Question about Health & Beauty
Replace battery how to get bottom of case off in order to replace battery
  • 4 Answers
Depends on waht kind of shaver do you have. I just changed battery in my remington R650. There are 6 screws to hold the shaver together and they are all hinden. Step 1 to take off the shaver blade assembly on top. It is very easy because it is linked by a wire spring. Two scews will revealed and took them out using a philips screw driver. Then take top black part off then threw shafts to drive the blades will come off together. Then took the trim off. It will take some time. I have to take a piece by piece. Then take two red plastic covers pieces off which will reveal 4 screws under it. I use thin knife to pry them off. After you take off 4 screws, the shaver will be open. You will see the two NiCd 600amh batteres connected serial inside the shaver. They are soldered through wires to the PCB.
Posted on May 30, 2010
My battery is so shot that it will hardly run on 110 AC anymore - takes it hours just for it to run. How much to get this razor refitted with a new battery?
You can do it yourself if equipped. First, remove the foil and cutter. Then remove the swivel frame by removing the two tine screws, Next, remove the two scew covers on the bottom. These are found on either side of the plug recepticle and look like part of the trim. You can pry them off with a small flat jewelers screwdriver or similar. Remove the screws underneath. You can then gently pry the front of the case off from th bottom. Once case is removed, you can lift out the circuit board to access the battery. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find compatible battery type at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
If this is not something you can do yourself, shaveroutlet.com can do it for you. See info and ordering at the link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Jan 13, 2011 | Braun Flex Integral 5314 Electric Shaver
In what order do the batteries go in on the Black & Decker ATM100? which go in top down? and which go in bottom up?
Take a look at the inside of the Battery cover. You will see a (-) and (+). Look at your unit from the bottom with batter case away from you. Insert batteries with Neg up, Pos up, Neg up, then Pos up.
Hope this helps
Dec 31, 2010 | Black & Decker Black Decker 25 Ft Powered...
I have a braun 5564 electric shaver i think the battery is dead can i get a new one and how do i replace it
You will need to replace the battery pack. Depending on when your shaver was made, it may have one of two different battery types. You will ned to look inside to see which you need before ordering.
To open, remove the two round screw covers on the bottom of the shaver. Remove screws to remove bottom of shaver. The outer case will then slide off the bottom. Push the trimmer up to be abl to take the circuit board out. BE CAREFUL not to detach trimmer oryou will not likely get it back on yourself.
Your battery(s) will be one of the two types below found at shaveroutlet.com
http://shaveroutlet.com/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Be sure to read the Note on the second link concerning instalation
If you are unable to do this yourself, shaveroutlet.com can do the repair for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Oct 28, 2010 | Braun Flex XP 5614 Electric Shaver
How do you open a TI-30Xa in order to replace the battery?
To replace the batteries:
• Remove slide cover. Place calculator face down.
• Using a small Phillips screwdriver, remove screws from back case.
• Remove back case.
• Remove discharged batteries.
• Install new batteries positive side up, as shown on diagram inside case.
• Run a coin across the reset pad on the upper right hand corner of the printed circuit board.
• Replace back case, and then replace screws.
• Press [OFF], [ON/C], [ON/C].
Note: The calculator cannot hold data in memory when batteries are removed or become discharged.
Oct 07, 2010 | Texas Instruments TI-30XA Calculator
I recently ordered a replacememt battery for Nuvi 255w. I received a kit and new battery. How do I open it?
At the bottom of your device you find the label with all relevant data like type, serial number etc. This label can be easily removed by cautiously lifting one site and pulling it off. Under the label there are 2 screws which must be removed. Then you can open the case using the blade of a screw driver or a similar tool. Be cautious not to destroy the cable from the board to the screen. When the case is opened you'll find three small screws on the PCB which must also be removed. There are two connectors which can easily be removed: The cable to the speaker and more important the cable to the Li-ion battery. The battery is fixed by some clue in the case under the PCB. Replace it and reassemble the device. I hope this was helpful. Regards A. K.
Jun 17, 2010 | Garmin Nuvi 255 GPS Receiver
My Braun 5564 electric/rechargeable razor will no longer hold charge. Suggestions please on repair or battery replacement?
Feb 05, 2010 | Braun Health & Beauty
I have a Braun model 7526 shaver and the batteries need to be replaced. I just ordered them and they come together on the circuit board. I'd like instructions on how to open the shaver's case and replace...
You will need to first remove the 'cap' on the bottom of the shaver. This is a piece of plastic that surround the hole on the bottom of the shaver where the cord plugs in. Gently pry it off with a small flat screwdriver or similar object. Once removed, the side grips will simply pull off revealing 4 screws on the back. Remove screws to remove the back cover.
From there it is a piece of cake. The internal components simply lift out.
Put it back together in reverse order
Jan 20, 2010 | Braun Syncro 7526 Electric Shaver
Need to replace the cmos battery on a gateway 450sx4 laptop.
Some are way deep inside, and you have to remove the top part of the case from the bottom.
Some others, you can remove the top power strip, (unscrew screws in the battery compartment, and sometimes on the bottom) and then unscrew the keyboard, and when you remove that, sometimes you can get right to it.
The only problem is, some of the laptop batteries are odd ducks, and not just the standard, they have wires or a metal tag on them. You can always order a new one onces you get to it.
Apr 12, 2009 | Gateway 450SX4 Notebook
Remington MS2-250 shaver disassembly?
This shaver was pretty clearly not designed for battery replacement. To open, first remove the screen and blades, and unhook the metal collar from the tab on the back of the case. Then carefully pry off the black inset on the front of the shaver. Underneath it, near the bottom are two screws. Remove these. The case is now only held together by several plastic latches, which can be carefully pried apart with a small screwdriver. The two 2/3A size batteries are soldered to the printed circuit board, which can be pulled out (don't break the wires to the motor) by a little wiggling. The original batteries in mine are 1100mAh, and I have just ordered 1600mAh replacements. The new ones don't have tabs - so soldering them in place is probably going to be a challenge.
Good luck.
Aug 24, 2008 | Remington MS2-250
Cmos battery for C110 TCI
The CMOS Battery is behinf the main battery behind a platic shield. The shield is relitivly fragile and glued around the edges. Care should be used removing it to prevent ripping. The battery itself is 3" flat pack glued to the case. Mine was wrapped in a black heat shrink with two wires exiting.
The connector is under the keyboard. You will need to remove the 6 scres from the bottom of the case to release and remove the keyboard. The keyboard ribbon cable is attached through a ZIF socket. Be sure and release the cable before removimng the keyboard. Youll have to trace the CMOS battery leads to determine the correct connector.
I found a Maxell ML2032 rechargable battery. Unfotunatly all the 3" flat pack batteries I have found are LITHIUM ION and not rechargeable. If I find a replacement I will post the information.
Apr 27, 2008 | Acer TravelMate C110 Tablet PC
Health & Beauty Logo
817 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
