Question about D-Link AirPlus DI-524 Wireless Router
Setting up an old router
Got an old D Link DI-524 router in our house...
It was working when I moved in, but stopped when my housemate switched the internet account.
I suspect it just needs reconfiguring somehow... but it's out of warranty and i don't know how to reset it.
I want to have a go at it before i chuck it out as junk.
I don't know any passwords or anything as it belonged to someone who has moved out.
Any ideas?
thanks
    Scholar:
  • 35 Answers
To perform a reset, please follow steps below:
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Note: The factory defaults username is admin, and there is no password.
Posted on Mar 30, 2008
I forgot my parent controls pin
As far as I am aware, the only way to reset the pin, is to reset the router to factory defaults. You will then have to reconfigure your wireless settings. To reset to factory defaults:
Plug in the router.
1. Locate the small reset button. It is next to the power jack.
2. Use something to push the button, a paper clip works well.
3.Hold the reset switch down for 10 seconds.
4. Wait for the WLAN light to stop blinking. The router is now reset.
To reconfigure the settings on the router, enter 192.168.0.1 into your browser address bar.
Mar 14, 2011 | D-Link AirPlus DI-524 Wireless Router
My DI 524 keeps dropping out. I have reset the router several times and reconfigured it.
there are a large number of reasons for wireless dropout on routers but in my experience they are almost always a sign of failure or imminent failure.
This model is quite old but should still be serviceable.
If it not the wireless side but your wired side then i would be looking at what you have connected to it and how those computers are set up
My own preference is to go to each computer and make sure it has its own IP etc and that the cable are not directly crossing any power cords etc (or at least as few as possible)
If it is just say one particular computer and if it is a wireless connection then maybe move the router either higher or to a more central location in the house.
Location of wireless routers is and can be a crucial factor in getting wireless to work around a house.
The setting on the router itself may also be an issue and to check those you may want to get a tech savvy friend or local tech into check it out for you.
There is always the option on a newer router too as they have developed quite a bit since that model and tend to offer much better security and better connectivity.
Feb 01, 2011 | D-Link AirPlus DI-524 Wireless Router
Wireless portion of d-link di-524 is not working. Flashed with fw ver 1.23 and no avail, flashed to fw 1.05 worked for ten minutes. Help please!
If it worked briefly then stopped, it's probably faulty with a heat sensitive component. Switch it off overnight and see if it works next day. If it fails again after 10 mins, get a new one.
May 16, 2010 | D-Link AirPlus DI-524 Wireless Router
D-Link DI-524 is not communicating with modem
Checklist:
* Is DHCP configured correctly?
* Connect your server and laptop to a switch (not directly with the cable)
* Can they ping each other?
* Check that the firewall is configured (or switched off if you have another FW in place)
* Default gateway should be your router, not the computers (until you have configured RRAS for example)
Here you can find more information about how to configure various roles in 2008: http://technet.microsoft.com/en-us/windowsserver/2008/default.aspx
Sep 07, 2009 | D-Link AirPlus DI-524 Wireless Router
I have a D-Link AirPlus DI-524 Wireless Router. I have no problem connecting the computers in my home that have windows XP installed. We have replaced two of the computers in the house with laptops that...
I have had exactly this problem and after MUCH work downloading new drivers for the Vista Pcs and updating the operating system in the DI-524 found that the 524 does not operate well with Vista. A new DI-624 integrated well with Vista, and installed with no problems. Good luck!
Feb 22, 2009 | D-Link AirPlus DI-524 Wireless Router
Installing a DI-524 router
Hi askar,
I'm assuming if you've been given a username/password you've either got DSL (a PPPoE connection) or it's for your email address. If you don't have a disc for your new router, you can configure it through a wired connection to the router (using an ethernet cable). That's a bit of work but if you need to do it that way we can help. Otherwise run the CD that came with the router (again, you'll need a computer plugged into it) and the step-by-step should get you through it.
For starters, unplug the modem and then plug the cable running from the old router into the same port space in the new router (should say either WLAN or Uplink). Turn on the modem, wait 30 seconds, then power on the router. After that run the disc and you should be good.
If not, let me know!
Ben
Sep 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Connecting a DI-524 to a DI-604
This shouldn't really be any problem simply use a short "Uplink" ethernet cable to join the routers thru the uplink port, or any port really, and that way ya should be able to wifi and access the net, set ya router that connects to the net for DCHP and disable that setting in the Wifi router and ya should be good to go?
Jan 30, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
One LAN port not working
My guess is that this port is just plain old dead. When you really need an extra port you could consider picking up a cheap ethernet switch. Repairs are not done because of the time an money involved vs the cost of a new one. When it's still in waranty you could always return it to the shop. Ports are normally hardwired and not controlled by the software on these kind of routers.
Jan 15, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
50 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
