Question about Dell (6F858) Cooling Fan
Dell Latitude 610 MATS Error F200:0119
So, my son upgraded my laptop with 1 gb of memory (had 256 Mb). Now I am getting this error message. I see that it could be bad ram or the laptop is heating up. I am not sure how to proceed.
    Genius:
  • 1,027 Answers
Could be the wrong memory type was installed:
Specs are Up to 2048MB using 533MHz DDR2 SDRAM
Posted on May 14, 2010
I just upgraded a D600 to 2GB (2x1GB) of RAM, and I'm getting all kids of BSOD with various messages. If I reinstall the original 2x256MB, it will boot. PNY memory tech rep says I need to specify some...
Dell BIOS does not have any memory related settings. Please try with only 1 GB at a time if you still get the issue, change the 1 GB with the other module. If it works with one of the 1 GB module, then but not with other then the issue is with the RAM module. If it works with 1 GB 1 at a time then the issue is that your motherboard is not supporting 2 GB.
Since your computer is used to 2 X 256 = 512 MB of memory, it could also be because of windows settings still maping to the old capacity, hence you can also try reinstalling the operating system (keep this as the last option)
Mar 08, 2011 | Dell Latitude D600 Notebook
I have a deskstop while am put new os for my computer in the drive capacity was just 15 gp in that all the process will completed after the computer will get started there shown the message (there is low...
FIRSTLYThe error shows that your RAM is less i.e. 256 MB not your hard disk. You have a hard disk with capacity of 15 GB but your RAM is 256 MB only. You might be installing either windows Vista or Windows 7 because your system does not meet the minimum system requirements. You need to upgrade your system hardware or you can install windows xp.
SECONDLY You have to install the windows in your desktop only because if you install the windows in your laptop, then all the device drivers will be installed for your laptop only. So it is mandate to install the windows in your desktop only until you are using any third party tool.
Regards
Manjeet
Jun 14, 2010 | Dell (002TR) Motherboard
I have a Fujitsu Lifebook E2010 with one 256 MB RAM module. When I try to upgrade to one (or two) 512 MB standard Kingston memory (266MHz Pc2100), the notebook won't boot, I only get 1-3-3-1 beeps which is...
Make sure that you got the right memory module with this specs:
Memory
  • DDR266 (266 MHz) so-DIMM 200 pin
  • 2 DIMM slots; upgradable to 1 GB total memory (512 MB x 2)
or better go to this link http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=GUIDES
there's a step by step troubleshooting for memory modules. Also make sure you purchase memory module from Fujitsu or Authorized Fujitsu Dealers .
You can also find us over the web, visit us at www.fujitsu.com or for Around-the-Clock Expert Technical Support you may contact us at :
Phone Support (Direct to Service Desk)
1-800-8FUJITS (1-800-838-5487)
Available 24 hours, 7 days a week.
Consumer Sales - 1-800-FUJITSU
Corporate Sales - 1-800-831-3183
Tech Support - 1-800-8FUJITS /1-800 8385487 or 1- 888 -3854212
-ERNZ
Feb 03, 2010 | Fujitsu LIFEBOOK E2010 PC Notebook
I want my Laptop Dell Latitude C800 physical memory upgraded to 128 mb to 256 mb I myself already installed 256 mb Ram but it still showing 128 mb of memory...can I get help in this regard ?
I assume you installed another 128Mb of RAM to give you a total of 256Mb.
It is most likely the 2nd RAM module is not compatible with the other RAM module. Try using the same make.
OR
Purchase and install a single RAM module 256Mb or 512Mb these are not expensive.
Dec 20, 2009 | Dell PowerEdge 2600 Server
Upgrading ram in a dell 5150 do I need to install 2 menory boards of the same size at the same time. I have two 256 mb and I am trying to install 1 512 mb to expand the menory to 1 gb It works for awhile...
you have 4 memory connectors. the maximum memory the computer supports is 4 GB. it is recomended that you install in pairs, for some reasons, but i have installed and i have seen it doesnot matter at all. you can go ahead and install the memory for whatever size on the computer. make sure the bus speed should be either 400 or 533 MHZ. and yoou never explained the error message. when you upgrade the ram you will get a message the system memory has changed press f1 to continue or f2 for setup just press f1. if the error message is in windows after you click on your name it has nothing to do with your memory. if its before that. than try to reseat the memory. installing memory in non pairs doesnot cause any problem most of the time. explain the error message only than i can guide you furthur.
Oct 16, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
My Dell C600 won't recognize the 2 new 256 mb sticks of RAM
i think you need a same brand of 256 for it to work? and when you buy something for your computer make sure that the one you both is the same brand or code with your 128 for example you have 128 ddr2 sdram so you can only upgrade it with 256 ddr sdran or 512mb,1gb,2gb ddr sdram.
May 01, 2009 | Dell Latitude C600 Notebook
Inspiron 6400 notebook
There are two slots for memory on that laptop and it will take a maximum of 2GB of RAM. The memory type is 1.8-V SODIMM DDR-2.
The cover ont he bottom if the laptop is easy to access and add more memory.
Dec 31, 2008 | Dell Inspiron 6400 Notebook
How to upgrade a Dell Latitude CPX - Intel P3 500-650 laptop
I have a CPX H500GT. To get it to run XP Pro to run right, max out the ram. And get a larger harddrive. Xp uses a substantial amount of space.
Sep 22, 2008 | Dell Latitude CPX Notebook
RAM Memory upgrade: 1gb modeles recognized as 512mb
You may have incompatible memory. double check your order and use only recomended name brand memory such as Kingston, you can look up the correct memory on their website, or on newegg.com
Apr 23, 2008 | Dell OptiPlex GX270 PC Desktop
Dell (6F858) Cooling Fan Logo
254 people viewed this question
Alun Cox
