My washer door won't unlock - Washing Machines
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with if the door lock is stuck and wont unlock then you can pry it to open, and just don’t try too hard. The issue can be with the door latch that is stuck, to unlock it you can stick a flat screw driver behind the door latch and then lever it to open so that you don’t have to pry it to open. Once it’s done, please make sure to replace the door latch assembly to avoid any further issues. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 22, 2010
Door won't unlock and the washer will not start to fill.
Check and see if the door is jammed or there is fault in the lock.
Click this link for tips to reset the lock: Door lock
Check the continuity of the door switch and see if the harness connects to the control board to trigger the start cycle when the door is closed.
Jan 21, 2013 | Maytag MHWE200XW Washer
The washer was starting spin cycle. It stopped & started huming. The door won't unlock. It has water in it. unplugging hasn't changed anything.
If it has water in it it may not unlock the door, it depends on what type of door lock is fiited as it may be a pressure type. If you can get the outlet hose out and lower it below the level of the drum to drain the water that is in it then the door may open oncethe pressure is gone.
Dec 27, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Electrolus front load washer door won't open
Hello - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Nov 20, 2012 | Electrolux Eiflw55hiw Front Load Washer...
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
Washer won't unlock
These doors are usually on a timer and so won't be released for opening until a couple of minutes have passed by after turning the machine off.
Assuming you've already allowed for this, try giving the door a good firm push (closing) on the mechanism. It may just have caught partially closed.
Apr 28, 2012 | LG WM2455 Front Load Washer
My washer started and now it stopped and it won't cancel/unlock and the door will not unlock. I have tried to unplug and replug and it still will not start or unlock the door. My clothes have been...
the most typical reson the door wont unlock when cycle is finished is because not all the water drained properly due to a blockage in the filter for the drain pump. This tip i wrote explains how to take apart the washer and clean the filter on the pump.
http://www.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
If you find the filter on the pump to be clear the door lock asm. will need to be replaced.
GENE
Sep 04, 2011 | Kenmore HE2 Plus Front Load Washer
The door on the washer is locked and won't unlock. I have a load of towels in the washer, cannot get towels out. Please help me Thanks
HI - UNDER THE CORNER OF THE SOAP UNIT YOU WILL FIND A GREENISH YELLOW NYLON - PULL ON THAT TO UNLOCK THE DOOR.
Jun 24, 2011 | Maytag Neptune MAH5500B Front Load Washer
It won;t power up at all, clothes... Solve It won;t power up at all, clothes are locked inside, no lights on the panel. Plug in is working, I... (More) It won;t power up at all, clothes are locked inside,...
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
