Question about Troy-Bilt Pony Garden Tiller
2 extra wires
I just put back together a troy bilt pony tiller and i dont remeber were the two wires go
SOURCE: tilller will not run
Get the model # and serial # off of the sticker. Got to the Troy Bilt site and use the owners manual link. Need to leave off the last 3 numbers of the model #.
If that site does not have the manual, I've found them on the MTD site. I enter only the first 2 numbers of the model # and then hunt for my manual from the list.
If all else fails, you can call Troy Bilt at their # provided on the site.
Hope this helps.
Posted on May 20, 2009
  • 112 Answers
SOURCE: i'm trying to find an operating and parts manual
go here http://troybilt.manuals-website.com/cgi-bin/pony_manuals.pl
Posted on Jul 15, 2009
  • 112 Answers
SOURCE: I have an older Troy-Bilt Pony Garden Tiller witha
From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at kerryjonjon@yahoo.com and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
Posted on Jul 18, 2009
al_kupchella
  • 843 Answers
SOURCE: broken pull cord on my manual start Troy-bilt Pony
It's definitely do-it-yourself in that no special tools or skills are required, but it can be a little tricky. You can see that the the recoil starter is in an assembly which is spot welded onto a metal cover. You have to remove the entire metal cover that includes the recoil starter. There may be 6 to 10 screws to remove to do that. When you get it off you will see a plastic spool that holds the cord. This spool is probably held in place by a couple of metal tabs that are bent down. Bend those tabs up with pliers. Underneath the spool is a spiral spring that provides the recoil. Take careful note of how this all goes together. Buy a new cord (available by the foot at a hardware store) and wrap it around the plastic spool. Use a piece of tape to hold the end of the new cord above the spool so you can thread it through the hole in the metal housing later. Put the spring and the spool in place, then wind the spool to put tension on the spring - about 5 turns in the direction that would push the string out through the hole. Once you have the spring "wound up" remove the tape and thread the end of the cord through the hole. Now bend those metal tabs back down. Put the handle on the cord end (or tie a knot) to keep the spring from pulling the end of the cord back through the hole. Reassemble the rest and you are in business.
Posted on Jun 15, 2010
  • 26 Answers
SOURCE: i need a free owners manual
http://manuals.mtdproducts.com/mtd/Public.do
Go to the above website and type in 12211 for your model number and 1 for your serial number. You will be able to download a free copy.
Frank
Posted on Oct 08, 2010
Troy bilt pony,moves so fastu cant hold it back,??????
I found that when you have the tiller at full throttle it can get away easily. Try pulling back the speed a bit and change the depth of the tines to grab a bit more but not enough to launch it. Good luck! Hope this helps you. Cheers, Michele
Oct 20, 2014 | Troy-Bilt Pony Garden Tiller
Need gasket carbereter kit
I have been trying to help you. It appears that the "pony" model has submodels as well I will send you this link and please post back with which model is yours. Model numbers are the BIGGEST help I get, because I can research this machine all day and not have the correct carburetor for your exact model. Here are the current Troy Bilt "Pony" Tillers for sale on the net.
http://www.bing.com/shopping/search?q=Troy+Bilt+Pony+Tiller&FORM=HURE
Again, please reply. I will get your reply and continue to assist you. Thanks!
Jul 04, 2011 | Troy-Bilt Pony Garden Tiller
Troy bilt pony 5hp rear tine tiller is leaking behind muffler on side of motor
Head bolts are probably loose, check the 3 nearest the mouffler and of course check all of them.
May 09, 2011 | Troy-Bilt Pony Garden Tiller
I need a manual so I can maintain a used Troy Bilt Pony tiller.
this is one of the largest on-line sights for free repair and operating manuals.
http://www.manualsonline.com/?src=12022010
May 04, 2011 | Troy-Bilt Pony Garden Tiller
Hi there i have speedy hoe model#352 i did tune it up and now i do not know how to put back small spring which is close to air filter ,and there is also about 1''of wire that conects to carburetor and...
I'm sorry I don't have a solution for you but I have a similar situation. Don't know what goes where. Do you have an Owners Manual for that unit? Much appreciated if could get a PDF copy e-mailed to me.
Feb 13, 2010 | Troy-Bilt Pony Garden Tiller
Jul 17, 2009 | Troy-Bilt Pony Garden Tiller
Troy bilt pony left side tine assembly fell off
sounds like the shaft is either bent,or the inside diameter is worn and the shaft tube needs to be replaced.
Apr 23, 2009 | Troy-Bilt Pony Garden Tiller
Troy-Bilt Pony Garden Tiller Logo
18 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
