Question about H.D. Hudson 1 Gal Poly Deck Sprayer
Pump is presurized but no spray - H.D. Hudson 1 Gal Poly Deck Sprayer
Most weed killers and fertilisers either crystalise or turn to gel when left unused. Pull sprayer wand to pieces and run hot water through the hose and wand, they especially clog up at the spray tip and at the on'off control.
Posted on Jul 19, 2012
Take spark plug out and they are completly dry!and all 6 got nice blue sparks! and open junction petrol rail before injector, their are strong spray out! so please explain what is cause of?
Hi Jodie, Your fuel system utilizes an electric fuel pump to presurize the fuel lines to deliver fuel from the tank to the injectors. Now is the spray out caused by you removing a piece to see if you have pump presure or is it an actual leak that must be repaired? Any loss in the system will cause the plugs to run lean. Good luck
Mar 27, 2015 | Cars & Trucks
06 pt cruiser no start/no fuel presure
fuel pump fried need new fuel pump check your fuel pump relay make sure its good.
Feb 17, 2013 | 2006 Chrysler PT Cruiser
Why is the fuel filter stay empty on 2003 chevy duramax 2500, when you pump it up, and spray it with ether,
could the fuel pump be weak it should give 55lbs presure for a petrol engine
Apr 28, 2012 | 2000 Chevrolet 2500
Car starts and cuts out after 2 to 3 seconds. fuel
When the ignition switch is turned on the pcm turns on the fuel pump by energizing the fuel pump relay. The PCM keeps the fuel pump on as long as the engine is cranking over or running.It does this by recieving pulses from the ignition module. If there are no referance pulses the PCM will turn the fuel pump relay off in 2 seconds with the ingnition on.
Most models also include a secondary control path through the oil presure switch witch will turn the fuel pump on after it detects oil presure.cranking time will be longer if the fuel pump doesn't recieve current until oil presure switch contact is closed.
Jan 28, 2010 | 1998 Chevrolet K2500
I have a 1995 chevy blazer 4x4 and the car sounds like it wants to start but, it wont kick over
Try to spray a shot of starting fluid in your air filter inlet. if it fires check fuel pump presure, And fuel pump relay.
Aug 12, 2009 | 1995 Chevrolet Blazer
I installed new fuel pump and truck will idel for about 15 second
check to see if the injectors are working, what engine do you have? and what kind of fuel pressure are you getting? check fuses for the injector circuit, if your fuel pump is working and you know your spark is good, the next thing to check would be the injector system
Jun 19, 2009 | 1996 Chevrolet S-10 Pickup
Lanos 95
hi there if you checked the pressure at the fuel rail then the fuel filter is clogged but if checked it before the fuel filter than it is the fuel pump
Aug 22, 2008 | 2002 Daewoo Lanos
Upper arm does not spin
No I don't believe its the pump. I believe the lower spray arm is possibly split open on the side causing a loss of presure and flow to the upper arm and overloading the door seal. As well the loss of flow to the upper arm will resulted in it turning too slow.
Aug 12, 2006 | Frigidaire 24 in. FDB635RF Built-in...
H.D. Hudson 1 Gal Poly Deck Sprayer Logo
357 people viewed this question
Top H.D. Hudson Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a H.D. Hudson Garden Expert? Answer questions, earn points and help others
