Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
When I turn on the pump it buzzes but doesn't turn the pump?
  • 8,404 Answers
Either your impeller is stuck or your start capacitor is failed.
Posted on May 16, 2010
Badger 5-81 motor buzzing, blades spinning, won't grind
Replace the whole thing. They are not that expensive and are easy to replace. The issue could be bad motor part or the shaft came loose from the grinding disk.
Jul 09, 2017 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Lg dishwasher ldf7932st motor starts but doesn't work
Is the water turned off? Dishwashers normally start a wash by emptying any waste water tipped into them during loading. Problem could therefore be a blockage somewhere, most likely in pump inflow under the filters in bottom of machine. Lift these out to check. Also check your sink drain isn't blocked and preventing the water from being pumped out.
Jan 19, 2013 | LG LDF7932ST Builtin Dishwasher
Power steering pump installation
Matt,
If you hear a buzzing or zinging type of sound when you turn the wheels right or left, that means there is still some air in the pump or pump return lines. To stop the noise and protect the pump, block the rear wheels, place the transmission in park, and apply the parking brake. Jack up the front tires approximately two inches from the ground, making sure they are supported with something strong under the chassis so that it doesn't fall. Loosen the power steering cap just enough to where it will stay on, yet release any remaining air from the system, start the engine, very slowly rotate the front wheels to the right then to the left, this will release any air from the pump and the pump returning lines. When you don't hear any of the buzzing sounds, that means the air was released. Turn off he engine, remove the power steering cap, you will see the small air bubbles rising to the top. If you get any more buzzing sounds from the power steering system, repeat this process adding just enough fluid recommended. I know this sounds unusual, I have worked on Dodges for 43 years and my dad the main mechanic taught me this from his experience. This will also work on many other vehicles with power steering. Hope this helps with your power steering installation.
Jul 28, 2012 | 1989 Dodge Ramcharger
Kenmore 80 didn't drain during the spin cycle and leak underneath machine. Makes buzzing noise in the wash cycles.
The pump is likely damaged if it was leaking. Look for a ring of melted plastic on the face side of the pump. Check to make sure the hole is not rounded where the motor shaft enters the pump.
I'd replace the pump just to make sure the washer doesn't flood some time in the future even if the pump turn out to be ok now.
Vlad,
First Choice Appliance Service. Sacramento, CA
Jul 05, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Motor won't turn on
CHECK POWER AT THE PUMP, MOTOR BUZZES ? YES CHECK TO SEE IF ROTOR TURNS, YES CLEAN START SWITCH, HAVE CAPACITORS CHECKED , NO ROTOR DOESN'T TURN MOTOR WILL NEED TO BE SERVICED. ROTOR MAY HAVE RUSTED TO STATOR OR LOCKED UP BEARING .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL
May 15, 2012 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Car want start
You should hear the pump in the tank buzz on for a couple of seconds when you turn key to ON. It will come on and pressurize the lines, and then shut off if the computer doesn't get a cranking signal from the engine. Do you hear the hum or buzz from the gas tank? If so, pump is working alright. If no sound, then the pump has either failed, or the power to it has been interrupted.
If the pump is working, and you know the fuel filter is good, you should have fuel under pressure at the fuel rail on the engine. The only thing left for fuel to get into the cylinders, is for the injector circuit to work and pulse the injectors. Post back if you ned to test the injector circuit-very easy with a test light.
Good luck.
Jan 29, 2012 | 2006 Dodge Stratus
GMC 2000 sierra pick up 1500 sounds like it wants to start but won't turn over. Battery sounds good so I guess battery and alternator are ok. For several years fuel gauge doesn't work and...
It sure could be. But, first...by "won't turn over" you do mean it cranks at normal speed but won't start?
A simple test of the fuel pump is to stand by tank and listen as someone turns key to on. When first turned to on, your pump will activate for 2 or 3 seconds, pressurizing the fuel system, and then shut off if the engine computer doesn't get a cranking signal. Do you hear it come on? If not, then something's not turning your pump on. If you can hear it buzz on briefly, then maybe it's your filter. Another test: Spray a little starting fluid into your intake manifold (remove the big hose going into intake manifold) while someone tries starting it.If it doesn't fire and try to stay running, then it's probably an ignition problem. But if it does fire off, then you know it's a fuel problem-likely your pump or filter. good luck.
Nov 07, 2011 | 2000 GMC Sierra
Frigidaire front load washer that will not start . it just buzzes. when it does start it stops after washing and leaves water in clothes asn buzzes.
it could either be a bad door switch or something stuck in the pump or a bad pump.if you set it to drain/spin will it drain out the water or does it buzz there?if it does drain i'd have to say you have a bad door switch.the model number you sent doesn't come up,you can unplug the machine,remove the hose that goes to the pump or run it before you unplug it and see if it's the pump making the sound or if the center of the pump can be removed to clean out the pump and check the pump for coins and junk,use a shop vac and vac out all the water in the tub and then lossen the hose or center of pump until water starts to leak out and vac it up as it comes out,check the pump and put it back together,add some water with a bucket or something and see if it drains out,if it doesn't drain and it sounds like the pump is making the noise you have a bad pump,if it buzzes and it's not the pump change out the door switch.the buzzing is electrical,things that could make this sound are the motor,the solenoids on the water valve or the door switch,if you can do some checks like see if it drains or try to find where the noise is coming from would be helpful.good luck and i hope this helps you out.
Oct 29, 2011 | Frigidaire ATF6000ES Front Load Washer
Hi my 3/4 hp 230/115 centurian is buzzing and i smell burnt electrics.....what do i need to order to fix?
If the motor can be turned easily by hand then sometimes the starting or run capacitor can be replaced with the same value device and the pump will run. If a new capacitor is installed and it doesn't run then the motor needs to be replaced. If the motor does not turn easily then usually the bearings are bad and the motor needs to be replaced. I hope this helps. The burned smell is either overheated wiring in the motor or a bad capacitor, etc.
Aug 05, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
I ran my flotec sump/effuent pump dry, model 001D05S. Now it buzzes and doesn't pump. Can I fix it, if so how do I take it apart.
Unfortunatly if you ran it dry for very long it most likly burned out and will require replacement. Sorry. Thank you.
May 29, 2011 | Garden
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
149 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
