Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
I need to know governor spring location on vanguard twin v 12.5hp engine
5 Suggested Answers
SOURCE: need pictures of governor springs and governor
model # 12f702-1824e1 mower( that uses weedeater string) had a spring come off the carberator and I don't know where to put it back on.
Posted on Apr 19, 2009
gill73115
  • 6 Answers
SOURCE: Engine appears to run normaly until PTO is
Check you float in the carb I had one a few years back and it was partualy plugged cleaned it out and everthing worked fine. Also is the PTO binding up or bearings going bad putting an excessive load on the motor.
Posted on Jul 08, 2009
  • 241 Answers
SOURCE: What is the electrical device on the carb of a
Yes if it is what im thinking it is its a fuel cut solinoid
Posted on Mar 24, 2010
suzukiracing
  • 200 Answers
SOURCE: I have an 18hp v twin vanguard and it is
Piston rings being wore.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Posted on Jul 20, 2010
Need to know where the springs hook to the governor arm on a 25hp v-twin intek i/c briggs 445777-0129=E1
The spring goes on the second whole in the govner rod at the bottom of motor.
Aug 05, 2014 | Garden
Briggs and Stratton 17HP Intek Governer Overspeeds
Can you Regulate the Engine Speed Using the Governor Arm? If Yes, then Reset the Governor. **To Reset the Governor; Loosen the Governor Arm Bolt and Turn the Governor Shaft Clockwise Until it Stops. Using the Governor Arm Hold the Carburetor to Full Throttle. Now with the Shaft Full Clockwise and the Governor Arm and Carburetor Held at Full Throttle, Tighten the Governor Arm Bolt. If the Engine Still Runs Full Throttle, then Reverse the Rotation of the Governor Shaft, but Still Hold the Carburetor at Full Throttle with the Governor Arm. If it Still Runs at Full Throttle, then Check the Internal Governor.** If you Can Not Regulate the Engine Speed Using the Governor Control Arm, then Check the Carburetor Throttle Valve. If the Throttle Control Valve (sometimes called a Flap or Plate) Mounting Screws Came Out of the Control Valve, then you will have No Control Over the Engine Speed. Send me the Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you. **The Throttle Cable Attaches to the Throttle Control Bracket. The Cable Moves a Slide that Moves a Pivot. The Pivot has the Spring Attached to it and to the Governor Arm. The Solid Link Connects to the Governor Arm and goes to the Throttle Shaft on the Carburetor. When the Throttle Cable is Moved it Moves the Pivot and the Pivot Pulls the Spring. The Spring Pulls the Governor Arm and the Governor Arm Moves the Throttle Shaft. Usually the Spring is in the Lower Hole in the Governor Arm and the Solid Link is in the Top Hole of the Governor Arm.** If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens
Sep 23, 2008 | Garden
I need to know where the springs hook on the governor arm on a 445777-0129-E1 briggs 25hp v-twin
on the governor rod there should be a spring that gos around the rod and hooks on both ends of the rod .then theres a spring and its very important that it is the right tension spring,go to a dealer and have him look up the correct spring for that model once you get it the spring will accually make the governor sping the engine wide open till it starts but from the governor arm you should see a holder of some kind or a hole where a spring goes to,thats the best I can do for you without seeing it,the dealer where you get your spring may hae a diagram of it!
Aug 05, 2014 | Briggs & Stratton Garden
Revs racing on Vanguard twin 18hp
down load the manual pdf file from B& S on the model you have.
Jan 23, 2013 | Tools & Hardware - Others
How to set governor speed on B@S v-twin vanguard
It is a simple but tricky job to explain here..I suggest you go into utube and ask that very same question starting with utube and then the question there are good sites that cover this..good luck..
Jun 20, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Motor runs wide open when set @ slow speed
It could be that the governor spring has become disconnected or has broken on an end where it hooks onto the throttle linkage. If the spring is OK & throttle linkage is not binding it could mean the governor drive inside the engine has failed preventing the governor from operating correctly. You may need to take the engine to a mechanic to fix the problem.
Sep 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Think i have a problem with governor on my 21hp v-twin briggs. it jumped to max speed and can't get it to slow down. which part of the governoring system could have let go?
Check for a broken spring on the governor linkage, follow your throttle control cable down to where it attaches to the throttle mechanism. In behind where the cable attaches you should be able to see a spring on the governor arm, the spring may have broken or somehow came out of its attaching point. Obviously be very careful about over-revving the engine, it could result in a broken connecting rod and a hole in the side of your crankcase.
Aug 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs 14 HP Vanguard runs well until PTO is engaged
First thing u might want to check is the governor--Make sure the spring and linkage is hooked up properly and the governor is moving freely.
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Governor problem on 9 hp vanguard engine
Go online to Generac and they have parts list and owners manuals online. They will ship you parts.
Jun 25, 2009 | Generac 5724 GP Series GP3250 Portable Gas...
Need pictures of governor springs and governor
Apr 18, 2009 | Briggs & Stratton Garden
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
278 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Randy Schumann
Randy Schumann
Bill Boyd
nirodacyar
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
