Question about Senco 4D0001N Framepro 502 Framing Nailer
My driver is sticking on my senco framing nailer it is a frampro601. what can i do to fix it
  • 23 Answers
SOURCE: senco 600 framing nailer / double hitting(nailing)
double nailing is usually caused when you apply to much pressure on gun causing it to fire on the recoil lighten up just tap it on the surface to be nailed
Posted on May 11, 2009
  • 142 Answers
SOURCE: Senco 601 nailer shoots 2 nails each time the trigger is pulled.
the 601 had a design flaw, in the nose, where the nails hit as the are being pushed forward, the peice was made out of a peice of metal that was too soft, it wore down and that is where you get the double nail problem.
Senco offered a trade in, this was years ago, for a limited time and gave us credit towards new guns, which we gladly did
Posted on Dec 31, 2009
  • 885 Answers
SOURCE: I have a Senco Frame Pro 600. It will not fire,
You need an o-ring repair kit. As there are a few different versions of the FP600 I don't know which one you need. If you go to www.senco.com and click on the nailers, staplers and collated screwdrivers picture it will take you to a page where you can find the parts list for your particular gun and it will tell you which repair kit you need. If no kit is listed you will have to go through the parts breakdown and order each and every o-ring. If you replace one, replace all of them.
Posted on Aug 23, 2010
sam0438
  • 7 Answers
SOURCE: I have a Senco Frame Pro framing nailer. The plunger is sticking in the
Check the drive pin for burrs and file them off. Check for worn piston replace if necessary. Clean the air return hole in the top of the piston cover. Add oil if manufacturer recommends it.
Posted on Mar 27, 2012
jeffpetree
  • 36 Answers
SOURCE: driver sticks down of senco pin nailer
If the piston is not seized its usually the trigger assembly
the trigger valve switches to both engage and retract the piston
Posted on Aug 29, 2012
Senco 601 plunger sticks when unplugging air line
The piston stop in the head is supposed to grab and hold the piston - I don't believe that is your issue. The problem I think you are experiencing is the head valve not moving freely up and down. There is a funny looking spring under the head valve to push it back - often these get weak or broken causing the head valve to jam.http://senco.com/Documents/Guides/FP601_PC.pdf
Part # KB4393
I would purchase the repair kit #YK0360 which includes this spring - clean and lubricate the tool as you reassemble.
Nov 27, 2013 | Senco & Frame Pro 601 Framing Nailer
What degree nails
Hi, Senco 601's use a 34 Degree Strip nail. Easiest way to remember is this when thinking of Senco strip nailers:
601 and 651 are 34 Degree clipped head nails
602 and 652 are 20 Degree FULL round head nails
www.collatedfasteners.co.uk
Mar 17, 2013 | Senco & Frame Pro 601 Framing Nailer
Senco nailer won't fire nails, but the firing pin dents the wood almost 1/4 inch.
Hi Jes,
Are the nails moving freely in the magazine if you pull the mag spring back? If so, then the driver blade is not returning to top dead centre - leaving enough of the blade to stop the next nail moving into the nose. This could be caused by a slight back pressure in the cylinder so, check the exhaust is clean and free of any swarf. Or check the O Ring on the driver blade, even though you've just replaced them....
Mar 01, 2013 | Senco & Frame Pro 601 Framing Nailer
Senco trigger schematic
Go to the Senco website at www.senco.com, click on the "Parts Charts/Specs/Manuals" tab at the top then scroll down to Frame Pro 502 where you can view or download the manual or parts guide. Their parts guides have very good exploded views of the tools and are very helpful when reassembling them.
Oct 25, 2012 | Senco 4D0001N Framepro 502 Framing Nailer
Mar 24, 2012 | Senco Air Tools & Compressors
Senco sn901xo is leaking air out the top on the nailer.
This is a sign that internal components are sticking. Try spraying a light weight oil like wd 40 down the air inlet and dry firing the gun several times. If that does not work, pop off the top of the gun, that is your exhaust port. Clean the area with contact cleaner, and lube with air tool oil.
Mar 03, 2011 | Senco SN901XP Clipped Head Framing Nailer
SENCO Framing nailer suddenly decided not to fire. Air escapes from top of gun when trigger is pulled
You have some worn/broken o-rings inside the gun. You need Senco repair kit #YK0360 to fix it. Fairly easy to replace the o-rings, just be sure to put lots of lube on the rings as you put it back together.
Nov 29, 2010 | Senco FP620 Framepro 602 2" - 3 - 1/2"...
Problem accessing nails
Hi, No you can't. They are two different feeds. The F33 uses tape feed and the N79 uses stick feed. The N79 is a basic wood frame nailer that uses 3 to 3 1/4 sticks, while the F33 uses up to 2 1/2 paper feed. The stick nails are the most common for the older nailers and on the box look for Bostitch as the brand to fit, as the N79 was sold under that brand not Stanley. This should Fixya!
Mar 02, 2009 | Stanley F33PT Paper Tape Framing Nail
Senco 4D0001N Framepro 502 Framing Nailer Logo
64 people viewed this question
Top Senco Tools & Hardware - Others Experts
John Trevino
yoopertech
Matt Olenzek
Matt Olenzek
Are you a Senco Tool and Hardware - Other Expert? Answer questions, earn points and help others
