Question about Bosch & Power Vent Water Heater
My bosch AQ 125FX keeps running the fan, but won't start a flame
With the propane ON and the power ON, the blower fans runs all the time but the flame igniter will not start the burners when I open a hot water tap
2 Suggested Answers
co7196
  • 3433 Answers
SOURCE: Bosch AQ 125XNG water heater burner frequently won't light
May be That we have something we can try. first, what doesn't work most of the time? Blowing with all you mite or jumping out of the way before your hair gets singed?
I think it sounds like you might have a maladjusted ignitor. Mispositioned. Its not in the gas path. Sometimes this happens as the tungsten ignitor wears down. That can be adjusted by repositioning the ignitor so it is in the pat of the gas. Just don't test as you go. Set the ignitor so the arc is about 1/4 inch long and about 1/4 inch away from where the gass comes out. Keep clear of the access hole. The longer it takes to ignite, the more gas build up there is. Have your exhaust vent checked. restriction keeps it from drafting and drawing enought air to balance the air gas mixed to ignitable.
Be careful and be safe
Posted on May 18, 2009
I have a Bosch tankless propane water heater 125fx. Yes, I know it's ****, we replaced the igniter switch last year. Then struggled with ordering parts to repair a water leak. During the leak, it was...
There is likely an onboard relay stuck in the open position.
This is a gas appliance and should be serviced by an authorized BOSCH repair center to avoid potential catastrophe.
Thanks!!
Aug 06, 2010 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
Fan won't stop running
remove from the wall.... donate to charity and purchase a quality tankless water heater!!!
Rinnai, Takagi, Noritz are the only brands I will install. I refuse to even work on Bosch "Aquastar", complete garbage!
Aug 05, 2010 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
125FX (with FXhood) turns off while in use
may be overheat stat or fan check little hose at fan area for pinhole best of luck
Oct 19, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
May 15, 2009 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
I have a power vent2 water heater by Rheem products. Problem seems to be with blower fan turning on when thermostat calls for heat. Fan makes un-able to start noise and thermostat stops. If I turn the...
your blower motor is trying to seize up on you, it is time to change it, if the fan doesn't come on first your water heater should not light, the fan comes on first to get eccess gasses out of the burner compartment,, do not light with ot the fan first it could combust
Jan 27, 2009 | Bosch & Power Vent Water Heater
Turn on water the electronic ignition not coming on
The tankless water heaters require larger gas supply lines because of the on-demand consumption. While I don't know your units rating, most Propane Tankless Waterheaters require 2" supply lines. Moreover, pressure is directly related to temperature which sounds like your problem entirely; consider the run of the gas pipe from the tank and the ambient temperature. Now you see why plumbing is a hard profession to fake... =)
Nov 19, 2008 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
Bosch & Power Vent Water Heater  Logo
47 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
