Question about Olympus Camedia C-350 Digital Camera
Lens opens when shutter slide is activated then goes back immedia
The lens opens when slide is activated but withdraws immediately. battery has been fully charged
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 14, 2010
  • adamsfam824 Aug 25, 2010
    Well done. With my Olympus C-350 Zoom I went through all these, and finally did fix #6a, which is listed separately on the blog page, though not above. (I got there by clicking on the link above "Fixing a lens error on a digital camera".) With the camera pointing downwards and the USB cable plugged in, I tapped the lens with the back of a screwdriver. Bingo! It's a great camera, and I didn't want to bin it; so thanks!
Why does my Shutter locks when taking picture
Sir,
This is a common fault in such models. carefully open the back cover and bottom of your camera thus you can find the shutter opening gears and related parts. with the help of a needle apply some silicon grease on this gears let it free by rotating the parts then fix the covers it will work properly, check the condition of the battery in some cases weakness of the battery also cause this
thanks raufkdv@hotmail.com
Sep 05, 2014 | Sony A Alpha - Camera Digital Slt-a65v Slr...
I cannot retract the lens back to my Rollei 35 se
Your question seems to be mis-categorized under slide projectors, if you are asking about Rollei 35 SE camera, the lens will only retract if you cock the shutter with the wind lever, then press the button next to the shutter release and rotate the lens a few degrees.
Nov 13, 2013 | Rollei 66 Dual Slide Projector
Shutter won't open/blaack when you look through lens
Your shutter may be stuck open... this will give the appearance of the shutter not opening as well as no image when you look through the viewfinder.
Open the back of the camera, as if you were replacing the film, and look to see if the shutter is open. If it is, you can probably see light coming through the lens when looking from the back of the camera.
If this is the case, you will need to find out why the shutter is stuck open.
Some cameras use a battery to activate the shutter, some cameras have a "bulb" setting that keeps the shutter open for long exposures.
Whatever you do, do NOT force the shutter... I might jiggle it a little bit to see if it will close, but I wouldn't recommend more than a slight jiggle.
While you have camera open, inspect the mirror. If the shutter is closed but the mirror is stuck "up" (to allow light to reach the shutter/firm), there is a chance that you would not be able to activate the shutter.
Aug 31, 2010 | Pentax Program Plus 35mm SLR Camera
Lens gets stuck,and makes a clicking noise when trying to open
Hi
Thanks for using FixYa. With the camera closed and off point it straight up (lens towards the ceiling) and hit the power button while holding down the shutter release. When the camera opened, it immediately tried to focus for the picture it was told to take, and apparently it forced the lens to move.
You can also try blowing compressed air around the lens cover to clean it. Now slide a thin strip of paper between the lens cover shutters and the outer support ring and move it around 360 degrees. This will clear the debris stuck there.
With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat these steps several times to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 04, 2010 | Samsung S1050 Digital Camera
On the lens makes a clicking noise shutter goes in and out turns.
Did you drop it? if you did you have damaged the gear drive motor for it. Are the batteris good?
Jul 06, 2009 | Olympus FE-210 Digital Camera
Camera turns on then immediately turns off
Quick turnoff is normally a symptom of low battery power. Make sure that you have fresh/charged batteries in the camera. If fresh power doesn't solve the problem you will need professional service on the camera.
Bill B.
San Antonio
May 12, 2009 | Olympus Stylus 400 Digital Camera
Dark shutter hangs in up position
The dark shutter requires an adjustment to re-set it's "trip point". You should take it to a factory-trained repair dealer who has the service documentation & tools to make the adjustment.
Jan 06, 2009 | Kodak ATS Ektagraphic Slide Projector
K100D Problem
Remove lens, locate silver vertical pin inside of mounting ring on left side as you are looking at camera. Lightly slide black plastic piece which is on the vertical pin downward; if it will go downward remount lens and try camera. If plastic piece will not go down, lightly slide it up and then down and now remount lens and try camera. My guess is that either that component is sometimes stuck or that it may have become mispositioned while removing and replacing a lens.
Nov 11, 2007 | Pentax K100D Digital Camera
Olympus Camedia C-350 Digital Camera Logo
100 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
