Question about Kelty Base Camp Framed Baby Carrier
I am looking for the plastic piece that connects the foot stand to the carrier for the base camp.
How to remove the monitor stand on acer s242hl?
For the S242HL
1. Unscrew the screws from the plastic base and remove this. You are now seeing the metal part of the base.
2. Lay the screen glass down, on a flat surface. If you crouch down and look into the area the metal piece is inserted, you will see a plastic 'tab' that is locking the metal piece in place. Wedge something to lift the plastic tab, so that you can pull the metal piece out. You can use quite some force to lift the plastic and then the metal bit just slides out.
I've just done this so I know it works.
Apr 28, 2014 | Acer Computers & Internet
How do you collapse a Cosco Flat Fold High Chair Model: HC188AKT
Standing in front of the High chair, on either side of the back of the chair are two plastic pieces, that look like they serve no purpose. They are curved at the bottom, to hold your finger. Place your fingers on the bottom of these two pieces and pull up.
Magically, the chair will fold towards you. You can also easily remove the foot rest to get a flatter fold, so that the chair fits into a smaller space.
Feb 20, 2013 | Cosco Flat Fold High Chair, Born To Be...
Need stand/bracket for Dynex flat panel model DX-26LD150A11
with a brand like this you may have a hard time finding anything, You might look on MCM electronics if in North America as they sell about 50 different bases and mounting brackets that are universal ones.
Dec 23, 2012 | Dynex Televison & Video
Car seat base is still wobbly after installed in the car. We don't have specific instructions for it. Can you email directions for the proper installation?
Good Day!
Here are two videos that will simply shows the proper way to install it.
and
http://www.ehow.com/video_4440636_use-infant-car-seat-bases.html
Here are some tips for added protections on your car seats
  • Many times this type of car seat comes with a base that a carrier latches into. This actually makes installation easier because you are dealing with a rather small piece of plastic. The base and carrier should only go in the back seat, preferably in the middle, although this is not a hard-and-fast rule.
  • You might need to place a shortened swimming noodle (one of the only materials CPS has certified) to level out the base, which should lie at a 45-degree angle with the carrier installed. Some manufacturers make bases that are adjustable.
  • Make sure the carrier straps are tight and the harness clip is even with the baby's shoulders or armpits. Also make sure the straps are in the slot that lines up just above or closest to the infant's shoulders.
  • If the child is still a bit wobbly in the seat due to her size, place rolled receiving blankets or towels along each side. This provides additional support and cushion. However, do not place anything under the harness straps.
  • When the carrier is snapped into the base, the handle should be out of the way. Place it in the down position.
  • Some older vehicles (especially those manufactured prior to 1997) may require the use of a locking clip. This is a small piece of metal that looks like the letter "I" on its side. Certain vehicles do not have seat belts that lock when the brakes are slammed. The clip locks the seat belt and prevents extra slippage in the event of an accident.
Aug 28, 2011 | Toys
I need help removing the stand to my ASUS VH197D LED monitor so that i can attach my wall mount.
For the ASUS VH197D LED Monitor, turn it upside down so you are looking into the base of the stand. Squeeze the plastic tabs to unlock the base and pull. This will remove enough of the base to make it wall mounted and you can quickly attach the base if so desired. If you want to permanently remove the base and stand, remove the two screws that are now visible after the base is removed and pry out the plastic stand. This will break it off at the hidden screws. You will be left with a short metal stub that can be folded in.
Aug 01, 2011 | ASUS VH197D LCD TV
How to fold the Graco Stroller 6001BCL1
Take the carrier off by raising the handle and then lifting the handle with one hand as you pull the red handle on the back of the carrier with the other hand. Set the carrier aside and stand behind the stroller. There should be 2 matching plastic 'things' on either side of the stroller, just under the rubber handle. Put your thumbs on the rubber handle and your first 2 fingers on those plastic pieces. Pull those plastic pieces up with your 2 fingers and the stroller will collapse. I hope this helps!
Sep 26, 2009 | Graco Baby Gear
Carrier Jam
THis solution I copied from another post. It worked for me as well
First you need to open the printer. Unplug from power. Then lift the scanning device, you can partially remove it when pushing the "hooks" close to where the lid is connected (careful with the cable connections). Then remove three screws in the cover of the bottom part and with some fiddling around you can remove the cover. Again be careful with the cable connections. Of course don't do it if you are worried about warranty or breaking the printer.
The plastic strip has slits at each side to attach to the inside back of printer, on the left side is a down ward facing arrow, the plastic strip feeds through the back middle of the cartridge carrier and then the slits are to be inserted to the metal tab like pieces on the back sides inside the printer on the right side (facing printer) it will look like a small rectangular hole with a longer metal tab like piece sticking out & on the left is a smaller squared like hole with a flat smaller metal like tab which will line up if the plastic strip is feed through the back of the cartridge carrier properly. This should allow the cartridge carrier to glide properly & work as it should, with no more banging.
Success
Jul 16, 2008 | Lexmark P4350 All-In-One InkJet Printer
Base removal of mounted plasma
Pls do not take any other screws, other than silver screws.if you take the 6 pcs of silver screws and pull the stand it will come out easily.
Sep 01, 2007 | Haier HL32BG 32 in. LCD Television
Kelty Base Camp Framed Baby Carrier Logo
106 people viewed this question
Top Kelty Baby Gear Experts
Andrew Taylor
Andrew Taylor
richie46
Dorel UK
Dorel UK
Are you a Kelty Baby Gear Expert? Answer questions, earn points and help others
