Question about Microwave Ovens
Cannot get hurricane spin mopto spin dry spins sround but does not wrig dry
  • 713 Answers
Please clarify your problem in order to get a comprehensive solution to your problem by highlighting the name and model of your unit.
thanks and take care
Posted on May 14, 2010
My washing machine do not spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 31, 2011 | Microwave Ovens
Upper and lower spray arms are not spinning
Check that the arms spin freely when spun by hand, then check the outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
May 06, 2011 | Microwave Ovens
Dishwashing tablet (the cleaning aid) stays dry during whole cylce.
The large arm that circles the top part of the washer should spin freely. I suspect a knife or fork has slipped and stopped it from turning.
Hope that helps.
Feb 27, 2011 | Microwave Ovens
Washing machine not spinning
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 08, 2010 | Siemens Microwave Ovens
Kenmore washer
Top loader? The basket at rest is slightly to the rear. Slow spin speed could be the brake hanging up or a worn clutch. If these are ok the spin tube bearings may be tightening up. Eric
Dec 04, 2009 | Microwave Ovens
My plate does not always spin, microwave seems to be working when plate spins otherwise it just make noise but doesn't heat up. When I move plate manually it sometimes help, so I replaced electric motor...
The heating issue is related to the high voltage fuse and the magnatron assembly as well as checking the high voltage cao and the protective diode if the unit has one. As for the spinning dish u neeed to make sure the voltage of the new motor is the same as the old one. otherwise u may have issues with the motor not being able to spin efficiently. Good luck.
Nov 15, 2009 | Microwave Ovens
Danby turntable keeps spinning
2 THINGS COME TO MIND--A BAD ELECTRONIC CONTROL PANEL (BEHIND THE KEYBOARD) USUALLY FROM A POWER SURGE,,,,OR A BAD SOOR SWITCH--THIS REPAIR WOULD NEED A TECH--TUNICA
Oct 30, 2008 | Danby DMW119 Microwave Oven
Glass plate not spinning anymore
yes it can be fixed , it is probably the motor that spins it or the circut that controls it
Oct 08, 2008 | Goldstar Microwave Ovens
Table not spinning
your oven is not spinning,when u put some load,either the motor which makes the spinning is not picking up the load,so u get the motor serviced or change the carbon brushes which comes in front of the armature of your spinner.
Apr 02, 2008 | Dacor DMT2420SS Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
