Question about Patton Heating & Cooling
I moved and took my window mount (Model RH-70 with me, but it does not fit the type of window in my new apartment. Will it still work if used inside on a tabletop?
  • 4,924 Answers
It will work as long it has the opens out for to get air..and is well sealed....the reason why it is used outside at the window is just cosmetic...do avoid its presence inside..but if it is powered and have a opening to the air outside it will work ..
Posted on May 14, 2010
Cam timing for fiat siena 1.2 2001
There are no timing marks on this engine - the engine has to be "locked" using special engine locking / setting kit which you wil have to obtain to do the job.
I will give you the instructions to do the job for when you have the locking kit to do the job.. as follows:
Removal
  1. Raise and support front of vehicle.
  2. Remove:
      • RH front wheel.
      • RH inner wing panel.
      • Air filter assembly.
  3. Support engine.
  4. Remove:
      • RH engine mounting and bracket.
      • Timing belt upper cover,
      • AC receiver/drier (if fitted). DO NOT disconnect hoses.
      • Timing belt lower cover.
      • Auxiliary drive belt.
      • Support bracket between gearbox and cylinder block (Palio).
  5. Palio: Remove bell housing cover plate. Fit flywheel locking tool. Tool No.1.867.029.000. or equivalent commercially available.
  6. Remove:
      • Crankshaft pulley bolts
      • Crankshaft pulley
      • Spark plug leads.
      • Ignition coil and bracket.
      • Spark plugs.
  7. Fit dial gauge and adapter to No.1 cylinder. Tool No.1.860.895.000.
  8. Turn crankshaft to TDC on No.1 cylinder. Set dial gauge to zero.
  9. Ensure notch in rear of camshaft aligned as shown.
  10. Install camshaft aligning tool. Tool No.1.870.823.000
  11. NOTE: If camshaft aligning tool cannot be fitted: Turn crankshaft one turn clockwise.
Installation
  1. Ensure No.1 cylinder at TDC by turning crankshaft slightly clockwise and anti-clockwise. Use dial gauge .
  2. Ensure camshaft aligning tool fitted correctly
  3. Hold camshaft sprocket. Use tool No.1.860.831.000/001
  4. Slacken camshaft sprocket bolt
  5. Fit timing belt in following order:
      • Crankshaft sprocket.
      • Water pump sprocket.
      • Camshaft sprocket.
      • Tensioner pulley.
    NOTE: Observe direction of rotation marks on belt.
  6. Fit tensioning tool locating pegs to tensioner pulley holes -Tool No.1.860.745.100/300. Ensure tensioning tool arm is horizontal.
  7. Set weight at 70 mm mark on scale bar.
  8. Hold camshaft sprocket
  9. Tighten camshaft sprocket bolt - Tightening torque: 70 Nm.
  10. Remove aligning tool
  11. Turn crankshaft two turns clockwise.
  12. Ensure No.1 cylinder at TDC by turning crankshaft slightly clockwise and anti-clockwise. Use dial gauge
  13. Ensure camshaft aligning tool can be fitted - If not: Repeat installation procedure.
  14. Tighten tensioner nut to 28 Nm
  15. Remove:
      • Tensioning tool
      • Camshaft aligning tool
      • Dial gauge
  16. Install components in reverse order of removal.
  17. Tighten crankshaft pulley bolts - Tightening torque: 20 Nm + 90°.
Jun 26, 2016 | Fiat Cars & Trucks
How do you fix a Moen Towel Bar when the mounting system has come apart from the wall?
There are larger screw-type anchors available at a hardware store. If the hole is a half inch, you can possibly use an expanding wing type "molly" anchor. it's hard to assemble the screws through the bracket, then put on the butterfly, and shove the folded butterfly into the hole, but it's doable.
Jul 28, 2014 | Moen YB2218BN: Brantford 18 in. Towel Bar...
Where do wires 1 and 2 go when im fitting a new screen to a compaq prsario C700
I presume you are referring to the Wireless Antenna wires,
http://www.pchub.com/uph/model/0--8407-2/Presario-C700-Series-parts.html?ps=20&type=0
They mount to the Display Enclosure.
The top cover of the laptop when it's closed.
(And mount behind the LCD screen)
One to the Left/Top side, one to the Right/Top side.
Who took it apart?
Think you better have the Service Manual, Mark;
http://www.fixya.com/support/t16425078-fit_new_screen
Page 59.
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 07, 2013 | Computers & Internet
I have a sony alpha 100 i want to buy a 1993 minolta maxxum 3xi with 35-70 and 70-300mm lenses. Those minonolta lenses are compatible with my alpha?
I took the following off of the Alpha website
"Sony Alpha lens mount
Identical to the Minolta A-type bayonet mount, enabling the use of a large back catalogue of existing Minolta and third party lenses"
I know that the lenses that fit my son's Maxxum will not fit my non-Maxxum Minolta bodies. VERIFY THAT THE LENS YOU WANT TO MATE TO YOUR SONY HAS THE MINOLTA A-TYPE MOUNT.
Oct 14, 2009 | Quantaray 50mm f/2.8 AF Tech-10 for Canon...
Sony a100 match ups
Yes, when Sony took over Konica Minolta they inherited the Maxxum lens mount (Minolta's AF lens mount system). the only Minolta lenses which don't work are the earlier manual focus type.
Sony have finally launched three new models which are the first to be clearly Sony designed, but they have still retained the Maxxum lens mounting.
Jul 03, 2009 | Sony Alpha DSLR-A100 Digital Camera
I forgot my security code for my nokia 1110(i) my imei is-356268/01/510003/8...thanks
IMEI: 356268015100038Mastercode: 6446016173
Use this calced 10 digits mastercode at the same points where the phone normally asks U for the security code.
Jun 01, 2009 | Nokia 1110 Cellular Phone
Climate control
You need a temperature control actuator..which mounts on the rh side of the central air con ducting under the dash.Remove the ducting panel on the rh side (3) bolts, then the glove box (2 bolts) then unclip the wiring harness connection box and push aside. Using flashlight look into the center at the central venelation ducting box, on the rh side there should be two raised bolt holes, where the actuator mounts over the white spindle shaft.
Apr 26, 2009 | 1998 Buick Park Avenue
Windows dont move down or up
you have to rebuild (which can be ghetto rigged, but never is reccomended) or replace the window winder units. they can be removed, find the rail which those loose cables came from and remove it, it should be an assembly with the winder motor attached. be sure to remove the bolt that attach to the window mount also. if you can locate the place where the end of the cable is supposed to mount (on a little slider thing) and make a new mount for the end of the cable, then take apart the winder motor spool, and re wind the cable inside the spool, then put it back together, you have ghetto rigged yopur winder. if you cant do all that, you will have to replace the whole unit at a cost of around $120.
Sep 28, 2008 | 1993 Mitsubishi 3000GT
Through the wall vs. window installation
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
Apr 09, 2008 | Frigidaire FAC124 wall/Window Air...
Heating & Cooling Logo
29 people viewed this question
Top Patton Heating & Cooling Experts
Mack Baxter
tractorman44
tractorman44
Jay Finke
Jay Finke
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
