Thank you for your suggestions
I did as you suggested and updated the graphics card driver. This did not help. I also tried lower resolution. The problem is that there are big splotches and lines of purple/red pixels (even when i lower the resolution), and these areas of pixilation change according to whatever appears on the screen, so for example, if there is a photo of mountains, there will be pixilation on parts of the mountains, and if i am viewing some graphics, there will be pixilation along the graphics. It's not just a couple of bad pixels. It began this evening a little after downloading a photo from a disc that my sister had send me, so i assumed it's a virus, but a complete virus scan didn't turn up anything. Any other suggestions will be most welcome. Many thanks.
  • shaidan Apr 02, 2008
    neither fixya nor geek squad could figure this one out. i finally discovered that it was simply that the lines btwn monitor and tower were loose.
  • 58 Answers
Hi Shaidan ... try going into the system settings and advanced then visual effects under performance ... put it on custom then disable (remove checks) beside everything ... also many graphic cards have fans on the graphic processor these days ... you can take a look at that and make sure it is clean and performing ok ...
Posted on Mar 30, 2008
Not getting full resolution of 1920 x 1080 on acer monitor p226hq - installed on HCL desktop - pentium 4 processor - 256 x 512 RAM suggestions
The 64MB graphics card installed was created at a time where that resolution was only dreamed of. The graphics card is not able to support the modern resoultion of 1920X1080.
One option is to install a newer graphics card or install the latest software called drivers, they may help you achieve HD resolution. Drivers can be found on the manufactures website. Download them and install them on your computer.
Take care!
Sep 10, 2011 | Acer (9005210464), (64 MB) Graphic Card
Hello, My winXP cannot recognize monitor Asus VH232T - windows suggests 4:3 resolutions only. Can you please advise where can I download the monitor driver? Video card is ATI RADEON XPRESS 200 Thank...
Monitors do not generally require drivers. The .inf drivers to run almost all monitors are already in Windows.
The problem here is in the settings of the graphics card.
Many users aim for Maximum resolution, when what they should aim for is Optimum resolution, balancing the RAM, CPU, GPU, GRAM and Monitor''s resources in the most efficient and effective way.
Keeping the relevant software updated also has an impact on graphics performance (grpahics Card Drivers, Java, Flash, DirectX, Video Codecs, etc.)
If the video resolution is set too high (or too low), beyond the graphics capabilities of the monitor, on reboot, the monitor will be unable to resolve the image.
The simplest solution would be to use a different monitor to adjust the video resolution, shut down then test the preferred monitor again.
Right Click on desktop>Properties>Settings then use the slider scale to adjust resolution, then Apply, Yes on the optimum setting, them OK.
Find the optimum setting in XP with your graphics card for this monitor and you should be fine.
Hope this helps.
Aug 02, 2011 | ASUS VH232H 23" Monitor
Hi, When I try and run my monitor through my XFX 8600gts graphics card most of the time the monitor wont work, i take it out and plug it into the mother board and all is ok, Rarely it will work through the...
I would suggest you lower your resolution settings from your video card to your monitor. Possibly they are to high for your monitor to handle. Go into control panel to change your settings at a lower rate and see if it runs any better.
I hope this helps you out if so please leave me some feed back.
Apr 03, 2011 | XFX NVIDIA GeForce 8600 Graphics Card
The screen display looks odd and undersized, and the icons are smaller than usual
Nvidia 9300GS is a well-performing graphics card. Such display resolution problems should not occur. To resolve issues of faulty display, download and install the latest driver of your Graphics Card. Go to Nvidia's official website and get your device's WHQL Version of driver, don't go for the Beta drivers.
Thank You.
Mar 08, 2011 | Nvidia Geforce 9300GS, PCI Express Video...
I have a dell 280GX and would like to increase it's graphics. I installed fsx deluxe but get out of range from monitor. I have done all the basics (settings advance and refresh). What is the suggestion?
This is a graphics card issue. I suggest you try say an Nvidia GTS250 card. If you are pushing up the resolution too high you will get this mesage. Short-term fix, try lowering the resolution in the settings of your current graphics card. This should help.
May 19, 2010 | Dell Optiplex GX280 (99301) Motherboard
I have an intel 82845G/GL/GE/PE/GV graphics controller. Games that used to work well now they don't run anymore. I get a black screen with a message ''H.V. Frequency overrange'' and the Pc shuts down....
reset you video settings. try to lower frequency settings or start setting to default VGA mode then try moving to 800x600 resolution then up.. 'hope this helps
Jul 10, 2009 | Computers & Internet
My laptop doasn't regonize my tv when i connect it
I would suggest that you should reduce the screen resolution of your laptop to something like 800 by 600 pixels, then try to reconnect it.
This is because there are some TVs that can not display the resolution provided by some high-end laptop graphics card, and I have actually experienced a case like this before.
So just try and check some lower resolutions on the laptop to connect it to your TV.
Hope it helps you out.
Mar 31, 2009 | Computers & Internet
Resolution problem on LCD
Are you saying that when you try to change the resolution it does not display 1440x900?
I would suggest downloading the drivers for the monitor as well as the latest drivers for your graphics card.
I'm guessing you used a different graphics card before now - use ATI's driver uninstaller to remove the current driver and any other drivers before installing the latest driver from ATI. They have a program made to remove their drivers that you're supposed to use every time you change cards or update a driver. Shouldn't be hard to find.
If that doesn't work, come back and we'll try the next thing.
Dec 13, 2008 | Computers & Internet
Resolution Problem
you need to be installing a graphics driver for your onboard graphics or your graphics card, the monitor driver won't change the resolution, when you installed XP there wouldn't have been a graphics driver installed, only a VGA driver to enable a 800 x 600 resolution.
Find out your card manufacturer or your onboard graphics or use the cd that came with the motherboard or card.
Oct 22, 2007 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Computers & Internet Logo
154 people viewed this question
David Payne
David Payne
