Question about Toro Lawnmower 20099 Mower Mowers Lawn
Stiff pull - wont start
Changed plug, filter and oil.
  • 63 Answers
Fully engage the safety bar
Posted on Jun 27, 2010
Changed oil in bmw e36 now spark plug socket and spark plug are showing engine oil (old) Shop gave me wrong oil filter so have not started car yet as I do not have the right filter Also I changed air
IF there is a sleeve around the spark plugs then when replacing the plugs replace the seal under that sleave as well or rocker cover oil will leak out past the plug base.. If you want the correct oil filter you may have to buy genuine . Run fault codes to find the reason for rough idle . It may be a vacuum hose is off or cracked or loose.
Feb 16, 2014 | BMW 318 Cars & Trucks
We changed the oil and oil filter, changed the air filter, changed the fuel filter, changed the spark plugs, and put injection cleaner in our 1994 Ford Explorer Limited and we are getting horrible fuel...
Clean the throttle plate-CRC Throttle Body Cleaner
Clean the MAF Sensor--CRC MAF Cleaner
Have the O2 Sensors tested
If it is 10 years old, the exhaust
converter may be plugged,that's
not good and shouldn't happen
Check for vacuum leaks
A leak causes the O2 Sensors to add fuel,
to account for extra air
Make sure the air filter box and ALL
Ducting to throttle is air tight
Dec 18, 2010 | Ford Explorer Cars & Trucks
Oil leaking,changed oil driving home 1,5 miles oil leked out filter tight and plug in drip pan
The gasket on the oil drain plug in the oil pan may have dropped off when it was removed and/or the filter may be installed with two gaskets.
Sep 19, 2010 | 1998 Saturn SL
I have a 2003 Subaru Baja with 126k. Recently has developed what I thought to be a misfire. When I pulled the spark plugs they were loose and covered with oil. I changed the wires and plugs and still have...
I would replace the filter and verify the fuel pressure. should be 30-40psi but I dontt have the exact spec. The oil in the plug tubes may be caused by leaking valve cover gaskets.
Sep 06, 2010 | 2003 Subaru Legacy
Oil in air cleaner
Run it minus an air filter until all the oil is off your piston head, you can also try keeping the plug out and ejecting the oil via that access by pulling the cord. It seems like you've already solved the problem, now you're just cleaning up.
Apr 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My daughter tells me that the mechanic at a garage in town tells her that the OIL FILTER doesn't have to be changed.Is that correct???
If it has an oil filter that can be removed, then it has to be changed at least every other oil change. Better repace with every oil change. Some modern cars as some european sedans (bmw and mercedes) as well as some fancy corvettes and probably vipers, do not have external oil filters and do not even have a dipstick. On this cars, the oil is special to be changed every 30 top 50 thousand miles, but even on this vehicles, there is an internal oil filter that also has to be replaced.
Sep 25, 2009 | 2004 Mitsubishi Outlander
When shall I change the oil filter for my C230 Kompressor
check your owners manuel..if you have none than purchase one.
I would say leave them alone .
Aug 28, 2009 | Mercedes-Benz C230 Cars & Trucks
Sudden drop in gas milage from 2o to 13mpg
old car, when rings begin to wear oil leaks into the combustion chamber burning more oil and reducing mpg try a product called restore and use it at every oil change also make sure you dont have black oil and that you are changing the oil at regular itervels also plugs wires roter cap and fuel filter and air filter are changed any abuse to these areas will reduce engine life i change my 350000 mile car every 500 miles reusing my filter everyother time
Jun 02, 2009 | 1991 Cadillac DeVille
I have a 95 honda accord sputers at stop
getting oil on my plugs on 97 honda accord any help or suggest
Mar 17, 2009 | 1995 Honda Accord
Toro Lawnmower 20099 Mower Mowers Lawn Logo
131 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
