Question about Husqvarna Designer I
Thread breakage why does my top thread keep breaking and stitches are varied lengths??
  • 2 more comments
  • Margie Campbell May 14, 2010
    Not sure, do you have the tension too tight? is the thread caught somewhere? Rethread the machine from the beginning to end. Is the bobbin inserted correctly?
  • skf1851 May 14, 2010
    If the tension was too tight why would I have both long and short stitches??
    Tension can't be too tight or I wouldn't have irregular stitches would I? I may have to see if something is caught.
    I rethreaded it all last night and tried it again, Doing the same thing. How far to left do I go on the tension??
  • 29 Answers
You may have a small amount of lint stuck in the machine somewhere...or the thread is hanging up somewhere in the thread process.
If you have a drop in bobbin, make sure it spins counter clockwise when in the machine.
If you have a front or side loading bobbin...make sure that when you have the bobbin case (with the bobbin in it) laying in the palm of your hand, so you see the bobbin...that the bobbin spins counter clockwise (when the bobbin case is in the machine, the thread is going clockwise). This can be confusing.
Try a new needle.
Also, if you are working with cottons or any WOVEN fabrics, you want to use a sharp (topstitch is great, has larger eye for easier threading), or a universal needle. For Knits or polyester...fleece, minkie, etc...use a ball point needle. If you use a ball point needle on wovens, or a sharp/universal on knits, you will get skipped stitches.
When your machine is threaded, and the foot is down...pull on the thread (pull towards the back of the machine) coming out of the needle...the needle will flex a little (not a lot) and then the thread will pull out...will be hard, but the thread should not break. Most tensions for sewing are between 4-5 on the dial. If your dial has no numbers...then 1/8 of a turn, test & if its still breaking, loosen a tad more and try again.
Always hold onto the top and bobbin thread until you have taken a few stitches, this will prevent nesting and jamming.
I don't have a machine like yours, but am giving you what I have learned over the years from the many, many machines I have owned.
If none of the above work, you may need to have the machine serviced, as the timing may be off a bit.
Marge
Posted on May 15, 2010
Testimonial: "I did have some lint buildup but also a small amount of thread being caught. Timing was also off a bit and I marked the spot to set if it gets off time again. Great Job all of you, it helped alot!!"
When sewing it skips stitches also the thread keeps breaking.
Remove the thread from the machine.
Install a brand new needle.
RAISE the presser foot and rethread the top thread.
Verify the thread path is correct.
Load and thread the bobbin case & install it. Verify it is correct.
Set the top tension at the midway point.
Re-test your stitch.
Sewing Machine Problem 1 Thread Breakage
10 reasons for skipped stitches
Mar 22, 2017 | Sewing Machines
My mb4 is stitching designs off centered and when i started the machine it hit the hoop and broke the needle. i replaced the needle but now the thread keeps breaking?
Remove the thread and rethread. Usually, thread breakage occurs when the thread is not following the thread path. However, there could be other reasons:
Nov 14, 2016 | Sewing Machines
I have a Janome 1600P and the top thread keeos breaking
There are several common reasons for upper thread breakage.
Check that the needle/thread/fabric are compatible.
All About Needles
Remove the upper thread from the machine, install a brand new needle, ALWAYS RAISE the presser foot, and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point.
NMSU Checklist of Common Machine Troubles
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
Oct 29, 2016 | Janome Sewing Machines
Kenmore mini ultra The top thread breaks off from needle after a few stitches. The bobbin seems to Be catching the top thread. Thank you. ??
If the top thread sews a few inches and then breaks, something is catching the top thread and holding it until it breaks. Usually, this will happen when using the old style thread cones with the slit in the edge to keep the thread from raveling off the spool. To prevent the thread from hanging up, turn the thread spool over so the slit is at the top instead of the bottom. Sometimes top thread breaks will happen if the thread becomes looped around the thread spool pin.
Remove the thread, ALWAYS RAISE the presser foot and then rethread the upper thread. Verify that the thread path is correct and that the thread has not looped around a guide.
If the thread is fraying at the needle eye, the needle/thread are not compatible. Also, the tension may be too high.
Check that the upper tension disk is clean--no gunk buildup or thread pieces stuck.
If the thread is actually breaking when it penetrates the needle plate hole, there may be a burr or nick somewhere below that is catching the upper thread. You can wrap your finger with a piece of fine fabric, like an old pair of hosier, fine knit fabric, etc. and running your finger around in the bobbin area, under the needle plate. If you get snags, then you have a burr or nick. If it is small, you can sometimes smooth it with a fine emery board. If it is a large burr, you may need to purchase a replacement part.
Why Does My Top Thread Keep Breaking Sewing Machine
Sep 05, 2016 | Kenmore Sewing Machines
Why the thread cracked with when i sticked with the machine
Thread breakage could occur for several reasons.
First, try a brand new needle.
Second, use only good quality thread--NOT old thread or bargain bin varieties.
Third, when threading the upper thread, be sure to ALWAYS RAISE the presser foot throughout the threading process.
Verify that the thread path is correct (consult the owner's manual). Incorrect threading will usually break the thread.
Check that the upper thread tension is set at the midway point between the high & low numbers.
Aug 27, 2016 | Brother ES2000 Computerized Sewing Machine
Upper thread keeps braking
Usually thread breakage is a result of incorrect threading or the thread tension set too tight.
Remove the upper thread. RAISE the presser foot and rethread from the beginning (verify the threading sequence is correct).
Check that the tension is set at the midway point between the high and low numbers.
Retest. If still breaking, there are other less common problems (thread/needle incompatibility, burrs or knicks catching the thread, etc) that may be the cause. Check the following web sites:
Why is my thread breaking
Feb 11, 2016 | Brother Sewing Machines
Bobbon thread is too losse /thread breaks no
Clean out the bobbin area.
Thread the machine with the presser foot up. This opens the tension so the thread can enter. Threading with the foot down closes the tension and the thread cannot enter as it should. When you sew, the top thread is loose and cannot properly connect with the bobbin thread to form a tight stitch. The stitching does not hold and pulls right out.
Thread breakage - top thread? Check the thread spool to be sure there aren't any nicks to catch the thread.
When the thread breaks, check the spool pin to see if the thread is unwinding too fast and wrapping around the pin. Thread nets can help stop this. You can find them at sewing machine dealers.
Mar 11, 2010 | Singer Sewing Machines
Sewing Machines Logo
203 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
