Question about Kenmore HE2 Plus Front Load Washer
Door won't unlock
My washing machine is 4yrs old, relatively good service, but today the door won't unlock so i can get my clothes out. I tried the default button and even unplugged it and plugged it back,,,,
So any suggestions
  • 11,896 Answers
The door is locked so that water doesn't leak out. I am unfamiliar with the diagnostic code for Kenmore HE2, but for the Whirlpool Duet, the keypad sequence (after you plug the unit it again) is: DRAIN/SPIN,NO SPIN, AND THEN PRESS EXTRA RINSE 4 TIMES WITHIN 5 SECONDS. This (on a Whirlpool) will displace "COO" in the display, and by pressing Extra Rinse incrementally, you can proceed through the diagnostic steps, eventually unlocking the door. You will need to determine the fault code or error that stopped the machine though - the locked door is NOT the problem - it is a safety thing. If that sequence does not work, remove the bottom panel, and, with the unit unplugged, shine a flashlight up to around the door lock area. There should be a little black rubber tab at the bottom of the door lock. Gently pull on the tab, and the door should unlock
Posted on May 14, 2010
Sears washer elite he3 fills back up with water when off
You have to shut your wall inlet pipe after your wash is over. If the leak persists you only have to change the inlet valve, which you can do yourself, see internet for spares quoting your washer number, model. It is good to keep the valve closed when the machine has finished it's wash.
For unlocking hold down "end of cycle" button at right side of panel for 3 - 5 seconds. The door remains locked when there is water in the machine, it does not want to wet your floor. Today's machines are smart. Helped?
Mar 05, 2013 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
WFW94HEXW door won't unlock and Door Lock isn't lit
if you machine is warranty you must call to the whirlpool, and get the assistance via online chat. However you must wait about 180 seconds since you did the command STOP, and stop the motor, fi the water level is higher must be drain before the latch door unlock.
2) if do not obey press and hold END OF CYCLE, wait about 10seconds
3) reset the machine unplugged from wall by 45 minutes, and then plug again, and turn on and unlock the door
God bless you
Jun 21, 2012 | Washing Machines
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
I have a hotpoint ultima wt741 , 4yrs old , washine machine does not show that the door is closed , the red closed light does not now come on and machine will not start. l have removed top of machine and...
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 03, 2011 | Washing Machines
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
Machine is not spinning
check the carbon brushes in the motor or the belt.if its not these then it may be a timer fault see if you have power to the motor
Jun 02, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Washing machine previously off balance, I pressed cancel button
THERES A LOCK/UNLOCK TO THE FAR RIGHT OF THE PANEL..HOLD IT DOWN FOR 3 SECONDS - MY KIDS DID IT TOO
Feb 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Turns off during cycle
well lets see what happens then reply to me
Jan 28, 2008 | GE WSXH208A Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
37 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
