(You can left-click on the photo to enlarge. You can enlarge twice)
Note the gold plated contact pins on the bottom, of the Ram Memory module.
These are the contact pins you clean with a pencil eraser.
You don't have to rub the eraser on the contact pins very hard.
Just go over the contact pins with the eraser.
If you are using an eraser on the end of a pencil, refrain from letting the metal band, contact the gold plated contact pins on the Ram Memory module.
After you clean each contact pin it may not look like you have done anything. You have.
Corrosion builds up on the contact pins after time. It takes very little corrosion to make a bad contact on those contact pins.
Use air to remove the eraser dust.
If you have a can of compressed air for computers available, this will work.
If not air pressure from your mouth will be sufficient.
Reinstall the Ram Memory module/s.
Reinstall the computer cover.
Plug the computer back into power.
WAIT 1 minute, turn the computer on.
Gateway Support > All desktop models,
http://support.gateway.com/support/supinfo/index.asp?pg=2&file=dt.html
Video of how to remove, and reinstall Ram Memory,
http://www.videojug.com/film/how-to-install-more-memory-in-my-computer
[ You won't need an ESD wrist strap following my Anti-Static Precautions above ]
Oct 09, 2010 | Computers & Internet
Gateway dx 4820 power up problem
Let's start with some of the basics.
1) Since you were checking connections on the motherboard, was the power unplugged from the computer, AND did you follow Anti-Static precautions?
[Anti-Static Precautions:
Static WILL fry out (Short Circuit), the hardware components inside a computer.
You may not even see it, or feel it.
Computer unplugged from power, computer case open, computer on a table.
TOUCH the metal frame of the open computer case to relieve your body of Static.
Should you get up in the middle of working on your computer, and leave, upon your return Touch the metal frame again.
Or use an ESD wrist strap, and connect the alligator clip to the metal frame ]
2) Computer unplugged from power, anti-static precautions followed, remove all ram memory modules, and reinsert them. In fact, it would behoove you to clean the contact pins on the bottom of the ram memory modules, before reinserting them.
Clean with a pencil eraser. Remove the eraser dust, with air pressure from a can of compressed air for computers, or air pressure from your mouth may be sufficient.
You may have bumped the ram memory modules.
Even if they look to be seated, it only takes a few minutes to remove, and reinstall.
After time, corrosion can develop on the gold plated contact pins, at the bottom of the ram memory modules. Doesn't take long to clean them with a pencil eraser.
Handle the ram memory module by the body. The body, is coated with a clear see-through protective plastic.
The above link, is only provided for an illustration of the gold plated contact pins, I am referring to.
It is DDR Sdram ram memory, and has 184 contact pins. 92 on each side.
Your computer uses DDR3 Sdram ram memory.
Has 240 contact pins. 120 on each side, and the Locating Notch is in a different place.
3) Are you sure the 4-pin ATX +12 Volt power cable, is plugged in tightly to the motherboard?
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
This is power for your Processor.
http://support.gateway.com/s/desktop/2009/gateway/dx/dx4820/DX4820nv.shtml
SATA power cable is plugged in tightly to your SATA harddrive?
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
If your SATA harddrive has provisions for plugging in a SATA power cable, and a 4-pin Peripheral power cable, BE SURE that only the SATA power cable is plugged in.
Plugging both in will fry out the harddrive. Maybe not right away, but will down the road.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Reply back in a Comment.
Jul 03, 2010 | Gateway DX4820-01 PC Desktop
Gateway 310 X will not power on
Hi. this is a failed power supply. the power supply pack will have to be replaced. it located on the rear side of the tower in the upper corner. its where the power cord plugs into. replace the power pack and this will fix the issue at hand.
May 17, 2009 | Gateway 310 X (310XSP) PC Desktop
I have a Gateway laptop computer with XP. It originally had 512mbs of memory. I bought 2gigs of memory and installed it. It worked lightening-fast for about one day. Here is what happened: My wife...
I was initially confused about the addition of the Dell laptop in the plot before realizing what you are saying:
I think its your RAM. Did you ground yourself while removing or replacing the ram to prevent static shock from damaging the device or memory sticks?
If not, try getting another 512 stick (pretty cheap) from best buy for your gateway and testing it out. Save the receipt.
Also, post the model of your gateway laptop as some computers can not handle large amounts of ram. Most will only allow up to 2x the original amount.
Dec 06, 2008 | Computers & Internet
Want to konw my memory capacity Serial NB24A 310 55747 Model 4530GZ
Gateway 4530GZ Notebook
Memory type 333 MHz DDR RAM
Memory expansion options Two 200-pin industry standard DDR-SODIMM sockets
Accepts two 333 MHz DDR RAM memory modules in memory bay
2 GB maximum system memory
Oct 23, 2008 | Gateway Computers & Internet
Gateway 310 S PC Desktop Logo
52 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
