Question about LG WM1814CW Front Load Washer
LG ERROR CODE UE MODEL 1812CW I THINK IT MEANS UNBALANCED LOAD NO LOAD IN WASHER STILL CODE HOW TO CLEAR
  • 10,515 Answers
UE Imbalance error One of the following:
The load is too small
The appliance is tilted
Laundry is gathered to one side
Non-distributed things are put into the drum
If you have made sure that, there are no problem with above mentioned conditions, then Then I would say you have a bad motor. The motor has a tach in it that tells the control board if the load is balanced. If the tach is bad in the motor then it will always think the load is unbalanced.
You have to replace the whole motor the tach isn't separate. I think I would call a tech out there to diagnose it
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 14, 2010
Why do all loads in our Top Load HE Washing Machine - Model # WT5070CW - stop because of UNBALANCED LOAD ERROR?
1st check ur floor level if the floor level is not flat means sure the error will come.. and dont put a blanket with other clothes
Feb 26, 2015 | LG WT5070CW White Top-Loading Washer
What is the UE error code on an LG front load washer
hi,
the code UE means that the load is unbalanced,, just shift the load evenly and restart machine.
chris...
Sep 20, 2012 | Washing Machines
Hi, I have a washing machine that got error code UE. What does it mean?
Hi Its a Unbalanced Error code their is a switch that can tell its unbalanced
Mar 25, 2011 | LG WM1812C Front Load Washer
What does UE mean on a 4kg LG washer drier??
Hi!! UE Error Code is indicative of a "Unbalanced Error". This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum.
Don't forget to rate this post!!
Sep 15, 2010 | Washing Machines
My Lg washer is showing a code UE and then PF what can I do to fix this problem.
UE means that the load is unbalanced in my LG. The code PE means that the water sensor is malfunctioning and needs replacing.
Feb 13, 2010 | LG WM-2277HW Front Load Washer
Error code UE
UE Refers that the Unit is Unbalanced. Take out the clothes out of the washer and then Run the washer. Does it Spin?
If yes, then it might be Unbalanced Load. Try to Load Small Clothes. If not, or if the Error is Appearing again and Again, Control Board or the Sensor is at Fault. You cannot Test the Control Board or the Sensor but usually Sensor is the Common Problem with Most of the LG Washers.
So, First Change the Sensor. If Problem Persists, Change the Control Board. On Most Models, Sensor would be Located near the Front of the Unit on the Side of the tub.
Let me know, if needed further assistance.
Hope i helped you.
Dec 26, 2009 | LG WM2496H Front Load
LG front load washer coded UE. what does that mean?
UE means unbalanced error. when you see this, it means the clothes are unevenly distributed in washer, it's basically unbalanced.
Dec 03, 2009 | LG WM-2077C Front Load Washer
Error reading
An UE Error Code is indicative of a "Unbalanced Error". This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum
If you tried out all things and it did not work,
then I would say you have a bad motor. The motor has a tach in it that tells the control board if the load is balanced. If the tach is bad in the motor then it will always think the load is unbalanced.
Hope i helped you.
Sep 06, 2009 | LG WD-1045FH Front Load Washer
LG WM1814CW Front Load Washer Logo
89 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
