Question about Nokia 6300 Cellular Phone
N6300 no signal
No signal. PA AND antina switch reheated but in vain .
waiting 4 ur expert view.
thanx in anticipation
How can i use wifi in my laptop without antina
check your laptop to be sure that your wireless capability is on, might be a switch on the front or it may also be on the keyboard that has a light. Otherwise check with a computer expert or with the manufacturer's manual to find where the wireless on/off button or switch is if it is not readily apparent.
Mar 22, 2012 | Computers & Internet
Nokia 8250 no signal
if you recently accidentally drop your phone then you need to open it and reheat the cobba i.c or known as the audio i.c for some cellphone experts. you need to have the following things. hot air and a flux. first you need to put on a flux above the audio or cobba ic and reheat it using the hot air. set the hot air to its proper setting and slowly reheat the audio ic for 2 to 3 minutes. and then let it cool for 3 to 4 minutes and then close back your phone. then for sure it gonna have a signal.be careful of reheating the audio or cobba ic. since its sensitive and don't try to move it, just reheat it. coz if incase you move it, it will cause you phone to recieve a contact service error.
Jul 10, 2011 | Nokia 8250 Cellular Phone
Will turn on for a few seconds and switches itself off again. will not charge while off.
reheat the power I.C then try to check the P.A if it is ground....
Jan 02, 2011 | Samsung Lands Phones
Signal problem
Dear customer
I will get vary happy to help u. If u are a Technician then open ur mobile handset by T-6 screw driver and firstly wash ur network antina and IC areas by a toothbrash with PCB cleaner.Check the network connecter make a jumper from network connecter to connecter pins by micro soldering IRON and give some hot air to network IC with pest.If u are not a technician then its better to go ur nearest NOKIA care center.If u are saticfied withmy information then please vote me. Thank you for your visit.
May 24, 2010 | Nokia 6300 Cellular Phone
No signal
Go to seting-phone setting-network, Choice search network manual.if show all operator the damaged are on PA (transmition IC).but if no operator found the damaged could be on antena or RF IC(as a receiver network)
May 21, 2010 | Nokia 7360 Cellular Phone
WindowsXP SP2Installation hangs in Compaq Presario 2000 series
minimum requirements for XP
PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
• 128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
• 1.5 gigabytes (GB) of available hard disk space*
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• CD-ROM or DVD drive
• Keyboard and Microsoft Mouse or compatible pointing device
Nov 07, 2008 | Microsoft Windows XP Professional With...
Samsung SGH E200 Secret Codes
how to change samsung e200 message tone
Oct 15, 2008 | Samsung SGH-E900 Cellular Phone
No Signal: Nokia 3100
go to the nearest cp tech.tell cp tech to reheat PA for your cp.tnx
Jul 02, 2008 | Nokia 3100
Antenna broke and I replaced it
If your not sure what to do at this point you probably should stop right here, however if your bold enough to try this, remove the back cover, I believe there are 6 (six) screws in total, there is also a small metal contact that touches the main circuit board on the back side, that also connects to the antenna, most often a springy piece of gold plated metal attached to a solid threaded nut, where the antenna is attached that fits snugly into the back cover of the phone when the cover is installed the nut is secured and won't fall out. This contact could be on the nut or on the main board if you bent it out a bit to make better contact, you will most likely fix your phone. Cheers!
Mar 03, 2008 | Cell Phones
Nokia 6300 Cellular Phone Logo
104 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
