Question about Ricoh Aficio CL7200DT2 Laser Printer
Aficio MP 2000
We have acquired an Aficio MP 2000 copier/fax machine with the recent purchase of a business. Although we were able to find manuals that came with the machine, we can not find information in those manuals on how to "change the number of rings to 4 or more rings." Four rings are required for our securtity alarm on our building since it is hooked up through our phone lines. Please advise,
    New Friend:
  • 170 Answers
There should be a separate manual to cover the fax function in the machine. You can download one at
Posted on Aug 06, 2017
SOURCE: Ricoh Aficio FX10 Fax/copier
I called the Ricoh 800 number at 1-800-577-4264 and they found me a local tech to fix the problem it is a motor/or part proble code try the number and they can help you out.
Posted on Mar 31, 2008
  • 145 Answers
you must clean developer and drum section. after that you must put new developer and initialize it. After that place in correct toner.
Posted on Oct 15, 2008
SOURCE: Part Number for RICOH Aficio MP C3000 Fuser Unit
Part number is: B237 4053 (North America)
B237 4054 (Europe)
I Expect this will be very expensive as it is not designed to be replaced as an entire assembly, but rather repaired as needed.
Posted on Feb 23, 2009
SOURCE: Won't receive all pages of a fax. Generating service codes 00-83
That could be caused by a number of things:
Are you connected to the phone line by a very long telephone cable? This can cause extra interference and cause these codes. Or it could be a deteriorated cable...try another one.
otherwise, it could be a fax circuit board problem, but more likely you need to have the 'cable equalizer " adjustment performed in "service mode", which is a fairly simple adjustment for a service tech, but too complicated to explain here.
I hope this helps.
Posted on Apr 13, 2009
  • 566 Answers
SOURCE: How do I delete stored faxed numbers (speed keys)
From Ricoh Aficio MP2550 manual:
Delete destinations registered in the LAN-Fax Address Book:
numb01.gifOn the [Start] menu, point to [All Programs], [LAN-Fax Utilities], and then click [Address Book].
The [Address Book] dialog box appears.
If LAN-Fax Driver has already started up, click [Edit Address Book...].
numb02.gifClick [New/Browse...], and then select the CSV file containing the address list to be edited.
numb03.gifSelect the destination you want to delete so it is highlighted in the list.
numb04.gifClick [Delete].
numb05.gifClick [Yes].
numb06.gifClick [Close].
numb07.gifIf you made changes to a destination, a confirmation message appears. To save the changes, click [Yes].
If you do not want to save the changes and want to quit editing, click [No].
To return to the editing display, click [Cancel].
The confirmation dialog box does not appear when you have not made any changes after starting Address Book.
You can download the manual (HTML or PDF/ZIP versions) from here:
Posted on Jul 29, 2009
Mp 2000 sc 982
i'm guessing == Scan, Color
Jan 03, 2015 | Ricoh Aficio Mp 2000 Copy Machine
Out of focus
Out of focus - Ricoh Aficio MP C4500 Copier with Print, Scan, Fax, Finisher
Jan 29, 2014 | Ricoh Aficio MP C4500 Copier with Print,...
How do we get this machine (ricoh aficio MP 2000) to duplex print?
There are certain models that can duplex and certain models that can't. Generally if a Ricoh copier can duplex it has a D after the name (like 2018D). If there is no option for duplexing on the screen or the ops panel, that model doesn't support duplexing.
Apr 30, 2010 | Ricoh Aficio MP 2000 Black and White...
Ive recently purchased a RICOH Aficio Super 180 G3...used.
press the "user tools" botton, then select "fax option",than "program fax information".You can change fax header there. "Time and Date" usually in "System" submenu.
Sep 10, 2009 | Ricoh Office Equipment & Supplies
I have Richo Aficio MP 1600 all in one device-- Faxes fine, copies fine; Cannot get scanner to connect although Twain drivers are installed & device is connected to the network with its own IP address,...
Make sure the gateway is entered correctly, are you scanning to file or E-mail? Using web immage monitor is the easiest way to do it either way. if you have questions e-mail them to -Carl
Jul 07, 2009 | Ricoh Aficio MP1600SPF Copier
Ricoh Aficio  CL7200DT2 Laser Printer Logo
103 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
