I do not have the disc to transfer my pictures from my camera to my computer, what can i do?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
SOURCE: Can not transfer pictures
driver not needed for windows xp and above... camera shows as removable drive in MY COMPUTER list. copy and paste pics from camera to HD>
SOURCE: I lost the disc to transfer pictures from my
when you connect your camera to your pc, go to mycomputer and see if the camera appears as an external drive.
you will be able to copy your pictures from there
SOURCE: Camera will not read disc, I have formated disk
If you have moved pics from your computer to the card and then inserted the card into your camera, the card is now formatted to the computer, not the camera. You're supposed to format the card in the camera.
SOURCE: My camera doesn't transfer pictures to my computer
Hello and welcome to FixYa
Please go to a electronics store and buy a USB card reader. I bought one last week and it cost $0.5 so its cheap as dirt. Then simply remove the card from your camera , pop it into the reader and the pictures will appear on a drive like a flashdrive in your my computer folder.
This is a much better option than using the camera's cable as it is faster , safer , saves on your camera battery and you don't need to install any software or drivers.
Kind Regards
Andrea
SOURCE: I'm trying to transfer my
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
